Kamotors E30-Turbo to ITB M20
  • kamotors
    • Nov 2007
    • 7102
    #766
    yes manifold will be black one I'm done
    7speedshop.com
    • acolella76
      • 2950
      #767
      Any benefit to putting the meth injection in the manifold vs where you had it before?
      -Alex
      • twolitresix
        • Jan 2013
        • 21
        #768
        Originally posted by kamotors
        have all the parts ordered to get the car running again just waiting now :)
        will be injecting meth into the manifold now.
        Are your sure that this is a good point to inject? You are injecting your w/a against the manifolds airflow direction, i have a feeling that it wouldn't be distributed very well, most going into #1&6
        • kamotors
          • Nov 2007
          • 7102
          #769
          its a 250psi pump and should get the job done fine.
          7speedshop.com
          • kamotors
            • Nov 2007
            • 7102
            #770
            SO I decided to run a vac port instead of my methanol at that location after further research and discovered my turbosmart wastegate had a bad seal and the valve does not even open more than a crack lol. I was wondering why the wastegate was soo quiet, it was basically a boost leak controlled by my boost controller
            7speedshop.com
            • u3b3rg33k
              • Jan 2010
              • 2452
              #771
              So you are going to put in a second "fuel" rail?
              Ich gehöre nicht zur Baader-Meinhof Gruppe
              Originally posted by Top Gear
              Just imagine waking up and remembering you're Mexican.
              Every time you buy a car with DSC/ESC, Jesus kills a baby seal. With a kitten.
              • kamotors
                • Nov 2007
                • 7102
                #772
                no just going to run it as it was before with just a pre throttle injector
                7speedshop.com
                • kamotors
                  • Nov 2007
                  • 7102
                  #773
                  found a cool callaway meth injection diagram for the e21, just thought I would share although its kinda irrelevant.
                  7speedshop.com
                  • ak-
                    • 12422
                    #774
                    Did they use draw thru? Injected pre turbo? Wat
                    1991 325iS turbo
                    • ak-
                      • 12422
                      #775
                      Why is there an H20 bung before the compressor inlet?
                      1991 325iS turbo
                      • TheTacoMan
                        • Nov 2011
                        • 2308
                        #776
                        Water cooled turbo I would assume.
                        • travish325
                          • Jun 2012
                          • 1151
                          #777
                          extra cooling?
                          • ak-
                            • 12422
                            #778
                            Water cooling the turbo in which the water makes it into the intake system lol?
                            Originally posted by travish325
                            extra cooling?
                            Water/meth going through the compressor wheel?
                            How do you/can you regulate that? o.O
                            1991 325iS turbo
                            • kamotors
                              • Nov 2007
                              • 7102
                              #779
                              pre turbo water injection has been around for a while, saab used to do it on the 99 turbo i believe. It can make the compressor housing "feel" larger as well as cooling the intake charge.
                              great to do if you have money to replace turbos
                              "One reason for someone to inject at this location is the water/methanol mixture chemically alters the turbo compressor map. The water/methanol injection will dynamically shifts the compressor map of the turbo so that it has the compressor map exhibits the characteristics of a larger turbo. This sounds great but, the main issue with pre-turbo nozzle placement is what mixture can damage the compressor blade if the mixture is not properly atomized when passing through the turbo."
                              7speedshop.com
                              • ak-
                                • 12422
                                #780
                                Learned something new.
                                Guessing it's old tech then.
                                1991 325iS turbo
