Originally posted by Exodus_2pt0
View Post
'91 318is, 16V swap.
Originally posted by JasonC View PostMine was like that cause they put cold water in the hot engine, and then warped the heads. Then left it sit for a few years.
New engine is in, so time for new gaskets.
What I'm starting with: 1991 5.0 Ho, bored to a 306. Forged pistons, cam'd(not sure of kind, but very lopey), aluminum rocker arms, aluminum valve covers, ARP head bolts and intake bolts, and Weiand single plain intake( for sale if anybody is interested) mated to the old T5 trans via a Center Force stage 2 clutch and flywheel.
The nice intake bolts, going to clean/ shine these up.
Intake off, looks very clean! And thankfully the gasket mating surface was pretty clean and smooth still.
Oh look, non rusty water passage ways!
Valve cover off, aren't the arms beautiful?
And my temp office for cleaning/ breaking down.
Originally posted by lolcantturn View PostDoing work
Also, to anyone attempting the swap, 2 things:
1. Make your core support removable. It will make getting the engine and trans
in together so so so much easier.
2. Cut off your csb mounts from the get go. I'm using a 3" driveshaft and it was very close even before this current issue. So save yourself the headache and just chop em.
Originally posted by FunfGan View PostI'm just taking my time with it now haha, no need to rush.
4. Don't do the swap in the first place. Jk.sigpic
1989 Alpine 325is 2dr m50 swapped
Build Thread:
Current ongoing build. Check it out!
1991 318is 4dr rallycross
Rallycross Build Thread.
1991 Alpine 318is coupe - sold
Also... polish up those valve cover gaskets real well. :Dsigpic
Build Thread:
Originally posted by shEck3lls0 View PostAlso... polish up those valve cover gaskets real well. :D
Well, I need some super high grit sand paper to do them properly at some point.
Originally posted by LJ851 View Post5) Dont leave this motor out in the rain.
Didn't you see the pic? The engine was totally fine. Turns out the clutch/ pressure plate had kinda, well just broke.
Actually somebody called that before you :)
Either way, we knew it was clutch stuff before I bought the new engine haha, just wanted a clean slate.Last edited by FunfGan; 07-09-2012, 08:31 PM.
Originally posted by FunfGan View PostActually somebody called that before you :)
Either way, we knew it was clutch stuff before I bought the engine haha.
