My Chalkboard E30 Project
  • Neil1138
    • 527
    I have a progress thread going on e46f but it's only fitting that I migrate it over to r3v. This is going to be my new progress thread
    I present my 1990 bmw 325i that I found listed on craigslist for $600. I hesitated and watched the listing for a couple of days. It dropped to $400 and that was just too cheap to pass up.
    Overall, the car is fairly sound. Strong motor and transmission, the body panels are all straight except the drivers door and part of the fender. Unfortunately the paint on the car was completely shot. Definitely needed a repaint
    When I bought it, the owner told me that the master cylinder was bad and there wasn't one in the car. He showed me 3 used (presumably broken) master cylinders in the trunk and there was a new one in a box. Since we thought it had no master cylinder (wouldn't go into gear), we towed the car home. Yes I could have driven it with no clutch but there were no brakes (no brake fluid). But to our surprise, there was already a good master cylinder in place and the car was just low on brake fluid. Topped it off and the car and the clutch feel great. Owner fail
    The front shocks need to be replaced, some shift linkage parts, a new tire among other small items. The car sat outside for nearly a year (with gas in the tank) so we are worried that the gas tank might have rust in it. (it actually does have rust in it, fack)
    Photos day of purchase:
    Start:
    I have pulled the entire interior, thrown away the crap seats and door panels. I removed and cleaned the front carpet, which got dyed black. The seats were replaced with black sports seats that are in exceptional condition and I have some black door panels to put in there as well.
    Pulling the interior
    the carpet was friggin nasty. Took it to a carwash and pressure washed the hell out of it, win
    ready to scrub the inside down and start taping off
    Prepping for the ghetto yet legit-ish paint job. If I was for srs, I would grab some paint stripper and take it down to the sheet metal but that's too messy
    First round of sanding off the clear coat which had failed...
    getting missed spots w/ an extra pad
    taking out all of the clear coat where it had started peeling off
    second round
    The paint is completely smooth now ftw. Oh and teh paint
    continued...
  • Neil1138
    • 527
    Moar sanding then some bondo work on the drivers door. We cleaned the car with mineral spirits and taped it off for primer.
    Legit spray booth is legit
    win
    First coat of primer, it's k. I went back and got the overspray/dust off and touched up some rough areas. Primer doesn't need to look purdy, it just has to be there for the paint to stick.
    Chalkboard paint ftw! You can call it matte maroon if that makes it nicer
    first coat of paint:
    oh and teh new door panels
    Second/third/fourth coat of paint was laid down
    Final coat of paint, baking in the sun
    • Neil1138
      • 527
      Unmasked and teh tints! I switched out my windows for grants tinted ones. We had to swap out the window regulators but it was worth it
      Swapping the rear glass
      Clean underneath the trash. Interior going in
      moar carpet dyeing brought to you by neil1138
      grant's sexy turbo e28
      moar!
      Dyeing under the seat? Nahhhhhh
      assembling interior bits
      Dye everything!
      Roommate's M50 E30
      Will continue soon
      • Thrizzle
        • Aug 2011
        • 194
        That is pretty sick, paint came out looking great!
        Sick project.
        • Dj Buttchug
          • Jun 2010
          • 7686
          one of the sweetest cars here on r3v.
          Turbo M42 Build Thread :Here
          Ig:ryno_pzk
          I like the tuna here.
          Originally posted by lambo
          • AsharC
            • Jun 2011
            • 1508
            I spy my e28 in the background :)
            BUY MY WHEELS! BBS E50s!!
            http://www.r3vlimited.com/board/showthread.php?t=275407
            Originally posted by Lurker27
            Any man will tell you being blown is better than being stroked.
            • Neil1138
              • 527
              Sick project.
              Thanks guys!
              Clean and ready for priming
              Priming the chalkboard paint... I'll explain later
              omnomnom
              giggity
              Instructions called for "priming" or covering the entire surface in chalk and then wiping it off. It made the surface nice and smooth, probably by filling the pores with chalk dust.
              Wiping down after the chalk priming with a slightly damp microfiber
              We tore into the motor. Replaced the timing belt (which we discovered was alright), waterpump, valve cover gasket and other little pieces. Still need to tear into the fuel tank.
              • catuned
                • Jun 2011
                • 2324
                Very cool!
                Work We Do
                CAtuned Feedback Page|FB CAtuned Page
                http://www.catuned.com
                • Deltron Dirty30
                  • 2436
                  wow this thread is very #based. I need more up close pics of that interior though haha. Great job with everything.
                  Instagram: @jstnlws
                  • Keith M
                    • 2338
                    I love the chalkboard car. Saved a picture of it with my name visible.
                    • Neil1138
                      • 527
                      Drained the fuel tank... wow. The tank was toast so it had to come out.
                      had to remove the heat shields, driveshaft and stupid fuel lines that pour fuel everywhere. Finally got it out though!
                      new fuel tank. $75 and rust free!
                      almost there!
                      More photos and close ups of the writing are here: http://www.flickr.com/photos/derref/...7624843913966/
                      I did park it outside during a football game... that was a bad idea. Whoever said random people writing on it would be better...
                      <3
                      • 1mz
                        • Jan 2009
                        • 641
                        that is awesome man - keep it up! what other plans do you have for it?
                        http://l0st0n3.mybrute.com
                        http://l0st-0n3.mybrute.com
                        Work in progress: 1991 318i m50 swap
                        Feedback thread :up:
                        I prefer having a female in the car at all times. They generally smell good, but you do have to put up with that hole in their face.
                        • Neil1138
                          • 527
                          Diff bushings, subframe bushings, oil housing gasket and oil pan gasket. What a pain.
                          Pulled the entire rear subframe out.
                          Torches to burn the bushings out and wood clamps to put them back in
                          The underside of this car is absolutely filthy.
                          Cork gasket, new to me.
                          Replaced the front bumper and repainted it. I've replaced the front valence which was bent and put the stock lip on it.
                          This is how she currently sits:
                          Chalkboard paint would look pretty good with clear coat :eeps:
                          • Neil1138
                            • 527
                            Currently I'm awaiting a gc coilover setup, should be here soon. Also I had a set of E38 style 5s filled and redrilled. Just trying to piece the car together for the new look!
                            • GOT8SPD
                              • 270
                              Super cool and original. Keep it up buddy!
