Kamotors E30-Turbo to ITB M20
  • tigwerks
    • Jul 2012
    • 42
    #691
    Are you going to put a one way check valve on the exhaust scavange setup?
    • kamotors
      • Nov 2007
      • 7102
      #692
      yup
      7speedshop.com
      • kamotors
        • Nov 2007
        • 7102
        #693
        Car runs excellent. Roll on throttle burn outs at speed all day:)
        7speedshop.com
        • kamotors
          • Nov 2007
          • 7102
          #694
          car drives so good now.:)
          no tire rubbing, no dead wheel bearing groans and no clunks!
          only sounds now are turbo whistle,compressor surge, flame popping and tire squealing:)
          7speedshop.com
          • 4ce30
            • Feb 2006
            • 2762
            #695
            Wow!! You have built Such a nice car, I really enjoyed the progress. Wish my drift car was on this level, I could do some damage!
            • kamotors
              • Nov 2007
              • 7102
              #696
              added a bit of bling,
              gold colored fender flare washers:)
              7speedshop.com
              • ak-
                • 12422
                #697
                I've been trying to figure out that bumper beam weight loss for a long time and can't get the bolts off! They spin.
                Is your check valve in the downpipe?
                1991 325iS turbo
                • kamotors
                  • Nov 2007
                  • 7102
                  #698
                  the bolts have a nut on the back, its 13mm I believe and the front is the torx.
                  Yes the check valve it the gold thing right on top of the downpipe, that then goes to the catchcan and then to the valve cover. it goes from a nice big 1" hose down to 5/8 for the scavenge system.
                  7speedshop.com
                  • yert315
                    • 2734
                    #699
                    468hp!? That, my friend, is what's up!
                    • sayed ali
                      • 762
                      #700
                      Awesome!
                      M20B28 Turbo
                      My Build Thread
                      http://www.r3vlimited.com/board/showthread.php?t=255839
                      • csermonet47
                        • Jul 2009
                        • 937
                        #701
                        In for some rolling burnout videos ...
                        Are Three Vee
                        Dad Spec
                        • jhaurimn
                          • Nov 2012
                          • 2224
                          #702
                          I was just reading earlier on in this thread when you were saying you would start at 200 or so hp and work your way up. That's quite impressive!
                          Current:
                          1989 325i
                          1988 M3
                          1987 325ic
                          Past:
                          2001 330ci
                          2001 M3
                          • Sagaris
                            • Sep 2009
                            • 2243
                            #703
                            I cant remember seeing an update with cam/headwork.
                            This is all on a stock 885 head and 2.5 bottom end, right?
                            Im definitely amazed either way
                            • kamotors
                              • Nov 2007
                              • 7102
                              #704
                              this is all on 100% stock motor with headstuds:)
                              7speedshop.com
                              • Vivek
                                attention whore/retard/bitch
                                • 6167
                                #705
                                Holy shit. And this is on a 22 year old head gasket. M20 FTW
                                1992 Mauritiusblau Vert
                                2011 Alpinweiss 335is coupe
                                2002 540i/6 Black/Black
                                2003 GSX-R 750 (RIP)
