E30 W/ Nitrous Powaa :D
    I don't think this will help controlling the timing
    M20B28 Turbo
    My Build Thread
    http://www.r3vlimited.com/board/showthread.php?t=255839
      Originally posted by MaksV View Post
      as long as you have a control box that has a staged distribution and a rpm trigger, bottle warmer, and a wet shot, I see no reason 50-75 shot isnt fine on a stock motor. I have seen this same setup on M50,52, and 54 with no issues.
      Problem is I'm not running a wet shot if that make a difference it's a dry shot nitrous kit.
        Why So? It says you can adjust your timing by (+/-) 20 degrees.
          It's IMPOSSIBLE! I can't believe this
          M20B28 Turbo
          My Build Thread
            Read the specifications of this link: http://www.msdignition.com/Products/...n_Control.aspx
              Oh! Great :)
              When it comes to turbo cars tuning you may need to retard or advance the timing in specific RPMs, with that MSD I think you can't adjust the timing in each RPM? It'll be fixed for all RPMs? Is it enough just to retard it few degrees and that's all?
              M20B28 Turbo
              My Build Thread
                Oh! Great :)
                yeah I think so because I was reading about this controller on a 350z forum for a twin turbo project.
                  you will be able to run a base timing with that msd ignition. and one of the wires that goes to the module is a trigger for retarding timing. in this case it would be wired with whatever you would use to activate the nitrous solenoid. wide open throttle switch or a button inside. whenever the nitrous is activated the msd ignition will retard the timing to what you set it to. and it will go back to base timing when the nitrous is deactivated.
                  Racelands are cheap shit.
                  Originally posted by whodwho
                  So are r3v members
                  dude, this is R3v. there's like 40 project threads, and like 20 FS threads and 100 members ride threads of stupid shit. guaranteed laughs on every page. cut springs, rolled cars at 20mph, fishtank heater core, selling broken stuff, painting cars with paint brush, cheap wings, hella-flush and then there is Vlad, king of the eta M3
                    I'm using neither a WOT chip or the fun button. I'm using a TC Window switch would it still work?
                      Yes.
                      So are r3v members
                        Yes.
                        Do you if the installation for the controller is hard and to set up the ay you mentioned? Or is it a professional only job? Also are there any online DIY's?
                          Originally posted by Vtec?lol View Post
                          M20 distributors arent at all adjustible. Maybe they could if you tapped some holes but umm.
                          That wouldn't do a thing. there's no points or pickup in the distributor to determine when it fires (on a 325i it's 100% electronic). all you'd do is change when it is physically able to spark, and probably end up with the rotor on the wrong wire when it fires...
                          Ich gehöre nicht zur Baader-Meinhof Gruppe
                          Originally posted by Top Gear
                          Just imagine waking up and remembering you're Mexican.
                          Every time you buy a car with DSC/ESC, Jesus kills a baby seal. With a kitten.
                            Wouldn't want that lol
                              Shouldnt be hard. The tc switch comes with wiring diagrams to install several differeng ways and so does the msd ignition. On the zex website, look at the tc switch u can download a pdf for wiring installation. Same thing on the msd website.
                              So are r3v members
                                Here is a DIY on NOS bro.
