Seeking Sage Wisdom for 325e
  • illest318i
    • 1472
    #46
    Great purchase man!!
    And don't tuck the bumpers get a swap instead..
    IG: @_j.wn
    • Bearmw
      • 1323
      #47
      Lighing upgrades are great bang for your buck. Start with headlights; maybe H1/H4. Can also make your rear lights brighter (search). Interoir lighting can also be improved.
      For performance I would simply do the chip and a 3.25 diff and then do some mild suspension mods without dropping it much. I would also probably go with euroweaves with a decent 205 width tire.
      You have a nice blank canvas but I would enjoy the torque and economy of a mostly stock Eta. I would consider reinforcing certain structural areas such as door hinge, trailing arm sway bar attachment, and so on. Also do some preventative maintenance and address areas that tend to rust on our cars over time such as around the license plate lights, the fuel line cover in the RR wheel well, and make sure all body drains function perfectly, etc.
      I would do a few body cosmetic mods last.
      Have fun.
      • DaButt
        • 476
        #48
        Are all the diffs available for e30s direct replacement parts?? I see the 3.25 recommended a lot. Is there a DIY write-up for diff swapping?
        /______\_o_/______\
        l{(OO)=[//][\\]=(OO)}|
        \ #___======___# /
        |__/-------------\__|
        "Took me an hour to do this..."
        took me like three seconds to copy/paste it- FOR SCIENCE!!
        Barney Fucking Rubble
        • ForcedFirebird
          • Feb 2007
          • 8300
          #49
          It's pretty self-explanatory. Remove yoke bolts, remove axle bolts, remove diff-to-subframe bolts, remove diff bushing bolt, installation is reverse.
          john@m20guru.com
          Links:
          • Teaguer
            • Sep 2004
            • 6167
            #50
            This is tru of most e30 diffs but the 3.25 is from an e28 or e24.
            This will require the additional steps of swapping the cover and stub axles over from the e30 diff.
            • ForcedFirebird
              • Feb 2007
              • 8300
              #51
              True. I was assuming he would be buying one from the forums since he's shopping for bumpers here as well.
              john@m20guru.com
              Links:
              • DaButt
                • 476
                #52
                So in the interest of simplicity, I should stick with an e30 LSD.... which are direct replacement parts.... ??
                /______\_o_/______\
                \ #___======___# /
                • Teaguer
                  • Sep 2004
                  • 6167
                  #53
                  Its just as easy ...just not unbolt and bolt in the new one.
                  The cover and stub axles can be swapped over from your current diff. Easy as pie.
                  With an Eta the onle Eta available ratios are the 2.79 and the 2.93 so anything else from an e3o will be too short of a gear.
                  The 3.25 is a great ratio and is about the shortest you want while still having an Eta valvetrain.
                  • dogsbark26
                    • Nov 2008
                    • 533
                    #54
                    Funny, everyone (including you) seems to be ignoring those pesky check panel lights. Those seem like a great way to get to know your car better. Start with, say, the washer fluid one. It's just a simple circuit. Either a wire is cut/disconnected or the sensor in the tank is hung up or faulty. Easy fix.
                    Which brake lights warning is on? On the check panel or in the cluster?
                    Try removing the brake light bulbs and cleaning the contacts then reinstalling.
                    • BoostinEuros
                      • 363
                      #55
                      Very nice car! It's in beautiful condition. What area of west Georgia are you in? I'm a west Georgian myself!
                      '91 "318is" slick top M50 turbo
                      '97 Dodge 3500 12v Cummins
                      '12 Mini Cooper S
                      '89 318i Chump Car Project
                      • ForcedFirebird
                        • Feb 2007
                        • 8300
                        #56
                        +1
                        More than once, I found myself putting the reverse bulb in the rear driving light spot to get home after the check panel illuminated.
                        john@m20guru.com
                        Links:
                        • DaButt
                          • 476
                          #57
                          I'm with you. I'm generally not the type to "ignore" things the car is telling me. But sometimes it's a legitimate hypochondriac. Like the Check Brake Lights (on the check panel). The maintenance folder I have goes back to the original owner in 84. It's been a problem since then. They've replaced just about everything on that joker that has to do with the check panel, and it always came back on a little while later. When I press the brake pedal or go revers, the brake lights come on, that's what I need it to do.
                          I'm ultimately more concerned about the engine, tranny, cooling system, etc. on this car.
                          What catches my eye is how the woman who owned it brought it in time and again with the "brake lights" check panel problem, and at least once there is documentation of the "owner declining the timing belt and water pump replacement, despite being warned of the potential consequences.
                          So if you see these two things in your car, you have to prioritize, the check panel light's not going to cannibalize the car, a failed timing belt may very well do so. Hence, my priorities are/were: 1. major points of failure
                          2. Everything else.
                          It's a 27 year old car, the computer's not going to be perfect, and I'm ok with that.
                          **Edit: After reading my post, it sounds a little flippant. Not my intention. I DO appreciate the advice, but I was just trying to share my train of thought with the group.
                          *** 2ND Edit- And I did pull a washer fluid res. and the sensor- replaced and sensor is functioning! Saved me money. Love it.
                          /______\_o_/______\
                          \ #___======___# /
                          • DaButt
                            • 476
                            #58
                            So... failure.
                            I'm sad to report that I excitedly attempted to put my TMS chip in last night, only to discover the old one was soldered in. When I reassembled everything, put the DME back inot the car, no start. (Yes I re-connected the battery), the starter was going all day long, but no spark or fuel (that I could hear)...
                            I'm thinking of getting charger and trickle charging the battery, but it still bugs me... what would make my battery go like that? I didn't have the interior lights on while I was doing any of this. I disconnected the batt, took the DME inside, reassembled the DME, put it in, then splat... why would it do that?
                            /______\_o_/______\
                            \ #___======___# /
                            • DaButt
                              • 476
                              #59
                              come on, someone help a brother out!
                              /______\_o_/______\
                              \ #___======___# /
                              • frankenbeemer
                                • Sep 2009
                                • 2260
                                #60
                                Is your battery dead? I'm not sure what you are asking.
                                Don't buy an e30
                                They're stupid
                                1989 325is Raged on then sold.
                                1988 325 SETA 2DR Beaten to death, then parted.
                                1988 325 SETA 4DR Parted.
                                1990 325i Cabrio Daily'd, then stored 2 yrs ago.
