This Is Randomness(and my build thread, I swear).
  • dnick
    • Apr 2011
    • 1377
    #421
    Originally posted by VinniE30
    For you also add to advantages the fact that you won't have to figure out how you're going to do a power steering pump, reservoir, and lines with a v8 in the bay and any extra work involved.
    yes that too!
    • FunfGan
      • Jan 2011
      • 4958
      #422
      Yeah the only trouble I had was how to hook the lines up to the pump on the 5.0, but glad I don't have to do that anymore haha.
      Go here be happy!
      Ratchet Garage e30 V8 build.
      • dnick
        • Apr 2011
        • 1377
        #423
        Originally posted by LJ851
        Ideally you want the remaining fluid/ air to be able to circulate, so linking the banjo bolts with a hose is the cheap and cheerful way.
        ive heard otherwise.. there are soo many threads on either linking them, or just putting bolts in both holes. i just went with throwing the bolts on em.
        • FunfGan
          • Jan 2011
          • 4958
          #424
          Anybody? Whats your take? It sounds like Vinnie30 just did the bolts too.
          Go here be happy!
          • LJ851
            • 7919
            #425
            If you get most or all the fluid out it shouldn't matter what you do as air is easily compressible. Linking the fittings makes it idiot-proof, and there are some determined idiots out there....
            Lorin
            The M30 is God's engine.
            • FunfGan
              • Jan 2011
              • 4958
              #426
              Haha. So either way, you would suggest leaving as much of the fluid in there as I can?
              Go here be happy!
              • dnick
                • Apr 2011
                • 1377
                #427
                lol not sure if you want to ask that, itll turn into a big stupid discussion that will get nowhere. Theres a few threads on here about this, ive basically read them all lol and i just said, fuck this im getting the bolts. Ive thrown the wheel back and forth many times so far and it feels fine. There is no pressure increase or bullshit like that that some people say will happen (which is why they say get the one that has the little hose that connects both holes).
                sparknotes: get the bolts, youll be fine. :)
                • dnick
                  • Apr 2011
                  • 1377
                  #428
                  i havent felt a difference so far with having them blocked off, but im not going to argue with you because there has been so much bickering in this thread so far lol
                  • LJ851
                    • 7919
                    #429
                    NO!! Remove as much fluid as you can. Its only purpose is to assist under pressure. If you dont pressurize it, it just gets in the way and causes resistance.
                    Lorin
                    • FunfGan
                      • Jan 2011
                      • 4958
                      #430
                      Nick I have to say I'm going with LJ851 on this one. No offense, but thats how it seems the liquid would work to me... We'll see what the outcome of no fluid is though.
                      Go here be happy!
                      • dnick
                        • Apr 2011
                        • 1377
                        #431
                        wait what? " but thats how it seems the liquid would work to me" dont get that part?
                        you have to remove the fluid either way.
                        • LJ851
                          • 7919
                          #432
                          I have had 2 e 30's without power steering. One had the rack drained and bolts put in the holes. It drove great with no side effects except slightly harder steering at low speeds.
                          The second one is my current one with a fully functional PS system that i thought had a bad pump so i cut the belt. Damn near impossible to drive, so much resistance unless you turned the wheel really slow. parking lot situations were comical.
                          So... dry rack, no prob. wet rack, maybe so link banjos.
                          Lorin
                          • dnick
                            • Apr 2011
                            • 1377
                            #433
                            yeah i forgot to mention i also drained the fluid, THEN blocked off the holes with bolts. whoops
                            • FunfGan
                              • Jan 2011
                              • 4958
                              #434
                              :facepalm. Problem solved everyone haha.
                              Go here be happy!
                              • dnick
                                • Apr 2011
                                • 1377
                                #435
                                :oops: my bad hahahahah
