89 325i LS Swap (Rust Repair & Respray Underway)
  • jeenyus
    • Aug 2011
    • 2064
    #76
    It seems like a 4.10 diff would be too short for that much power. Like i bet you fly off the line, but cruising you'd be sitting close to 4k like all the time. Are you considering changing the final drive with the new power plant?
    • AWDBOB
      hooptie connoisseur
      • Aug 2013
      • 4504
      #77
      Originally posted by jeenyus
      It seems like a 4.10 diff would be too short for that much power, cruising you'd be sitting close to 4k like all the time.
      Not with a T56- fourth gear in *most* T56s is 1:1. 5th and 6th gear are both overdrive gears. Unless OP is cruising the highway at like 120mph all the time the 4.10s actually probably work well.
      • jeenyus
        • Aug 2011
        • 2064
        #78
        Ah I guess I missed where he replaced the tranny with a Chevy transmission. Thanks for explaining that!
        Sent from my Pixel 2 using Tapatalk
        • Pootis
          • 636
          #79
          Yeah AWDBOB is right. The 4.10 is geared really well for this setup even with the shorter tire but I think down the road I will get a built 3.73. That is probably the perfect ratio.
          1989 325i LS Swap (Money Pit):https://www.r3vlimited.com/board/sho...d.php?t=244933
          COTM Feb 2019: https://www.r3vlimited.com/board/sho...d.php?t=428404
          • z28
            • Oct 2014
            • 362
            #80
            I wouldn't go shorter than 3.73.
            First e30 - 1991 318i 4 door
            • lukeADE335i
              • Apr 2013
              • 1389
              #81
              I'd agree there. The HSV Commodores we got down here with the LSx run either 3.7 or 3.9 LSDs with the T56. They have plenty of poke pushing around 1800kg, so 3.73 should be fine in an e30.
              My e30: OEM+ with M30B35
              • Pootis
                • 636
                #82
                Ebay is running 10% off right now so I think I'm going to pick up a Sloppy Stage 2 Cam and new lifters during the sale
                • BUDNUNTA
                  • Apr 2005
                  • 996
                  #83
                  I've got 3.46 with 195/60/15s
                  Gearing feels great to me
                  We're out there in here.
                  • TeXJ
                    • 1914
                    #84
                    Just found this build thread and am very interested in the ls swap details.
                    For the 6.0 that you're gonna be putting in, do you have DOD? If so, are you going to delete it?
                    Did you buy any of the swap kit parts? I see you modified c5 headers, any info on that?
                    May I ask about how much you have in the swap?
                    Would love to put a LS in my e30.
                    1990 325is
                    m52b28
                    3.73lsd
                    g260 (1987 325is 5spd tranny)
                    • Pootis
                      • 636
                      #85
                      The 6.0 I bought is not DOD but if you buy a DOD motor you will have to delete it. I am doing a full refresh on the motor with new lifters gaskets headbolts etc and throwing a cam in. I bought a custom kit that a guy was running in his e30. It sat a little too far back for my liking so I did alter it a bit. The modified c5 manifold is not pretty but it works. I basically cut it off at the collector and then mixed and matched pieces until I could sneak it around the steering shaft. For the 6.0 I plan on running a set of jba gto shorty headers with hopefully minimal customization necessary. I have never added up all that I have in the swap but I can tell you now it isn't cheap and the "while your in there stuff" adds up quick but when people tell you expect to spend 6-10k believe it. I definitely have at least $6K in it and that is with doing 95% of the work myself. If I could do it over again I would have just dropped an M/S5X in it and turbo'd it. Practically the same amount of money and wouldn't take 3 years to do it. Not saying an LS swap takes that long but an M/S5X swap can be done in a weekend.
                      • TeXJ
                        • 1914
                        #86
                        dang man. I'd like one but I know I couldn't do most of it myself. Thanks for the info!
                        1990 325is
                        m52b28
                        3.73lsd
                        • 325isman
                          • Dec 2010
                          • 299
                          #87
                          Nice looking car and I like the wheels on it,keep up the good work.
                          • Pootis
                            • 636
                            #88
                            Appreciate it!
                            • Melon
                              • Mar 2018
                              • 1311
                              #89
                              I swapped out the 3.42's in my C5 to 4.10's
                              Best mod ever.
                              I do things.
                              • Supadave
                                • 1006
                                #90
                                Ain't that the truth. I remember do my S52 swap in 2 weekends by myself. This LS swap is WAY more time consuming. At the end, it'll be worth the time and effort.
                                https://www.r3vlimited.com/board/sho...d.php?t=420591 5.3 LSA build in progress :devil:
