TheTacoMan's build, Turbo'd, mflare'd.
  • TheTacoMan
    • Nov 2011
    • 2308
    #31
    Originally posted by BavarianAddict06
    Just did a stroker on a buddy of mine's car. Big difference. did you happen to do a comp test and leak down test before hand? dont make the same mistake i did. turned out the block was toast now spitting out blue smoke like a mofo. good luck with the stroker!
    No I didnt, but the car did run perfect and did not smoke even a little bit. Only issue was the car warmed up very quickly but I thought that was due to the thermostat.
    • BavarianAddict06
      • Sep 2011
      • 315
      #32
      yea you shud have done that BeforeHand . its always good to be safe. Yea buddy of mines car before the stroker was runnin on the warm side. but found out it was the headgasket. good luck. its worth it
      1987 528i Royalblau
      • TheTacoMan
        • Nov 2011
        • 2308
        #33
        Got the new head on along with the new timing blet, water pump, headgasket. Also have a 12in electirc fan coming along with long tube headers and 3in exhaust all the way back. No cats
        • slaterd
          • Jul 2011
          • 1731
          #34
          Awesome, I too have an 88 eta. Can't wait to save up some money to do this swap. The stock eta is a pig and I need a little more power in my life.
          Originally posted by Wh33lhop
          This is r3v. Check your vaginal sand at the door.
          • TheTacoMan
            • Nov 2011
            • 2308
            #35
            Yes, compared to my friends 85 325e this was light years faster. Even copared to a supped up "i" it really didnt get killed bad at all. If anything it kept up.
            I cant wait to get it done, just waiting on exhaust to get here and some miller stuff.
            • TheTacoMan
              • Nov 2011
              • 2308
              #36
              Finished the the stroker conversion today, waiting on the i ecu, maf sensor, and long tube headers. Still neeed to finish the cooling system with a 12in electric fan but thats it.
              Also if anyone has an I throttle body that they would be willing to sell let me know as the junkyard wanted 52$ for one.
              • squidmaster
                • Aug 2011
                • 2666
                #37
                Did you bore the block?
                • TheTacoMan
                  • Nov 2011
                  • 2308
                  #38
                  No I didnt, started with a super eta engine and put an I head on.
                  • squidmaster
                    • Aug 2011
                    • 2666
                    #39
                    that's not a stroker then. it hasn't been stroked haha. it's just a 327i.
                    also if you had a super eta engine then you already had an i head, it was just a matter of changing the cam and valve springs. other than that the seta engine is almost exactly the same as an i engine.
                    • TheTacoMan
                      • Nov 2011
                      • 2308
                      #40
                      I realize this, but it was easier for me just to get a new head and do it that way. I guess you could call it the poor man's stroker
                      • ian e30 318is
                        • Mar 2007
                        • 1809
                        #41
                        He's not hating lol...just pointing out a fact.
                        There's a few key words in there
                        1991 LS1 Swapped 318is
                        Instagram:
                        https://instagram.com/saltybeast/
                        LS Build Thread:
                        https://www.r3vlimited.com/board/for...s-e30-ls1-swap
                        • squidmaster
                          • Aug 2011
                          • 2666
                          #42
                          no, not hating. I'm just saying that I did the same thing as well, and called it a stroker because I thought it was easier, but there's a distinction.
                          • TheTacoMan
                            • Nov 2011
                            • 2308
                            #43
                            Ok, you guys have a point. Well my 2.7 is nearing completion, just waiting to finish my exhaust.
                            • TheTacoMan
                              • Nov 2011
                              • 2308
                              #44
                              Found out why my car seemed fast , it had a 173 ecu already in it. I also got another mystery 173 ecu with a chip on it already. Check out this thread.
                              • TheTacoMan
                                • Nov 2011
                                • 2308
                                #45
                                Car is now running, everything is working minus the exhaust which will made at some point soon.
