91' 318is S52 Swap "The Beast"
  • craiggroves91
    • Oct 2009
    • 3024
    #661
    Originally posted by pandaboo911
    Front is still 400lb spring / Koni SA (ix)
    Meant to say DA is not worth it for comp. adjustment.
    I have 550lb spring, which I'm hoping helps a little with the added 24v weight.
    I went with the g60 corrado 1198 sports, which are probably very similar to the IX Koni SAs.
    What is up with your car lately? Last I heard it was supercharged.
    1989 BMW 325i SOLD
    1998 BMW Estoril Blue e36 M3/4/5 SOLD
    1987 BMW 325 (The Piece) SOLD
    1991 BMW 318is S52 swap (The Beast) Now Driving Project Thread: http://www.r3vlimited.com/board/showthread.php?t=234207
    • pandaboo911
      • 2070
      #662
      The corrado shocks are the same length, but the iX inserts are made to fit the e30 strut tube.
      It was supercharged, but having to find E85 all the time and some drivability issues changed my mind about it. Reverted back to NA.
      I might do another FI build after I graduate. Most of time right now is dedicated to fixing a Lemons car and keeping my 735i running.
      • 2mAn
        Señior Mod
        • 20997
        #663
        I also have the 1198 Sport, paired with the Ground Control raised mounts in the back and IE3 springs (550#). I love the setup. I still need to go back through the front as the Bilsteins feel tired. Im probably doing the iX up front too.
        Simon
        Current Cars:
        -1966 Blue Boat
        -1969 Red VW
        -1986 White BMW
        -2006 Green Thing
        Make R3V Great Again -2020
        • craiggroves91
          • Oct 2009
          • 3024
          #664
          Sweet! Ix or g60 up front seem like the way to go. I chose g60 because I got a good deal on them.
          Sent from my SM-N920V using Tapatalk
          1989 BMW 325i SOLD
          • craiggroves91
            • Oct 2009
            • 3024
            #665
            So I need stock e30 strut collar nuts? Silly me didn't realize I have bilstein HDs from PO in now so the strut nuts I have won't work with Konis.
            1989 BMW 325i SOLD
            • varg
              Florida Turbo Man
              • May 2014
              • 3425
              #666
              Stock nuts worked fine with my Koni SAs
              IG @turbovarg
              '91 318is, M20 turbo
              • craiggroves91
                • Oct 2009
                • 3024
                #667
                Okay, I have to get my hands on some stock nuts them.
                Have poly rtabs and posi lock toe and camber correction kit from Ireland engineering on the way.
                1989 BMW 325i SOLD
                • craiggroves91
                  • Oct 2009
                  • 3024
                  #668
                  Okay gang, so I have e36 m3 struts laying around with swaybar endlinks. Shouldn't I be able to cut that mounting bracket off and weld it into my strut housing and run the e36 m3 endlinks?
                  1989 BMW 325i SOLD
                  • craiggroves91
                    • Oct 2009
                    • 3024
                    #669
                    Seems like it should work? Not correct orientation, just testing.
                    1989 BMW 325i SOLD
                    • craiggroves91
                      • Oct 2009
                      • 3024
                      #670
                      Cut the e36 m3 endlinks in half and threaded them. Just need a coupling and jam nuts now
                      1989 BMW 325i SOLD
                      • craiggroves91
                        • Oct 2009
                        • 3024
                        #671
                        More parts rolling in. Got poly rear trailing arm bushings from Ireland engineering.
                        I also cut the other swaybar endlink bracket off the e36 m3 strut. I cut the right one off differently and it came off in better shape, but they are both good enough to weld on.
                        1989 BMW 325i SOLD
                        • kronus
                          • Apr 2008
                          • 13032
                          #672
                          sure, e36 tabs will work fine, but AKG ones at $15 and you don't lose a pair of strut housings..
                          good idea on threading the end links.
                          cars beep boop
                          • craiggroves91
                            • Oct 2009
                            • 3024
                            #673
                            The struts were blown to smithereens. I had them laying around still from my e36 m3 which had gc coilovers. Figured I might as well hack them up.
                            Thanks, I'm just waiting on someone to make me coupler nuts. We chose an odd thread, but the correct thread for the diameter. So a fabricator is making me a coupler out of hex stock.
                            1989 BMW 325i SOLD
                            • craiggroves91
                              • Oct 2009
                              • 3024
                              #674
                              Finally got the collar nuts so I was able to cut the sleeves and spacers to the right length and assemble everything for the front suspension. It was a pain in the ass getting the length of the sleeves right I had to keep shaving them down.
                              Before shaving
                              Done
                              I've been waiting years to see this. I've had the springs and strut housings for about 4 years!
                              1989 BMW 325i SOLD
                              • 2mAn
                                Señior Mod
                                • 20997
                                #675
                                looks good Craig (its Craig, yes?)
                                did you source everything separate?
                                Simon
                                Current Cars:
                                -1966 Blue Boat
                                -1969 Red VW
                                -1986 White BMW
                                -2006 Green Thing
