Ill4noreason's Turbo M42 Build
  • ill4noreason
    • 2710
    #46
    Progress will begin soon shEck3lls0 and I are gonna pull the head and take it to machine shop to get checked out. Then do all new seals and head gasket. I am making a list of parts that I'm gonna need. Any advice? I know I'm not getting a vr headgasket thats for sure... I wanna keep it relatively stock just maybe beef up the head gasket with a Cometic multi layer one and longer head bolts. Next update will have major progress.
    My Multi car part out. Need a part? Pm me...
    http://www.r3vlimited.com/board/showthread.php?t=193051
    Need 24v swap parts? How about a LSD? Plastic Bumpers? Or anything else click here...
    http://www.r3vlimited.com/board/showthread.php?t=215044
    Have you done business with me? If so leave me feedback here...
    http://www.r3vlimited.com/board/showthread.php?t=188307
    • Dj Buttchug
      • Jun 2010
      • 7688
      #47
      Originally posted by ill4noreason
      What else do i need to make the megasquirt work? The original owner said I need something to make it work?
      I only wanted to make 200whp on stock setup.When I build the motor completely I am expecting at least 300. From what I have read so far it is definitely possible if you tear it down and build the motor up .The previous owner of the turbo kit said he made 246whp at 12psi on a stock m42. That seems high to me but who knows. Also certain dyno's read higher. I wonder If I call DTM if they would remember his car?? I need to figure the megasquirt shit out. The rest of the stuff I can have bolted up in a day. I just dont see the point until I have everything else hooked up.
      If anyone knows about megasquirt fill me in with what I'm missing.
      Thanks
      to make it work your need wideband and IAT sensor. Todd at DTM made that MS. he only made a few. hes a legit dude. Not sure about the 246 hp... 12 psi is about all you can throw at it before the hg pops. itll pop between 3 and 4. too much heat back there.
      Your also going to need a base tune. I can send you one once i reformat my laptop. does it come with injectors?
      Originally posted by Schnitzer318is
      I second buttchug... 300hp is going to be difficult to be reliable on, I am guessing. Maybe with studs, oring, and double stacked gasket? Not sure, that seems like it would need an a lot of boost... maybe ~20psi?
      bout 18- 20 psi gets you there no problem
      Turbo M42 Build Thread :Here
      Ig:ryno_pzk
      I like the tuna here.
      Originally posted by lambo
      • ill4noreason
        • 2710
        #48
        I bought 42lb injectors from VAC. The previous owner told me the tune was set up for 42lb injectors and 12psi. I really only wanna run 7-10psi so it will last longer. With the multi layer head gasket and bolts I hope it will handle that fine for at least a year. Either way I'm gonna pay to get it re-tuned so I'll just get it tuned to run around 10psi I think. How much should I spend on wideband and Iat sensor? Any particular brand? I will definitely have to grab that base tune from you. Thanks.
        • Schnitzer318is
          • Jan 2008
          • 2057
          #49
          I definitely recommend AEM's UEGO wideband. I've had mine going on 2 years... no problems at all since installation. I get a bit of stereo whine but I am sure that's my fault with shielding or something.
          My setup sees 8-12psi (stupid internal wastegate and actuator) and has held up for the same amount of time as the UEGO. The headgasket had about 20,000 miles on it before boost and using the stock bolts. If you are doing studs and multi layer gasket you will have no problem for a long time.
          My tune is setup for 46lb injectors (low impedance) but may help you? The only other one I have is for 32lb injectors... but was running out of fuel by 4600rpm @ 10psi. I have it it in my build thread.
          File Here: build thread file post
          "A good memory for quotes combined with a poor memory for attribution can lead to a false sense of originality."
