Kamotors E30-Turbo to ITB M20
  • Dj Buttchug
    • Jun 2010
    • 7643
    #1981
    My car runs in the 180 210 range all day depending on driving style/ airflow What is not normal about this?
    Turbo M42 Build Thread :Here
    Ig:ryno_pzk
    I like the tuna here.
    Originally posted by lambo
    • kamotors
      • Nov 2007
      • 7102
      #1982
      im thinking flow as well, the little breather hose does not seem to flow any liquid with cap off and car runing
      7speedshop.com
      • kamotors
        • Nov 2007
        • 7102
        #1983
        because when i beat on the car it gets much hotter. If I was N/A this would be fine, the problem is its a 71c thermostat running at over 200 degrees.
        7speedshop.com
        • ak-
          • 12422
          #1984
          How long is your wastegate provisional and where is it going? Back to the DP or just dumps to the floor?
          Can you remove it and see if it will still overboost?
          How are your ports setup on the WG?
          1991 325iS turbo
          • kamotors
            • Nov 2007
            • 7102
            #1985
            dumps to atmosphere
            1.00 a/r on hotside
            7speedshop.com
            • ak-
              • 12422
              #1986
              Whoops, I meant the dump pipe after the wastegate. It looks long and squirrely.
              Maybe try removing it and see what happens?
              1991 325iS turbo
                • 37828
                #1987
                Originally posted by kronus
                Their inlet/outlet setup is the same as late model e30, upper left and lower right. you might need to improvise a lower hose, but the radiator itself drops right in.
                On a 88+ car you have to cut out the perches tat the late model rad sits on. Easy though.
                Kam you really should put a E28 radiator in there before continuing.
                Classic BMW Specialists
                Grover Beach, CA
                www.BimmerHeads.com
                • Good & Tight
                  • Apr 2004
                  • 2057
                  #1988
                  Is it spiking to 20+psi then going back down or does it stay above 20..?
                  When did this start happening. You mentioned in a earlier post it was at 14psi now it's higher?
                  Need a Turbo manifold? We have them in stock- Click here---> http://rapidspoolindustries.com/
                  ____________________________
                  E-mail Panayiotisx2@gmail.com
                  Dyno vid http://www.youtube.com/watch?v=C7aM7..._order&list=UL
                  • ThatOneEuroE30
                    • Dec 2013
                    • 8626
                    #1989
                    E28 or mishimoto. I feel like that plus a low temp therm and a high flow spal fan should have this car running right where it needs to be.
                    1991 318i 4dr slick top
                    Mtech 2 turbo restoration
                    • kamotors
                      • Nov 2007
                      • 7102
                      #1990
                      it was 14psi at like 3/4 throttle; at WOT it just keeps going, it would of kept going but i have over boost protection so the car cuts at 21/22ish.
                      That was the first wot i've done.
                      My opinion is that the exhaust would rather flow threw my turbo than be redirected threw the wastegate. I am running open downpipe so maybe if I continue to build back the exhaust it will lessen.
                      7speedshop.com
                      • blasphemy101
                        • Apr 2012
                        • 170
                        #1991
                        I realize I'm entering the discussion late, but some questions I didn't see asked..
                        Have you verified your wastegate is working correctly? While you're digging around, you might want to pull your gate off and feed it a small amount of compressed air to make sure it is opening completely.
                        Is the fire ring (if it has one) seated properly? Dumb question, but I've heard of people installing them backwards so they don't seal properly.
                        Of course, you're right, if you're overboosting, the air is going through your turbo instead of the gate for whatever reason. It might be the gate function, size, or placement. I doubt it's the open downpipe...
                        The Great Big M20 Timing Belt DIY
                        Some good information I've found online (no affiliation):
                        Turbo Tech (Garrett)
                        Four-cycle information and cam properties for beginners (ISKY Racing Cams)
                        • Good & Tight
                          • Apr 2004
                          • 2057
                          #1992
                          IMO the turbine housing is too large. A 1.00 a/r is designed for high boost pressure in the 25+psi range. Either add a larger gate or down size the turbine housing.
                          There are other people running the same manifold w/smaller turbo holding 10psi.
                          • kamotors
                            • Nov 2007
                            • 7102
                            #1993
                            cooling system plan of attack-
                            535i rad-ordered
                            new lower hose-ordered
                            and will be going with a 16" pusher fan
                            7speedshop.com
                            • ThatOneEuroE30
                              • Dec 2013
                              • 8626
                              #1994
                              535i rad-ordered
                              Hopefully that fixes problems. Which lower rad hose are you running? I'm using e34 hoses top and bottom and they got perfactly I did trim them a little bit.
                              • kamotors
                                • Nov 2007
                                • 7102
                                #1995
                                I'll be running the e28 lower as my E34 lower was cut to fit the stock E30 rad, and the lower ports sits further down on an e28 rad.
                                7speedshop.com
