★ ★ Project Glacier | Make the E30 a Daily Again ★ ★
  • petrolhead
    • 421
    #706
    Originally posted by lambo
    Rear subframe is being a dick, though. It won't drop by itself. I'm thinking the mounts are seized/corroded. I'm going to have to get creative.
    Very little hammering required. Put a large enough bolt or screwdriver into the bush hole and twist/pull/yank it sideways, it'll break free.
    -oh I see you already dropped it. Well, someone else might benefit from this ^.
    I use a puller + some patience on those washers that usually are tight in the bush. Before putting them back I've used a hydraulic press to make them a bit curved/ cup shaped, like they are on M3. This limits rear subframe vertical movement. I've done this on two cars, I think it works.
    -Jarno
    • lambo
      Captain Scene Points
      • 10953
      #707
      Gonna finish this tomorrow/Sunday.
      Well this was a lie, probably.
      Got some stuff done today. But, that half shaft is still stuck in the hub. We gave it hell today. Sledge hammer, torch, slide hammer, you name it. My neighbor said he'd bring it into his shop on Monday to get it out so we'll see. Might ask around locally if someone happens to have a straight driver's side trailing arm.
      Got one trailing arm ready to be mounted. Decided not to paint them. I'll be dropping it all again in a year or so.
      Pretty, new wheel bearing ( ◠‿◠) I bought the Harbor Freight tool to press the bushings in and out. It's definitely a worth while thing to have, in my opinion.
      I have no idea what I'm doing.
      GC parts sure are pretty when they're clean.
      • lambo
        • 10953
        #708
        Also, here's how I removed the rtabs. I installed them with the same setup, just altered.
        • blusylver
          • Feb 2013
          • 230
          #709
          I tried removing my rtabs like that and I ended up breaking the all thread. So I decided to burn them out. Fire is way faster and funner.
          • lambo
            • 10953
            #710
            slow and steady... you have to tighten it and let it sit for a bit instead of just cranking it
            • blusylver
              • Feb 2013
              • 230
              #711
              my subframe was rusted pretty bad. before I tried the all thread I tried a 20 ton manual press, only thing that worked was fire. it was not my first choice. glad yours came out easily
              • lambo
                • 10953
                #712
                Tomorrow. I swear.
                • lambo
                  • 10953
                  #713
                  E30's suck.
                    • 37829
                    #714
                    E30's suck.
                    I thought this once. I was wrong.
                    Classic BMW Specialists
                    Grover Beach, CA
                    www.BimmerHeads.com
                    • LJ851
                      • 7918
                      #715
                      E30's are special.
                      ftfy
                      Lorin
                      The M30 is God's engine.
                      • 325i
                        • Sep 2012
                        • 910
                        #716
                        getting real tired of your shit stella.. my arms and back are sore and im tired as hell.
                        1997 Audi A4 1.8t 5-Speed (bamboo metallic): ST Coilovers, Sport Edition 17x7.5 Et35, 215/45/17 Kumho AST, Panzer, Depo Ecodes, 55w 5k bulbs, Magnaflow 14815, Res delete, JHM Vent Boost gauge
                        2001.5 Audi s4 2.7tt 6-Speed (Imola Yellow)
                        <<Flickr>>
                        • lambo
                          • 10953
                          #717
                          Well she's back up and running. FYI running no muffler is the worst thing in the world.
                          • lambo
                            • 10953
                            #718
                            Put the muffler back on. Now I just need to tune the amp. And I need to order parts for the front. But, she's good to drive :)
                            20140626-DSC_1967 by PhillipKeefe, on Flickr
                            • MPLFoster
                              • May 2013
                              • 1490
                              #719
                              Nice. was waiting for the obligatory sunset shot....
                              form.follows.function IG @mplfoster
                              • lambo
                                • 10953
                                #720
                                of course lol
                                I'm going to pick up a new lens tomorrow ;D
