Ebony & Ivory
  • BMWerke
    • 893
    Ebony & Ivory
    Hello, I am black man and this is my car.
    I REFUSE to rock the same wheels on my E30 that everyone else has (Borbet A, BBS RS) no matter how good it looks.I also have a bad habbit of buying wheels and then never putting them on the car (16x9 Corvette salad shooter, 16x8 CSA Diplomats). So I picked up Some trashed 16x8 ET34 Mercedes Cosworth wheels and with a little bondo & Ivory paint I was able to do this.
    Then I ordered some 30mm Adapter from Adaptec Speedware which arrived today so here are some mock-up shots!!!
    I bought the car bone stock with 106k on the clock back in March of 2010, since then I have done the following.
    5 speed swap
    Head gasket
    All oil seals
    Coolant Hoses
    Interior swap from black to beige (I am switching to grey plaid soon)
    LED Interior, trunk and license plate lights
    Caliper Rebuild
    Ceramic Pads
    H&R sport Springs
    Control Arms
    E30 M3 offset bushings
    I have poly trailing arm bushings that need to go in soon
    Exhaust hangers
    Spark Plugs
    Cold Air Intake
    Center Support Bearing
    PHC Valeo Friction Disc
    Sachs Pressure Plate
    Timing Belt
    Coolant Cap Seals
    Drivers Lock Rebuild
    Euro Intensive Headlamp Washers
    I have bought many M50s but none of them have ever made it into my car but I picked up a low mileage one for $100 including the harness. And I will be doing the following.
    M50 block/head
    M52 2.8 pistons, crank and rods
    Individual Throttle Bodies from the older K75/K100 BMW Motorcycles 'cause they use the same Throttle Position Sensor.
    S54 Intake
    E39 540 MAF
    M54b30 intake cam with 4mm shaved off from gear
    M50 Non Vanos Intake cam will be ran on the exhaust side.
    S54 Oil lifter housing with aftermarket oil cooler.
    Im also gonna run coilovers because the H&R sports are too soft.
    Some cleaned up parts.
    I bought an engine stand 3 month ago but I just purchased longer bolts to hold it up since the stock tranny ones are too short
    Warped S50 head in my room that I turned into a planter lol.
    Having Fun doing the headgasket/tranny swap.
    me
    And my buddies who help me out SOOO much!
    That ttrousdell standing on the donor car lol
    Current Look
    My well drawn exhaust plans (and I was going to art school lol)
    Hans the traveling logo in my E30!!!!!!!
    '90 325is DD, 5 spd swap-H&R springs-Euro Headlight Fully Built OBD1 M54b30. Ox Blood interior, 3.46 LSD with Z3M Diff Cover. Custom shifter, every bushing replaced.
    '86 325e- Donor car for swap/parts car
    '00 323i- BBS 197s Totalted
    '89 740 turbo Volvo- Donated
  • FunfGan
    • Jan 2011
    • 4958
    This is going to be great :D
    Go here be happy!
    Ratchet Garage e30 V8 build.
    • ButtJuice
      • Dec 2009
      • 2609
      Looks awesome dood
      1991 318is - Sold
      1986 325 - Sold
      Instagram - Lamoursum
      • Massimo
        • Jan 2008
        • 3207
        Wheels make the Boss!
        • squidmaster
          • Aug 2011
          • 2666
          what size tires? Also what brand, and such and such.
          • Kershaw
            • 11822
            hello, i am a white man and i think your car looks great.
            AWD > RWD
            • Danny
              • 14216
              Your car looks like butts.
              • BMWerke
                • 893
                Thanks guys!
                And I will be running a 195/50 up front and a 205/45 out back.
                • slammin.e28
                  שמע ישראל
                  • 12054
                  I am stealing that planter idea!
                  • 8380 Labs
                    • Oct 2006
                    • 2990
                    is there a specific reason you chose final et -26?
                    8380 Laboratories
                    M3 Champs Poster
                    • Vtec?lol
                      • Dec 2009
                      • 3278
                      Herroo. I'm brahck man too! I must say you're making us look good so far!
                      I'm stealing the plant Idea as well!
                      You wouldn't have happened to have any adapters for those salad tossers would you?
                      • BMWerke
                        • 893
                        Well the wheel offset is +34 and the adapter is 30mm so my final offset is +4. so I'm not sure where the -26 came from.
                        • BMWerke
                          • 893
                          Haha thanks, and no I don't have the adapters. I sold the wheels a long time ago.
                          • 8380 Labs
                            • Oct 2006
                            • 2990
                            it came from your first post where you said the offset of the wheels was et4. :p
                            8380 Laboratories
                            M3 Champs Poster
                            • squidmaster
                              • Aug 2011
                              • 2666
                              lol I actually meant what are you running on the 14" weaves.
                              the size is perfect and I'm in the market for new tires.
                              car looks great btw
