Kamotors E30-Turbo to ITB M20
  • ThatOneEuroE30
    • Dec 2013
    • 8626
    #1696
    Originally posted by kamotors
    depends on whats left of my budget
    Is there a guide on doing the removable rad support This could come in very handy for me.
    1991 318i 4dr slick top
    Mtech 2 turbo restoration
    • badnerd
      • May 2008
      • 65
      #1697
      oh snap this is gonna be good
      • kamotors
        • Nov 2007
        • 7102
        #1698
        thinned out the body harness, so much simpler now and less cluttered.
        You can see how thin is now.
        cleaning up the engine bay, need to paint a few spots,wrap turbo side in heat tape etc.
        need to replace steering rack boot
        7speedshop.com
        • RagtopE30
          • Dec 2010
          • 1869
          #1699
          You are going to need one of my "I tuned it myself" stickers!
          And I am going to need some of your flares!!!!
          450whp 524 lb-ft 1988 336ic In progress
          http://www.r3vlimited.com/board/showthread.php?t=250709
          • kamotors
            • Nov 2007
            • 7102
            #1700
            yeah, I really want one of those stickers!
            not much of an update, engine bay cleaned up, I'll kmow the details on my bottom end tomorrow so I can order bearings and piston rings and other than that the engine bay is just about ready to accept a new motor.
            quick question about the driveshaft I was told that I could use the front half of the 535i driveshaft combined with the rear of an E30 bu its looking like the combined length is a few inched longer than a 325i driveshaft. what are my other options as far as driveshaft is concerned?
            7speedshop.com
              • 37828
              #1701
              Driveshafts are balanced as a unit so I wouldn't want to mix and match.
              You should be able to use a stock E30 driveshaft. That's what we did on Shant's car. You can either find the Eta large guibo driveshaft or swap a small flange on to the trans.
              Classic BMW Specialists
              Grover Beach, CA
              www.BimmerHeads.com
              • LagunaSecaBlue
                • Sep 2013
                • 360
                #1702
                Two easiest ways here. Either use a SETA(Large giubo) Driveshaft or Swap on a 325i(Small Giubo) output flange and use a 325i Driveshaft.
                #AZE30
                1991 318i
                1989 325i
                1989 335i
                • Good & Tight
                  • Apr 2004
                  • 2057
                  #1703
                  I would suggest not running the small giubo, especially for a M30 turbo car.
                  Need a Turbo manifold? We have them in stock- Click here---> http://rapidspoolindustries.com/
                  ____________________________
                  E-mail Panayiotisx2@gmail.com
                  Dyno vid http://www.youtube.com/watch?v=C7aM7..._order&list=UL
                  • RagtopE30
                    • Dec 2010
                    • 1869
                    #1704
                    Just due to the ease of it I found and swapped in a SETA (or early 325) drive shaft.
                      • 37828
                      #1705
                      Good point! The car I've done it on was NA.
                      It seems like a 96+ E36 328/M3 driveshaft would also work, no?
                      Grover Beach, CA
                      www.BimmerHeads.com
                      • ForcedFirebird
                        • Feb 2007
                        • 8300
                        #1706
                        Correct. Same as a 24v swap. e30m3, e36m3/328 and late eta would all work, e36 variants needing the CSB flipped. Early eta and all 325i (both e36 and e30) came with small Guibos.
                        john@m20guru.com
                        Links:
                        • RagtopE30
                          • Dec 2010
                          • 1869
                          #1707
                          Kamotors 325i Turbo build+M30 build
                          I got my large guibo driveshaft out of a 1985 325. They can be found in the 1984 and 1985 325 cars but you have to install a late model CSB if you are installing it in an 88 or newer
                          • ForcedFirebird
                            • Feb 2007
                            • 8300
                            #1708
                            Not sure the dates of the driveshaft change, but I have owned 3 eta's 86 and 87, all had the small guibo.
                            john@m20guru.com
                            Links:
                            • RagtopE30
                              • Dec 2010
                              • 1869
                              #1709
                              Yeah the 86 and 87 were definitely small guibo. And not all of the 85's had large guibo's but many of the 85's I have come across did have the larger disc.
                              Sorry for derailing your build thread!
                              • kamotors
                                • Nov 2007
                                • 7102
                                #1710
                                88 seta is small flange as well.
                                7speedshop.com
