This Is Randomness(and my build thread, I swear).
  • FunfGan
    • Jan 2011
    • 4958
    #661
    Is that really going to be stretched? I found a pic of that size on a 10 and it looked pretty square...
    Go here be happy!
    Ratchet Garage e30 V8 build.
    • FunfGan
      • Jan 2011
      • 4958
      #662
      Host your images online with an easy to use image uploader, albums, photo hosting, sharing, dynamic image resizing on web and mobile.
      Thats supposedly a 235/50rX on a 10 inch wide rim...
      Still a tire size noob, forgive me hahah.
      Go here be happy!
      • LJ851
        • 7919
        #663
        I had 245/45/16 on my 16x9 Fuchs and it was pretty square. (Rear Wheel)
        Lorin
        The M30 is God's engine.
        • lolcantturn
          • 4588
          #664
          you will be stretched on 235's.
          Originally posted by TSI
          OEM+
          • VinniE30
            • 2113
            #665
            A 235 tire should be run on at the most a 8.5 inch wide wheel. I would run it on an 8 inch wide wheel.
            Zinno '89 <24v swap in progress>
            • FunfGan
              • Jan 2011
              • 4958
              #666
              The tires I'm running apparently run super wide, so it would supposedly be a little wider than a 245? They're R888's.
              Go here be happy!
              • VinniE30
                • 2113
                #667
                10 inch wide wheels are for 275 width tires and up. Of course you can run less wide tires but it won't be ideal. See tire rack and look up the 235 tires you want and see what width wheel is recommended...
                • lolcantturn
                  • 4588
                  #668
                  Since you're going all out to be different, try and run 255's on your E30. Seriously. Cut the inside lip of your quarter panels, and get a roller and pull those motherfuckers out an inch.
                  OEM+
                  • FunfGan
                    • Jan 2011
                    • 4958
                    #669
                    The R888's had the biggest size in 15's that weren't a full out track tire. We'll see. I may just go 9's.
                    Go here be happy!
                    • VinniE30
                      • 2113
                      #670
                      From toyo's website:
                      Approved rim width: 6.5-7.5-8.5
                      So 8.5 at the most, 7.5 being the proper fitment.
                      That's for the 235 width R888 tires that you said you want.
                      • lolcantturn
                        • 4588
                        #671
                        Hoosiers.
                        OEM+
                        • FunfGan
                          • Jan 2011
                          • 4958
                          #672
                          My point is, what Toyo says is the norm for most tires, but If the 205's run as wide as 235's in Starspec sizing(pretty normal sizing) the 235's should run closer to 255/265. No?
                          Go here be happy!
                          • shEck3lls0
                            • Jan 2011
                            • 1154
                            #673
                            Think about it this way Stuart.... I have 215s on my 9s. You're going to be running a 20mm wider tire. There are 25.4mm in an inch. So with that extra inch of wheel you'll be slightly more stretched then mine. It also depends on what sidewall you run. Your stretch/contact patch will be the same, but depending on the size sidewall, it can make it appear more or less stretched. So if you can find some 255s, that'd be closer to ideal.
                            1989 Alpine 325is 2dr m50 swapped
                            Build Thread:
                            Current ongoing build. Check it out!
                            1991 318is 4dr rallycross
                            Rallycross Build Thread.
                            1991 Alpine 318is coupe - sold
                            • FunfGan
                              • Jan 2011
                              • 4958
                              #674
                              Originally posted by shEck3lls0
                              Think about it this way Stuart.... I have 215s on my 9s. You're going to be running a 20mm wider wheel. There are 25.4mm in an inch. So with that extra inch of wheel you'll be slightly more stretched then mine. It also depends on what sidewall you run. Your stretch/contact patch will be the same, but depending on the size sidewall, it can make it appear more or less stretched. So if you can find some 255s, that'd be closer to ideal.
                              See above links.
                              Go here be happy!
                              • FunfGan
                                • Jan 2011
                                • 4958
                                #675
                                And this is a 235 on a 7 1/2 wide rim. 9's have to fit pretty well, no?
                                Go here be happy!
