Kamotors E30-Turbo to ITB M20
    Sumitomo HTR Z-II -- I presume ?
    1989 332IS -S-Fiddy Four-Some weight removed.
    5 lug E36 M3 Brakes Coilovers and LTW's and No ABS.
      Originally posted by kamotors View Post
      Staggered, I went 8.5" wide front. So i can still do u turns. I've run huge front wheels and it hurts turning radius. 8.5" is perfect front imo.
      Sent from my SM-N920T using Tapatalk
      18x9.5 isn't to bad but you have to get the spacing just right to get the turning radius back but I can still u-turn as tight as an e46 m3.
        Ya At 17x9 et10 I only had 4mm strut clearance and just rub inner wells at full lock. At 17x8.5 et15 I have stock turning no rub. Im 18x8.5 et2 now so it will rub at full lock but I don't u turn too often. The 9.5" et2 front would have far too much poke for my liking.
        7speedshop.com
          Htr z111, cheap and enough meat that it shouldn't need to be a super racey compound to get some grip. Fronts are 245/35/18 poteneza's they look almost identical tread wise and have exact same o.d.
          7speedshop.com
            7speedshop.com
              5 lug life
                Spacers or suspension swap?
                  Back to 5 lug adapters, but this time studded ones.
                  7speedshop.com
                    I did it. 285/30/18 no trimming to the standard width flares. I'll likely shave off a few mm from the inner lip though.
                    7speedshop.com
                      Getting a bit of the pokey goodness .
                        Gonna need some bigger brakes lol
                        7speedshop.com
                          That should work great as long as you don't have any suspension.
                          Lorin
                          The M30 is God's engine.
                            Started trimming one side, also going to test some ultrawides on the rear.
                            7speedshop.com
                              Why not go 5 lug?
                              1991 318i 4dr slick top
                              Mtech 2 turbo restoration
                                Originally posted by ThatOneEuroE30 View Post
                                Why not go 5 lug?
                                I may but this works for now
                                7speedshop.com
