S54 powered E30 track car
  • Pootis
    • 636
    #181
    What size tires are you running on the black car?
    1989 325i LS Swap (Money Pit):https://www.r3vlimited.com/board/sho...d.php?t=244933
    COTM Feb 2019: https://www.r3vlimited.com/board/sho...d.php?t=428404
    • Larzzz
      • Jan 2013
      • 531
      #182
      Very cool!
      1991 318i Slicktop - Sold
      1991 325ix - Sold
      1997 Estoril M3 Coupe - Sold
      1986 325es - RIP
      1997 328is - Sold
      1995 Avus M3
      instagram @MattLarzz
      //M42 GOON-SQUAD
      http://www.r3vlimited.com/board/showthread.php?t=281596
      • grt
        • Apr 2011
        • 246
        #183
        225/50 R15 on a 7 inch rim.
        Track car
        http://www.r3vlimited.com/board/showthread.php?t=2214204
        Street car
        http://www.r3vlimited.com/board/showthread.php?t=307890
        • grt
          • Apr 2011
          • 246
          #184
          Originally posted by yberther
          When I saw the cage, I was like hmm, not super reinforced on that side, and forgot too!
          The car looks like it moves properly! Holy crap that looks like fun. The videos are awesome.
          Are the rears rubbing a ton? It looks like you'd benefit from stiffer rear springs (stop the rubbing), and it might reduce that longitudinal weight transfer out of the corners and balance out that light weight front... That's what it looks like from watching the videos, what do you think?
          Haha Im not so sure. Stiffer would stop the tyre scrub but it wouldnt squat as much and I will be loosing rear grip. We all love squat!
          Big day of work planned so I am getting stuck into it!
          Track car
          Street car
          • grt
            • Apr 2011
            • 246
            #185
            Ok quick update before racing tomorrow.
            Today we fixed the alternator bracket. I couldn't get ahold of a M3 bracket or anything that looked the same. I ended up getting a M20 (I think) bracket off a friend and customized it to fit. I just bent it like the original.
            A quick clean and coat of paint and it was set to go. Installed it fine and I can now adjust my belt to the correct tension!
            We also bashed the inner rear guards for better tyre clearance.
            After I had an issue with a wheel nut at Mt Cotton I decided to retire the wheel nuts and install some new ones to be safe as the old ones looked a bit second hand.
            Apart from that we just went over the car and double checked everything.
            A few quick pics
            M20 vs S14 bracket
            Cleaned up ready for paint
            Install on the car
            New nuts!
            Track car
            Street car
            • reelizmpro
              • 9556
              #186
              Here's a tip...M10 uses the exact same bracket as S14. I worry that the M20 bracket will not last due to the offset mounting hole and the hole in the center. S14's often shear these brackets around those area's.
              88 M3 - LACHSSILBER
              89 M3 - ALPINEWEISS II
              • grt
                • Apr 2011
                • 246
                #187
                Yer I couldnt find an M10 old. Hopefully it holds up.
                Track car
                Street car
                • grt
                  • Apr 2011
                  • 246
                  #188
                  Well my first race day is done and dusted! To say it was a success would be a understatement. I have an absolute ball and can't wait to get back out there.
                  First a bit of background about the category I was racing in. It was known as the Queensland V8 series in 2012 but due to smaller numbers they decided to open the invite to cars. Cars around the late 80s early 90s period could race in this category. They changed the name to Queensland Touring car championships. There were 14 entrants in the class, 5 BMW E30s, the rest were V8 Holden’s and Fords.
                  First up on Sunday morning was qualifying and it was the first time I had driven this car around Lakeside raceway before so it was a bit nervous. It was also my first time driving on Hankook slicks.
                  Qualifying went very well. I did have a little off which bent the bumper up (see video below). I think this happened because when we reinstalled the gearbox we overfilled it a little thus had gearbox oil leaking from the breather hose. Combine that with tyres that were going off and it wasn't hard.
                  I ended up qualifying 6th but because it was my first race so I decided to start from the rear of the grid and watch what happened from the back. Starting 13th by the end of the 7 lap race I was 11th and very happy with that result.
                  Race 2 I gained 2 more positions and finished 9th.
                  Race 3 was the finale race and the heaven opened up! It poured down rain about 30 minutes before our race and wasn't easing up. We swapped back to my Yokohama A050 soft tyres. A few of the front running V8s didn't have wet tyres so I moved up into 7th place for the start. Coming onto the straight viability was terrible. You could hardly see the car in front. I got a good start and tucked in behind another E30. We both passed 4 cars to make it a BMW 1,2,3.
                  It was a difficult race as the drivers side wiper also decided to break and the windscreen was fogging up!
                  Overall I am hooked on racing and I can't wait for the next one! Here are some pics and a video of my off. I will upload videos on the races in the next few days.
                  Note the front bar pushed up after off.
                  Check out the drivers side wiper arm.
                  Track car
                  Street car
                  • grt
                    • Apr 2011
                    • 246
                    #189
                    A little rallying
                    Track car
                    Street car
                    • e30_neverstock
                      • Nov 2011
                      • 283
                      #190
                      looks like shes a screamer!
                      • King Mufasa
                        • Sep 2012
                        • 530
                        #191
                        Best engine to put in a e30 period.
                        • noahb
                          • Dec 2012
                          • 125
                          #192
                          you're my hero.
                          • grt
                            • Apr 2011
                            • 246
                            #193
                            Yer I love it!
                            Originally posted by noahb
                            you're my hero.
                            I'm a hero to many...
                            The car or....??
                            Track car
                            Street car
                            • Cabriolet
                              • 9620
                              #194
                              damage anything going off the track like that?
                              Much wow
                              I hate 4 doors
                              • CanadianBacon
                                • Dec 2008
                                • 12
                                #195
                                This is so great man. All 13 pages, good work! Cool vids too!
