Today's project: hitch reinforcement and trailer (almost) completion.
As noted previously, I installed a hitch that is basically sold everywhere as *the* design for the metal-bumper e30s. It bolts to the bottom of the bumper and to the bottom of the spare tire well. IDK.....I suppose it works fine, but would like a bit more reinforcement. So I added a piece of 1/2" steel vertically, which is the design that later e30 hitches use, bolting through the trunk vertically. Figured I'd combine the two to get a stronger/more stable hitch, just to be safe.
don't ask why it's not "pretty"......mostly because it won't be seen, so who cares. And yes, that's an ugly-ass weld for sure. The wire kept jamming, so I kept on having to make ugly restarts....
heres the inside of the trunk. It bolts through and then angle bracket leftover from the trailer project as a backing plate.
here you can see up under the bumper where it bolts through. just enough room
I still need to do the trailer lighting wiring from the car. I need one of those little converters since the car has seperate brake/taillight/signal lights and of course the trailer doesn't....an annoying waste of $28. I may have to think of a workaround :)
so, back to the trailer. It was mostly done already, but I finished up the wood deck by coating it in truck bedliner, so it will be "weatherproof" and also have some grip to it. And of course needed it to be black :)
So here's the trailer as it is almost done. Still plan to add a few tie-downs up front once I decide what I want to carry up there, and fab up a mount for the spare (thinking of a few options here).
box bolted down. I left some room behind it in case I want to carry larger diameter tires in the future (I only mention it because someone brought it up over on dirtyimpreza).
