Schwarz/Houndstooth Mtech1 S52 coupe: 10 year journey
  • Habla
    • May 2004
    • 1470
    TL,DR
    __________________________________________________ ____________________________
    Hi. I've introduced myself and my car in the pnw section before, but I thought that I should make a project thread to share, and so I can track my progress.
    Anywho, around thanksgiving, I finally got an e30. I drove it home with no brakes and floppy ball joints. It was also raining, and the defrost grid is broken (no way!) so I couldn't see shit. Here's what I got:
    Driver door:
    1. This door doesn't match (it has no pinstripe, yet it has damage. Wonder what the original door looked like...)
    2. The lock is punched in and was never matched to the car (can't use it)
    Passenger door: Someone obviously tried to lever it open, bending the top of the door out
    Front bumper - DGAF, Going in the trash (fender has some related damage, not going in the trash)
    So that's what I started with, at least on the outside. Interior is in really good shape, apart from a broken sunroof crank and a rip in the sunroof liner. I'm always looking for front black perf vinyl sport seats, but can never afford them.
    Over christmas break, I ordered ball joints and had them pressed into my lca's, and then I installed them. It would have been cheaper to order complete arms, but oh well. Rented a pickle fork for the old stuff, but the job was still painful. Especially tightening the subframe bolts. I also installed a new brake master, bled the brakes, and spilled the blue all over the place. Now the car was at least safe to drive.
    Went to a Portland meet in March and picked up euro bumpers and the euro valance. I really struggled to get the rear to line up, since my brackets were bent multiple times. Strangely, I never took pictures of the front, and It's off right now. The front was missing a few pieces, but "bmwsparesshop" on ebay uk is the place of wonders. Got the rear caps for 20 and the front side trims for 10 (one side is for mtech, they don't match. I will buy new, later).
    The rear bumper:
    Yeah, the exhaust pipe is now much too long, but I need a new muffler anyway.
    My US valance was bent to shite, but I needed the top portion, so I snipped away the junk and kept the goods. The euro valance was polaris, I think. I used a wire wheel on a drill to quickly key the paint, and rusto-glossed it to black:
    Summer break
    In early June, I started tearing apart my engine, because I was getting poor economy, losing coolant, and overheating, I suspected. My temp gauge never worked, so I swapped it with a junkyard piece, and it was more lively, but would jump to full hot pretty quick. I still don't know whether it was overheating or not (my coolant check light has always been on).
    This week has been very productive:
    • broke the upper neck of the radiator when removing it, so I picked up a used behr piece
    • got the fan clutch off, unsure of its condish. Contemplating a cheap electric fan
    • finally freed the head, but had to remove the intake mani in the car in order to lift it by myself. I should have taken the hood off.
    • Started disassembling the head
    Gasket bottom
    Gasket top
    Looks like the coolant passages have buildup, but I don't see breaks in the gasket anywhere...
    Started stripping the head. Don't know if the machine shop needs all the studs out, but I toiled anyway.
    My chain clamp was juuust too short, so I had to improvise:
    The exhaust rocker shaft was cake, but the intake side was kicking my ass. The rockers wouldn't break free of the shaft and prevented the shaft from sliding out. I couldn't get the first rocker off, and it was dark, so I grabbed a beer instead. In true budget-build form, an icy cold Rainier.
    -Pete
    -Peter
    318is slicktop | F15 35dM | F250 SD
  • FunfGan
    • Jan 2011
    • 4958
    Looks like you're making some good progress, keep at it!
    Go here be happy!
    Ratchet Garage e30 V8 build.
    • Habla
      • May 2004
      • 1470
      Thanks , Disco Stu!
      -Peter
      • ACHTUNG
        • May 2005
        • 2397
        Ahhh Rainiér...I miss drinking cans of vitamin R.
        1989 US E30 Cammed S52
        Under Construction: 1983 Euro E28 Cammed LQ9/LS3 Heads/Jakeb E28 LSx Kit
        • Habla
          • May 2004
          • 1470
          It's been a while...
          It's been a year since I updated this, so I'm going to do a quick update with pictures.
          When I finished the HG (sooooo dirty):
          And gratuitous tailpipe is still there (new muffler was next):
          All clean:
          Got a lip from Austin:
          No more bozouku pipe:
          Replaced fuel lines:
          Bought some new seats!:
          Did this:
          Mine, buddy's car, and the rabbit:
          My tach took a crap again, so I looked inside and found a burnt path. Soldered some wires in its place to fix it:
          Decided to drag Ricky and Abe into a long day of wrenching. Put in a S2.93, and attempted to lower the car on ST springs and used shocks (horrible idea, I'll explain later):
          Josh showed up to help, because the front shocks were I bought were blown and the wrong size. He saved the day with a different pair laying around.
          Diff and rear susp. in, toiling on front suspension:
          Results:
          Tried to get rid of the oxidation:
          Prepping for ABQ:
          Couple days after:
          Then I finished school, so I got to move back home!
          This is where shit hit the fan. I realized that the ST springs I had bought were for a 318 once my front shocks blew and I was bound to nosedive my oil pan straight into the ground at any moment. I looked up my order from eBay, and sure enough, I fucked up. Maybe that was why the car was so raked forward....
          Anyway, the car was undriveable, so I decided to redo it (myself, this time) with some Bilstein HD's and H&R sports.
          Up she goes, for a month or so...
          Getting the old stuff out:
          Sold this lot:
          With the car in the air (waiting on springs), I painted all the front and rear trim:
          Results:
          Also did the wheels, since the springs were backordered:
          Finally:
          Rear done:
          Now the front:
          The day after (on an incline):
          Got to take it to the islands after I finished, which was quite a reward:
          And that's where I'm at right now.
          -Peter
          -Peter
          • series88
            • Nov 2011
            • 1231
            A world of difference. Great looking car. Keep it up!
            • downforce22
              • Aug 2009
              • 3192
              nice where did you find the valence? Also, may want to replace the cam gear and oil drive gear with the later style (sintered) ones, those early ones are known to fail.
              • Habla
                • May 2004
                • 1470
                I got the valence with the bumpers...
                I'm not tearing into this motor anymore, I'm starting a swap fund
                -Peter
                  • 37829
                  Sweet car and good work! I love a Euro'd early model so much.
                  Classic BMW Specialists
                  Grover Beach, CA
                  www.BimmerHeads.com
                  • Habla
                    • May 2004
                    • 1470
                    Thank you all!
                    -Peter
                    • Habla
                      • May 2004
                      • 1470
                      Sooo, this happened recently:
                      So it came out:
                      Separated the trans, and took it to the car wash. Here's what 27 years of crap looks like:
                      After much searching, I picked up this sight for sore eyes. Stay tuned!
                      -Peter
                      • E30_Pare
                        • 7801
                        -Peter
                        o.O fuel gauge must be brokeded.
                        DREWLIENTE
                        1$ PShops PM me
                        • Habla
                          • May 2004
                          • 1470
                          Wut?
                          -Peter
                          • Habla
                            • May 2004
                            • 1470
                            The motor is ready to come out:
                            -Peter
                            • kingston
                              • Jun 2010
                              • 2669
                              Awesome man! You will love the 24V setup in an E30! Smoother, more powerful, no more timing belt, no more manual valve adjustments, easier oil changes, no manual belt tensioning... good times!
                              Originally posted by LJ851
                              kingston is the play by play announcer for this thread.
                              ‘Tis by the grace of God that my cars run!
                              Originally posted by unloadedak
                              #teamross
                              Siobhan's Build Thread - UPDATED!
