Kamotors E30-Turbo to ITB M20
  • kamotors
    • Nov 2007
    • 7102
    #331
    ^ just DTM Fiberwerkz flares, he's a member on here.
    7speedshop.com
    • kamotors
      • Nov 2007
      • 7102
      #332
      any tips on removing the input shaft seal on the trans? I cant seem to get it out.
      7speedshop.com
      • Lof8
        • Oct 2006
        • 2827
        #333
        sweet! Those flares are killer. I've been considering them for a while. Just hesitant to shell out the dough for adequate wheels and tires to fill them out.
        S50'd
        Originally posted by TDE30
        What is this faggy shit I have happened upon?
        I can always live in a M3. Can't M3 a house.
        • Farbin Kaiber
          Lil' Puppet
          • 29502
          #334
          I prefer to use green cups. Afterward, I pretend I'm a ninja turtle and the cup is a cylinder of ooze.
          • ROLLingKING
            • Apr 2011
            • 1169
            #335
            ive had fender flares in my plans a while ago and after seeing them painted to match i must say fuuuck yes! the flares look pretty bawse with a wider than 8in wheel. and its necessary.
            only concern is if i blow a tire mid drift. I hear they rip the rear flares up bad when they blow
            m20 is plenty. im simply a drifter.
            build thread -- http://www.r3vlimited.com/board/showthread.php?t=206510
            • Sagaris
              • Sep 2009
              • 2243
              #336
              did you remove the 3 flex plate to torque converter bolts on the engine side of the TC?
              • yert315
                • 2734
                #337
                ^ do that.
                Also, are you running a short shift lever?
                • kamotors
                  • Nov 2007
                  • 7102
                  #338
                  SO i got the 5 speed and everything seems smooth but I'm missing the shift carrier bearing so I have to wait for that. should be here Wednesday. I also got a different shifter and linkage installed and it seems much smoother. cant wait to drive it.
                  Also I broke the clutch return spring on the clutch pedal box but the pedal returns fine without it so its not really needed right?
                  7speedshop.com
                  • Sagaris
                    • Sep 2009
                    • 2243
                    #339
                    Im not using that spring. Many others I talked to aren't either and don't have an issue. I still have to bleed my clutch before I drive it though so I haven't personally experienced it yet (this coming Saturday it will be finished).
                    • acolella76
                      • 2950
                      #340
                      I just noticed last night while replacing my clutch master that my return spring was broken. Not sure how long it has been like that, but I haven't noticed a difference
                      -Alex
                      • kamotors
                        • Nov 2007
                        • 7102
                        #341
                        cool, everything went really smooth, so the car should be driving by Wednesday just waiting on my last order from pelican parts to show up. Just waiting for the shift carrier bearing then I will throw the drive shaft on and be good to go.
                        7speedshop.com
                        • 4ce30
                          • Feb 2006
                          • 2762
                          #342
                          Loving the build! keep it coming
                            • 37827
                            #343
                            I've done 2 cars now with no spring and they drove perfectly.
                            Classic BMW Specialists
                            Santa Clarita, CA
                            www.BimmerHeads.com
                            • e46s54dr
                              • May 2008
                              • 1059
                              #344
                              Are the wires connected to the reverse switch on the side of the tranny? Have you tried swapping the switch for a known working one?
                              • davem
                                • Jun 2010
                                • 705
                                #345
                                +1 switch could be bad, where'd you get the tranny from?
