E46 M3 cluster swap
    • 34839
    #46
    started populating the board on saturday:
    relocated the offending cap:
    hardwiring the fuel gauge ADC's to my op-amp:
    fits inside the E30 housing a bit better now:
    :D
    • Jand3rson
      • 37587
      #47
      Excellent work, Chris! Can't wait to see it in person.
      • Wh33lhop
        • 11705
        #48
        I haven't checked this thread in awhile and come back and you've got boards made up... awesome stuff man!
        Your "breadboard" on the previous page isn't too bad actually, I am usually really neat when it comes to breadboarding stuff out but a surprising amount of prototypes are suuuper messy. My 50 year old coworker was telling me about when he was first getting into it he wouldn't even use a board, he would just have a ball of a circuit with the ICs at the core :p functioned fine though and that's all that matters.
        paint sucks
        • george graves
          • 19996
          #49
          Good work - Really nice job. Hats off Nando - I'm sure Luke will be PM'ing you to do some circuit work now!
          Just a suggestion or two. For "green wire fixes" you'll want 30 gauge wire. And tack it down with run-of-the-mill walmart 5 min xpoxy (don't use hot glue - the inside of a dash can be 235 degrees, it will sag. - you can use silcone if it's low on acid))
          The old cap thing - that actually has a long twisted story behind it. Mostly 90's caps. I'll try to dig it up - it's a good read.
          Wheelhop - yes, it's called a "dead bug" - Since most parts go to ground, you just pull out some copper clad board and start soldering - you a copper clad spacer to join parts. Crazy.
          It's old school - and nasty. No one uses it anymore. The only guys that use it are old-school RF and Ham radio guys over 70. ;)
          Let me know what op-amp your using - oh, and if you need a suggestion to laser cut face plate. Glad to help - if I can.
          Originally posted by Matt-B
            • 34839
            #50
            Laser cut, hadn't thought of that.. Good idea! I just need to make a pattern somehow..
            • James Crivellone
              Head Janitor
              • 6304
              #51
              Chris,
              Not that I need another project, but if you make more of those I'd be interested to tinker with them. I don't have any real application, but the thought of grabbing an MSS54 + Cluster and having it all work just stimulates my inner nerd..ism
                • 34839
                #52
                I've got two more boards. I'd like to fully vet them before doing anything with the extras.. I'm sure I'll find changes here and there.
                george, I'm using this op-amp:
                I didn't pick it for any specific reason, other than it had a single output and met my package size. I also chose it before I realized I'd needed two (but I bought a spare just in case).
                • Wh33lhop
                  • 11705
                  #53
                  Dead bugging is just flipping an IC upside down... I mean straight-up no organization, no board, no ground plane, just an IC or two and a bunch of wires. :p
                  paint sucks
                  • James Crivellone
                    Head Janitor
                    • 6304
                    #54
                    No biggie.. My only idea would be to install it on the e30 simulator. i've been after a 9000rpm tach and this is a great way to get one!
                    • delatlanta1281
                      Dart Master
                      • Mar 2006
                      • 10317
                      #55
                      Oh god. I am failing at so much right now. Great work so far!
                      Yours truly,
                      Rich
                      you kids get off my lawn.....
                        • 34839
                        #56
                        I redid the "patch" for the ADC inputs. cut the +5v trace for one of the level sensor inputs and ran it to there, so I don't have to worry about pulling the ADC traces off the board. I still have the 5v input to my adapter ran straight to the traces of the cluster, though..
                        just waiting for the rest of the parts.
                        on a tangent - anyone ever buy a brand new coding plug or have a newer one laying around?
                          • 34839
                          #57
                          I've got another stumper: looking for the connector for the oil level sensor. it's not a regular Amp 3-pin minitimer. Sensor looks like this:
                          ideas? I've searched for 3-pin amp connectors and I don't see anything that matches.
                          • FredK
                            • 14761
                            #58
                            ah, I'll try and read the AMP PN off my engine harness tomorrow.
                              • 34839
                              #59
                              that'd be sweet :)
                              BTW: anyone else going down this path.. just buy an S54 harness. it would have been cheaper. :(
                              • James Crivellone
                                Head Janitor
                                • 6304
                                #60
                                It somewhat looks like those plugs that GM uses all over the enginebay on the last 20 years of cars
