awesome car, you have great taste (red leather/black car). sub'd for sure
'90 325i Project Log
picked up the adapters for the turbine setup today.
18mm 4x100 > 5x120s.
will be doing a test fit without tires to assess how much space i'm working with and figure sizes out. hoping i can get 215s on the 8s and 235s on the 9s and still have clearance.
as a side note, an adapter setup like the one pictured above can be purchased via the link in my sig below. ;)
did some test-fitting yesterday, i couldn't wait any longer after i got my hands on the adapters. :)
here's a step by step of the installation process first:
install the kidney-shaped adapter plate. tighten it enough that it stays in place, but can still pop into place in the back side of the adapter body - once it's lined up, torque it down.
once you fit the adapter body on top of the kidney-shaped piece, bolt them together with the two supplied counter-sunk bolts.
affix the rest of the adapter to the hub via the supplied lug bolts.
mount the wheel and bolt it down via the supplied lug nuts.
the results.
the fender clearance - pretty much where i thought it would be, very close to where my old RSs sat - gonna have to do some more thinking re: tires.
p.s. wheels are 17x8 et20 F and 17x9 et22 R, 18mm adapters all around.
Cool! My goal is to be running the exact same setup w. throwing stars
1983 Peugeot 505 STI
1992 Volvo 240 Wagon
Originally posted by csermonet47 View PostLooks great! Those adapters look like a great design. Looking forward to seeing it all buttoned up.
Originally posted by freeride53 View PostCool! My goal is to be running the exact same setup w. throwing stars
Originally posted by bmwsone01 View PostThat interior...is perfect!
What size tires will you be running?
Originally posted by MattAvino View PostI very much enjoyed viewing your vehicle.
o man - i test fitted my turbines for a day -green doesn't look right but one day I'll run them on the e30 in a gray or white.. RUDE! Can't wait to see you dial them in!
91 DS S52 Slicktop, 91 Calypso M42, 89 Royalblau M20, 84 Bahama Beige 323i, M535, Euro e24, ap1
www.RenownUSA.com
ig @RenownUSA / @rude.scott
Originally posted by animal View PostCan't wait to see you dial them in!
i've been looking through my turbine folder for inspiration and i'm leaning towards having the centers sprayed as well, so the whole thing is OEM silver - i like the look when the naked wheels are all one color...
