Schwarz/Houndstooth Mtech1 S52 coupe: 10 year journey
  • Habla
    • May 2004
    • 1470
    #46
    Nope. Fuel pump is now making more noises than usual, so a new bosch external is on order.
    -Peter
    318is slicktop | F15 35dM | F250 SD
    • kingston
      • Jun 2010
      • 2669
      #47
      Dang, man...this car should already be screaming. Keep at it!!
      Originally posted by LJ851
      kingston is the play by play announcer for this thread.
      ‘Tis by the grace of God that my cars run!
      Originally posted by unloadedak
      #teamross
      Siobhan's Build Thread - UPDATED!
      • Habla
        • May 2004
        • 1470
        #48
        I suspect that poor fuel delivery has been the main cause this whole time... Live and learn I guess.
        I'm still glad I've done all this other stuff though
        -Peter
        • Habla
          • May 2004
          • 1470
          #49
          Got a new hella crank sensor coming, as the off brand one I had in there was failing and causing the engine to shut off for a split second and flash a cel.
          I put in a brand new bosch external pump, but it turns out the lift pump is the culprit, as the new pump is still squealing like a stuck pig. I have a new walbro coming, so I'm ditching the twin pump setup for a single tank pump. Now to see if the tank is rusty :/
          -Peter
          • kingston
            • Jun 2010
            • 2669
            #50
            Sounds like you are really close now, man!!
            #teamross
            • Habla
              • May 2004
              • 1470
              #51
              Long time no update!
              Bought some front seats and began the hunt for the rest (PITA$$). Ollie the heeler collie is about 1 here (he's 2.5 now)
              Old cockpit setup
              The 770/2 euro valance looks great!
              I finally fixed all my engine issues with the m50 by installing a walbro 255 in the tank and taking out the two pump system. Also moved the filter to the old external pump location. It wasn't very long after that I found an s52 for a deal. So I did what any sane person would do and sold my entire drivetrain to start over.
              M50tu/g250 coming out
              The new S52
              Picked up a zf320, did the pins/detent service, condor shift bushings. Plugged in the Markert Motorworks obd2 harness and chucked the motor in!
              Konis going in the front with new bumps and top mounts
              Finally finished the houndstooth scavenger hunt, found the bolster pieces I needed and rebuilt the front seats. Started putting the rest of the interior in
              Installed the spal fan and brackets, hooked to a 80/88 switch in the radiator for automatic turn on action
              The Jimmy hill hunt has also come to a close. It was lachs, now flat black
              Got some exhaust done, but Im not happy with the work at all. Gotta fix it later. At least the vibrant stuff looks nice
              Been sitting on these RD wheels for a while, finally got some undersized tires put on :sigh:
              This is pretty current:
              Just got my collector plate in, stay tuned for interior assembly and making the front end come together.
              -Peter
              Sent from my Z981 using Tapatalk
              -Peter
              • e30austin
                • 15382
                #52
                Nice!
                • wworm
                  • Dec 2016
                  • 1719
                  #53
                  good stuff man! chrome on black looks so damn good.
                  1984 Delphin 318i 2 door
                  • Habla
                    • May 2004
                    • 1470
                    #54
                    Thanks!
                    Bought some RXs for the wagon and I just had to see the 225/55 et15 on the adapters :loco:
                    Could work with some stretch I do love them so
                    -Peter
                    • AWDBOB
                      hooptie connoisseur
                      • Aug 2013
                      • 4504
                      #55
                      What p/n fan did you use?
                      • Habla
                        • May 2004
                        • 1470
                        #56
                        One of these, Bob
                        Spal 30100401 16" Straight Blade Pusher Fan https://www.amazon.com/dp/B009OBOOT4..._ZAEcAbW2ZQMGK
                        -Peter
                        • TheWipprSnappr
                          • Jul 2015
                          • 477
                          #57
                          Originally posted by Habla
                          are these 16x8s?
                          1990 325iX - sterlingsilber metallic
                          1991 325i - lazurblau metallic
                          Originally posted by delamaize
                          E30 = Lego for men.
                          • Habla
                            • May 2004
                            • 1470
                            #58
                            Yep, e34/e30m3 fitment
                            -Peter
                            • AWDBOB
                              hooptie connoisseur
                              • Aug 2013
                              • 4504
                              #59
                              One of these, Bob
                              Thank you! That's the one I had saved in my cart. Is that the stock booster just moved over?
                              • Habla
                                • May 2004
                                • 1470
                                #60
                                Yes it is, with shaved fins.
                                -Peter
