'91 318is, 16V swap.
  • FunfGan
    • Jan 2011
    • 4958
    #886
    Originally posted by KamakaziX
    When you paint tire letters, show us how you do it. Imma do it too k?
    Originally posted by LJ851
    Make a stencil and spray or hand paint with brush or paint pen. It's not rocket science.
    Wheels are off till summer haha, so probably not happening for a while.
    Also, car will probably not be driving till summer. Long story, lots of work being done including engine rebuild and switching to EFI.
    Go here be happy!
    Ratchet Garage e30 V8 build.
    • KamakaziX
      • 2041
      #887
      Originally posted by lj851
      make a stencil and spray or hand paint with brush or paint pen. It's not rocket science.
      k
      Originally posted by lambo
      Fuck studying. Party hard.
      • eurotrash
        • May 2007
        • 768
        #888
        Originally posted by Exodus_2pt0
        I want to like the exhaust, but man it kind of ruins it!
        Have you considered a rear exit? There's something sexy about a big engine with a tamed exhaust note. Then again, if you simply love loud, then carry on. :pimp:
        If you only knew how much $ and work that takes.
        • twolitresix
          • Jan 2013
          • 21
          #889
          As a German i should hate what you have done to one of our beautiful be-äm-we's, but i love it! Enough to start looking for 5.0's, but theyre extremely expensive here... Wait, can i use that one?: :hitler:
          Have you ever put the Car on scales? Would be really interesting with all the weight distribution discussion going on for there swaps.
          Yes please. Going to stock ford EFI, or megasquirt?
          • FunfGan
            • Jan 2011
            • 4958
            #890
            Awwww yeaaaaaaah ;) Glad to hear :) No sorry sir, this one is mine!
            Well, by my calculation, the swap weighs about 50 or so pounds heavier than an m50/ g260 combo with all accessories, and aluminum heads drop ~80lbs, so... I am very excited to finally get it on the scales at some point, though.
            For now, stock EFI, but Megasquirt is most definitely in the plans.
            Go here be happy!
            • ballski
              • Jun 2012
              • 345
              #891
              did you have the tranny already on the motor when you dropped it in? Or are the bolts accessible after the motor is in to put it on afterwards?
              Current Moneypits: e36 m3/4/5 Turbo Techno
              1961 Cadillac deVille bagged -
              IG @bryang513
              • Exodus_2pt0
                • 5943
                #892
                Because doing the 5.0 swap requires so little work anyway, right?
                No E30 Club
                • Exodus_2pt0
                  • 5943
                  #893
                  If you need any help in that department hit me up. I just finished my MS box the other day. Of course I now have to change some things to run the 5.0 motor, but either way hit me up if you need anything!
                  No E30 Club
                  • lambo
                    Captain Scene Points
                    • 10953
                    #894
                    Thought of you when I watched this <3
                    • shEck3lls0
                      • Jan 2011
                      • 1154
                      #895
                      Dude. prefect.
                      1989 Alpine 325is 2dr m50 swapped
                      Build Thread:
                      Current ongoing build. Check it out!
                      1991 318is 4dr rallycross
                      Rallycross Build Thread.
                      1991 Alpine 318is coupe - sold
                      • hfabricius
                        • 608
                        #896
                        I wanted to hate this car but its so damn outrageous that I couldn't bring myself to it.
                        http://halden-fabricius.tumblr.com/
                        • eurotrash
                          • May 2007
                          • 768
                          #897
                          Honestly the 5.0 swap is as easy as swapping an oe engine. Mounts are all fabbed for you. The pan is fabbed for you. The driveline is fabbed for you. All you gotta do is drop it in and rewire. The exhaust is a bitch to keep everything up and to snake it through if you keep mandrel bends. Ive got 2.5 -3" and it was a bitch to get it past the engine, subframe, starter, and frame.
                          • Exodus_2pt0
                            • 5943
                            #898
                            I see a market for a 5.0 exhaust kit.....
                            Hmmmmm....
                            No E30 Club
                            • eurotrash
                              • May 2007
                              • 768
                              #899
                              Thered be a better market for an e30 5.0 header that didnt require removing the steering shaft to get it out.
                              • Exodus_2pt0
                                • 5943
                                #900
                                Interesting. Is the clearance an issue only when mounting it in the original orientation? I was under the impression that most people mounted the headers backwards. The motor I have already has a good set of shorties on it.
                                I'm about to do the swap, so I am soaking up as much information as I can beforehand.
                                No E30 Club
