Looks great!
★ ★ Project Glacier | Make the E30 a Daily Again ★ ★
No idea... I was under the impression the whole strut would have to come out. Ideally that's how I'd like to do it so I can clean some stuff up... idkHmm, with shortened housings don't you just unbolt the three nuts at the top (camber plate) and you can pull it out from under the fender? I can do that on mine with stock housings, so swapping struts is a breeze. I wouldn't worry about time or space too much.
And before people try to take this the wrong way, I'm only asking in case you didn't realize how easy it is :)
Originally posted by SpasticDwarf;n6449866Honestly I built it just to have a place to sit and listen to Hotline Bling on repeat.Comment
Nope, if you don't have to clean anything up it shouldn't take more than an hour or two max. Are you planning on repainting/PC'ing your housings?The first car I ever rode in was an e30
1992 Mauritiusblau Vert
2011 Alpinweiss 335is coupe
2002 540i/6 Black/Black
2003 GSX-R 750 (RIP)Comment
I guess that makes sense. Housings are already PC'd but the driver's side housing has a lot of shock gunk on it from the blown shock...
Well...I definitely need to get around to fixing my damper... Any kind of spirited driving gets a little sketchy if there are slight bumps in the road...
^^^Looks like a solid list!sigpic
Instagram @rebellionforgeComment
I might bump it up to 5mm just to be safe. But, once I get the wheels I want to be able to run them immediately and then sort out the perfect spacers afterwards.
Haha! Nah, I'm gonna go with the white and black bolts...hoping to kind of mimic this:
MMMMMMM.....Wheelzzz.
I like that, fresh look for that wheel. I would look clean on your car.sigpic
