Ill4noreason's Turbo M42 Build
  • devon.818
    • Feb 2011
    • 2937
    #31
    he got his intercooler lined up today. i fondled the turbo, it gave me a chub.
    seriously, i've never seen joe this excited about anything other than 5dollar hooker night down at the block!
    • dnick
      • Apr 2011
      • 1377
      #32
      smart man. uber
      • FunfGan
        • Jan 2011
        • 4958
        #33
        Seriously though joe, I can't believe you scored this. Looks like I'll be seeing it on friday.
        Go here be happy!
        Ratchet Garage e30 V8 build.
        • 87vert30
          • 767
          #34
          Dude looks nice!!!!!...
          BawaMotorWerks@gmail.com
          Pummy
          • ubernasty
            • Jan 2009
            • 2749
            #35
            I'm going to try and make it by the shop tomorrow man. Looks like some good progress is being made. Let me know when you'll be around.
            • ill4noreason
              • 2710
              #36
              I should be around all day call me when you wanna come by. The contract Job I was doing ended so I have off for a while.
              My Multi car part out. Need a part? Pm me...
              http://www.r3vlimited.com/board/showthread.php?t=193051
              Need 24v swap parts? How about a LSD? Plastic Bumpers? Or anything else click here...
              http://www.r3vlimited.com/board/showthread.php?t=215044
              Have you done business with me? If so leave me feedback here...
              http://www.r3vlimited.com/board/showthread.php?t=188307
              • dnick
                • Apr 2011
                • 1377
                #37
                hows it coming with it?
                • ill4noreason
                  • 2710
                  #38
                  Not many updates. I got my 42lb injectors from vac the other day. I found a semi local tuner. I washed out the engine bay but it still needs more cleaning. I'm gonna do the head gasket, oil pan gasket, rear main seal, and all other engine seals. Also gonna pull the motor and trans change to a more capable clutch and lightened flywheel. I wanna check all the timing stuff to make sure nothing needs replacing. I found a leak in spark plug #1 I believe its from the valve cover gasket. The car is off the road for the winter. I am buying a 91 318 for a dd tomorrow. Updates will come soon I just dont wanna bolt stuff up only to take it all off again.
                  first cleaning of bay...
                  All I got for now been busy as shit parting out cars... Buy my parts fund my project!
                  • Dj Buttchug
                    • Jun 2010
                    • 7688
                    #39
                    that MS is from DTM here in SD. Im running the exact same software.
                    good luck btw. Not sure if you can make those hp numbers on stock internals tho...
                    Turbo M42 Build Thread :Here
                    Ig:ryno_pzk
                    I like the tuna here.
                    Originally posted by lambo
                    • ill4noreason
                      • 2710
                      #40
                      What else do i need to make the megasquirt work? The original owner said I need something to make it work?
                      I only wanted to make 200whp on stock setup.When I build the motor completely I am expecting at least 300. From what I have read so far it is definitely possible if you tear it down and build the motor up .The previous owner of the turbo kit said he made 246whp at 12psi on a stock m42. That seems high to me but who knows. Also certain dyno's read higher. I wonder If I call DTM if they would remember his car?? I need to figure the megasquirt shit out. The rest of the stuff I can have bolted up in a day. I just dont see the point until I have everything else hooked up.
                      If anyone knows about megasquirt fill me in with what I'm missing.
                      Thanks
                      • Schnitzer318is
                        • Jan 2008
                        • 2057
                        #41
                        I second buttchug... 300hp is going to be difficult to be reliable on, I am guessing. Maybe with studs, oring, and double stacked gasket? Not sure, that seems like it would need an a lot of boost... maybe ~20psi?
                        "A good memory for quotes combined with a poor memory for attribution can lead to a false sense of originality."
                        91 318is Turbo Sold
                        87 325 Daily driver Sold
                        06 4.8is X5
                        06 Mtec X3
                        05 4.4i X5 Sold
                        92 325ic Sold & Re-purchased
                        90 325i Sold
                        97 328is Sold
                        01 323ci Sold
                        92 325i Sold
                        83 528e Totaled
                        98 328i Sold
                        93 325i Sold
                        • Simon S
                          • Oct 2004
                          • 3758
                          #42
                          Whooot !!
                          Also stoked for progress on this endeavor..
                          -----Zen and the Art of e30 Maintenance - / - Zen TOC - / - Zen Summary
                          • Ryann
                            • 3350
                            #43
                            Wwwwwwwwwait a minute, those numbers sound familiar. Was this kit in an e36 318is?
                            • ill4noreason
                              • 2710
                              #44
                              The kit was on this car...
                              Scroll down to post 17.
                              He could of been bullshitting. I don't know honestly. Either way I'm not trying to build a race car just a badass vert with boost and still get good gas mileage. I will see what numbers it makes when I take it to get tuned. Anything over 200 and I'll be happy on stock internals.
                              • Ryann
                                • 3350
                                #45
                                Okay. It made me think of a certain m42 turbo thread over at m42club.com.
