316 superlite
  • Skarpa
    • Jan 2013
    • 495
    #226
    Originally posted by petrolhead
    If I bolt on a part per day... How many parts are there to an E30?
    Can't tell you the number of the parts but you have twelve weeks and there are 24 part categories. You need to finish at average of two categories per week. (Although you are well on the way in some categories)
    Engine
    Engine Electrical System
    Fuel Preparation system
    Fuel Supply
    Radiator
    Exhaust System
    Cluctch
    Manual Transmission
    Gearshift
    Drive Shaft
    Front Axle
    Steering
    Rear Axle
    Brakes
    Pedals
    Wheels
    Bodywork
    Vehicle trim
    Seats
    Vehicle Electrical system
    Instrumets, Measuring systems
    Lighting
    Heater and Air Conditioning
    Restraint system and accessories
    E30 Armo "330i"
    • petrolhead
      • 421
      #227
      I bonded the windscreen on
      Continued fiddling with the wiring
      • petrolhead
        • 421
        #228
        Repairing the wiring harness/deleting useless bits, adding/modding new stuff..
        I had 3 rear screens in storage, put the lightest one to the car..
        • Skarpa
          • Jan 2013
          • 495
          #229
          That's dedication to weight loss :P I wouldn't have thought about the weight differences of glasses.
          E30 Armo "330i"
          • totheredline
            • Jun 2013
            • 762
            #230
            This thing would be badass with an aluminum M52 with m54b30 rotating assembly... 240hp in that thing. Mmm.
            Sent from my XT1585 using Tapatalk
            = Heidi 1988 325 -> 335i. 7200rpm built M30
            • petrolhead
              • 421
              #231
              That's just something I can do right now with zero cost. Applies to all parts that I have several of, in store. You'd be surprised at weight differences between two cast metal parts with the same part number.
              Stuff starts adding up when you have a reaaally long list of small weight savings.
              • petrolhead
                • 421
                #232
                That weighs more than my current setup, does not bolt on to a similarly nice close ratio box, and I can achieve my targets with the current lump.
                If "more power" is the essence of BMW building, every E30 should have a turbo'd S70/2 :).
                That said, I HAVE tested a 940kg E30 with ~240 hp M50 or 52 I forget. Anyway, it had slicks and all that racing stuff. YES it went like stink.
                • Bearmw
                  • 1323
                  #233
                  Keep it coming man. I love this build. The scale is my friend too.
                  • Kershaw
                    • 11822
                    #234
                    What were the weights of the other two rear windshields? How much did you actually save?
                    AWD > RWD
                    • petrolhead
                      • 421
                      #235
                      The one with factory tint was 6,8xx kg, other two were ~0,3 and 0,4 kg lighter than that. Ofcourse, change to Lexan and save several kilos..
                      • Kershaw
                        • 11822
                        #236
                        With this dedication to extreme weight savings, I hope you're under 72kg or it's going to look very silly. :rofl:
                        AWD > RWD
                        • petrolhead
                          • 421
                          #237
                          A 6 feet 2" tall guy close to 40, weighing 72kg.. Now that would look stupid :D
                          • petrolhead
                            • 421
                            #238
                            Quite stiff engine mounts, 5,90€ a piece
                            Lambda's route to the prop shaft tunnel
                            Wiring sets are quite a lot thinner than stock.
                            • petrolhead
                              • 421
                              #239
                              All fog lights, switches, and their wiring deleted
                              ..as was the rear window defogger:
                              Dashboard collides with the modified windscreen frame. I can live with that and come up with a clever solution come winter.
                              1984 front lip doesn't fit the 1985-> front valance.
                              Rest of the brake stuff installed and made to fit eachother, brake bleeding done (I think).
                              • 2mAn
                                SeƱior Mod
                                • 21062
                                #240
                                Im loving this build. The color has really grown on me too. Hope you hit all your goals
                                Simon
                                Current Cars:
                                -1966 Blue Boat
                                -1969 Red VW
                                -1986 White BMW
                                -2006 Green Thing
                                Make R3V Great Again -2020