          91 318is Turbo Sold
          87 325 Daily driver Sold
          06 4.8is X5
          06 Mtec X3
          05 4.4i X5 Sold
          92 325ic Sold & Re-purchased
          90 325i Sold
          97 328is Sold
          01 323ci Sold
          92 325i Sold
          83 528e Totaled
          98 328i Sold
          93 325i Sold
          • Dj Buttchug
            • Jun 2010
            • 7688
            #50
            I really hope those injectors are high imp. makes tuning with ms a hell of alot easier.
            i dont think my tune will help you. im running 1000cc injectors. lol itll throw everything off. duty cycle blah blah blah. unless you want to change all that when it comes time to tune.
            Ig:ryno_pzk
            • ill4noreason
              • 2710
              #51
              It says they are. Hopefully all is well.
              • Dj Buttchug
                • Jun 2010
                • 7688
                #52
                nice. the high imp saves you a lott of hassle. im stoked on this build
                Ig:ryno_pzk
                • ill4noreason
                  • 2710
                  #53
                  Me too i just wish I had more time to research more. My knowledge of Engine Internals and forced induction is limited. I'm hoping by doing this project I will learn a good amount and have a better understanding. I have been reading a lot on my time off work. A local guy just rebuilt his m42 and he is gonna help so that should be a big help.
                  • Schnitzer318is
                    • Jan 2008
                    • 2057
                    #54
                    I second all of the above. I am looking to buy some 46lb high imp injectors now because of the difficulty I've had tuning the low.
                    Good luck, I'm sure between your local guy and the board you will be able to get it done relatively quickly and reliably.
                    91 318is Turbo Sold
                    06 4.8is X5
                    06 Mtec X3
                    05 4.4i X5 Sold
                    90 325i Sold
                    97 328is Sold
                    01 323ci Sold
                    92 325i Sold
                    83 528e Totaled
                    98 328i Sold
                    93 325i Sold
                    • Vtec?lol
                      • Dec 2009
                      • 3278
                      #55
                      YAY! M42 POWAH!
                      For longevity, I would recommend lowering the compression a bunch. as for all the seals, it would be best to take the entire engine out.
                      • ill4noreason
                        • 2710
                        #56
                        Originally posted by Vtec?lol
                        YAY! M42 POWAH!
                        I am pulling the entire engine out. I bought an engine stand a while back and now I can finally use it. Plus I realize I want it to look good after going through all trouble why not clean all the parts and engine bay and do a nice neat job. I just bought a 91 4dr 318i for a daily and have been dumping money into it I gotta stop so I can get this project done.
                        • Vtec?lol
                          • Dec 2009
                          • 3278
                          #57
                          sounds awesome!
                          • ROLLingKING
                            • Apr 2011
                            • 1169
                            #58
                            where is your manifold from?
                            I like this build tho. we need more turbos around here. im also looking for a turbo manifold. ive never heard of good n tight
                            m20 is plenty. im simply a drifter.
                            build thread -- http://www.r3vlimited.com/board/showthread.php?t=206510
                            • FunfGan
                              • Jan 2011
                              • 4958
                              #59
                              Now you've got some money for this joe! :o
                              I'm also down to help if you ever need me.
                              Go here be happy!
                              Ratchet Garage e30 V8 build.
                              • ill4noreason
                                • 2710
                                #60
                                Goodntight is a member who builds turbo maniflod that is good quality. Not like ebay junk. Lot's of 24v swap go with with his adapter. Just search you will find some badass cars using it.
                                Well priorities have changed since I lost my job. As of right now the turbo build is on hold. Hopefully I can get another contract and resume work soon enough. But when your entire income is e30 parts it makes you a poor bastard lol. This is the project I started this week.
                                Yes another 318i...
                                Cracked paint:
                                Beginning of prep work to get it respayed...
                                That was about 3hrs of prep. I should have all major prep work done today. Then gonna 2 stage primer it and send it off to get resprayed. I want a e30 dd andwant it to look good so I picked this up last wednesday and dropped it on H&R Races and Bilstiens and now respraying it. Gotta look fresh while jobless...
