★ ★ Project Glacier | Make the E30 a Daily Again ★ ★
  • lambo
    Captain Scene Points
    • 10953
    #841
    So my dumb hard start problem came back... I wonder if it's the heat down here or something.
    20140819-DSC_2682 by PhillipKeefe, on Flickr
    • E30_Pare
      • 7801
      #842
      weak battery
      DREWLIENTE
      1$ PShops PM me
      • lambo
        • 10953
        #843
        Originally posted by E30_Pare
        weak battery
        It doesn't seem like a battery issue since it only has difficulty starting on the first key turn after it sits for, anywhere between, 20 minutes to a couple hours. Then it fires right up on the second key turn.
        • lambo
          • 10953
          #844
          I'm trying to be cool here...
          20140820-DSC_2693 by PhillipKeefe, on Flickr
          • E30_Pare
            • 7801
            #845
            is that the walmart special? lol. Use those same stikars on my rc cars.
            DREWLIENTE
            1$ PShops PM me
            • Hooffenstein HD
              • Nov 2012
              • 1388
              #846
              That's a cool spot. You've got some real nice locations out your way, you lucky bastard.
              In regards to your hard starting issues, perhaps you have a small fuel leak and slowly losing pressure at the rail?
              • lambo
                • 10953
                #847
                I'll have to check that out. Although, it would be weird as everything fuel related in the engine bay was just replaced. Maybe my injectors or something aren't seated correctly.
                • lambo
                  • 10953
                  #848
                  20140819-DSC_2685 by PhillipKeefe, on Flickr
                  So begins the long period of no fun updates since school started up again.
                  Although, I took it out for a drive a couple days ago and the m20 feels really strong. Now I just need to replace the giubo and csb. Somewhat thinking of just buying a reman'd driveshaft, that would probably be the smart thing to do. Although that would mean forgoing a new exhaust setup. Decisions...
                  I seriously can't wait to get out of school and actually start doing real things to this car versus talking about them...
                  • Mr. Tasty
                    • Jul 2011
                    • 3421
                    #849
                    could be water temp sensor. My car has this same issue. Cold starts instantly, hot starts instantly. Only hard start if it cools down a bit, like an hour.
                    2014 Alpine White 335i MSport
                    (Daily Driver)
                    Full Mperformance Aero
                    KW V2 Coilovers
                    VRSF Catless Downpipes
                    • lambo
                      • 10953
                      #850
                      Interesting. I was looking at it when I was doing my other maintenance thinking it might be nice to replace it.
                      • lambo
                        • 10953
                        #851
                        So close to pulling the trigger on a set of wheels...
                        20140906-DSC_2701 by PhillipKeefe, on Flickr
                        • lambo
                          • 10953
                          #852
                          I can't do stock weaves for more than a few months at a time. Even though the ride is decently comfortable. IDGAF.
                          • 2mAn
                            Señior Mod
                            • 21068
                            #853
                            why do you need a new driveshaft? the guibo and CSB are seperate from the driveshaft.
                            Its a pain, but the parts are cheap and it can be done relatively easily if you can get the car up in the air.
                            cheap repair = more money for rebuilding the OZs!
                            Simon
                            Current Cars:
                            -1966 Blue Boat
                            -1969 Red VW
                            -1986 White BMW
                            -2006 Green Thing
                            Make R3V Great Again -2020
                            • AbsorbantNut
                              Non faccio funzionare questa merda
                              • Jun 2010
                              • 2491
                              #854
                              Ugh so true. I ran weaves up front with steelies in the back when I rebuilt the RS's. I couldn't wait to get them off
                              '73 2002 m20 turbo [sold] '87 rat rod 325is [couch modded] '91 vert [daily] '88 325is [spec build v1] '84 325 [spec build v2] '99 323i vert [sold]
                              • lambo
                                • 10953
                                #855
                                Typically a failing csb/guibo is a sign of shitty u-joints. Idk, it would be a piece of mind thing really.
                                Yeah weaves haven't gotten me many scene points.
