This is Polly, the m30b35 swapped Ratrod.
  • F34R
    sLaughter
    • 12376
    #511
    Originally posted by thatphysicsguy
    Had an awesome time hanging out with the binghamton crew, picking parts, and eating spiedes!
    Glad you had a nice time here, and those spiedes are amazing.
    Instagram: @BWeissLeather
    Current cars:
    ~ '87 325 M30B35 swap
    ~ '87 535
    ~ 01 540 Msport 6spd
    ~ '06 X5 4.8is
    • Swanny
      • Mar 2012
      • 2834
      #512
      Wheres the coolant puddle?
      How is that other hose holding up? Any wear from the belt?
      Swanny!
      SUCKERS.
      • F34R
        sLaughter
        • 12376
        #513
        This was the day after all that shit, you know that lol...and the new hoses are perfect, ordered a new O2 sensor and getting the coils to fix the exhaust studs/
        Current cars:
        ~ '87 535
        ~ '06 X5 4.8is
        • Swanny
          • Mar 2012
          • 2834
          #514
          Hellllz yeah
          Swanny!
          SUCKERS.
          • F34R
            sLaughter
            • 12376
            #515
            Boring update:
            After rushing to refresh the M30 for Gfest '13 I neglected things to just get to the event, this year has just been going over everything and redoing last minute rushed work. Bought a rebuilt Bosch 140amp alternator and got a new Bosch 02 sensor to resolve the rich running issue. Had to add about 10" to make it from the header bung to the drivers side harness plug. Soldered the splices and heat shrinked the connections, then added a ribbed plastic tubing to keep the bare wires safe from vibrations.
            Cured the rich burn ratio from the lack of an O2 and got to route a bunch of wiring from the last minute install of my M30 for last year, long term I want to pull the M30 out and install a b25 harness I have laying around.
            Right now I am focusing on Gfest '14 and cleaning up everything for the trip:
            -Heilcoil two exhaust studs that the owner before me fucked up.
            -Add resonator after the Vband
            After the event I will be tackling body work and
            Current cars:
            ~ '87 535
            ~ '06 X5 4.8is
            • DER E30
              • Sep 2013
              • 2349
              #516
              Polly getting painted?
              -Christian
              • F34R
                sLaughter
                • 12376
                #517
                I have a few things in mind, not sure what one yet(playing in photoshop). No shiny paint, I hate chrome and new paint.
                Current cars:
                ~ '87 535
                ~ '06 X5 4.8is
                • F34R
                  sLaughter
                  • 12376
                  #518
                  Random shots from my outing tonight.
                  Current cars:
                  ~ '87 535
                  ~ '06 X5 4.8is
                  • F34R
                    sLaughter
                    • 12376
                    #519
                    Some shots tonight from a nice drive.
                    New fender is installed from DJ ButtChug, shot it with some clear coat and left the rust patina like it came to me.
                    Current cars:
                    ~ '87 535
                    ~ '06 X5 4.8is
                    • F34R
                      sLaughter
                      • 12376
                      #520
                      Detailed the bay and blacked out a few things, currently reworking the cooling system and getting ready to install the MLS gasket and ARP studs(including helicoil some stripped exhaust manifold studs).
                      Using a 16" Spal pusher fan 30102048 and using a puller 16" fan in the engine bay, also a Spal. I am unsre of the 16" fitting in the bay off to the left(drivers side) I am going to see if I can make it work since I own it already.
                      Current cars:
                      ~ '87 535
                      ~ '06 X5 4.8is
                      • JGood
                        • Jan 2004
                        • 7959
                        #521
                        A pusher and puller together will just double the restriction above 40mph, raising temps. Below 40, they will just move the same amount of air. A 3000 CFM fan in front of a 3000 CFM fan will move 3000 CFM or air. Or maybe less, depending on what happens to the airflow between them. I'd assume it would get pretty turbulent...
                        e30 restoration and V8 swap
                        24 Hours of Lemons e30 build
                        • M-technik-3
                          • 18946
                          #522
                          Heading to Saratoga next weekend?
                          • F34R
                            sLaughter
                            • 12376
                            #523
                            Picked up a set of these, if you're mounting a fan, this IS the fastest/best way to mount it.
                            I had to trim the heads a bit to fit in the angle of the fan body.
                            Nice stick pads to protect the fins, for 6.00 the kit did the trick. **when using these zip tie-like rods, make sure to give yourself a few notches after the clip.**
                            I tested it all out with the new fan installed...there is NO need for a second! damn this thing is so much better than my low profile Spal.
                            Details? I am free next weekend ;D
                            Current cars:
                            ~ '87 535
                            ~ '06 X5 4.8is
                            • LJ851
                              • 7919
                              #524
                              Originally posted by F34R
                              Picked up a set of these, if you're mounting a fan, this IS the fastest/shittiest way to mount it.
                              ftfy.
                              I highly recommend you make a real fan mount instead of hanging the fan off the radiator tubes, something they are not designed to do.
                              Lorin
                              The M30 is God's engine.
                              • F34R
                                sLaughter
                                • 12376
                                #525
                                For now...they got the job done. I am out of town and needed the fan installed badly.
                                Current cars:
                                ~ '87 535
                                ~ '06 X5 4.8is
