★ ★ Project Glacier | Make the E30 a Daily Again ★ ★
  • Jb325is
    • 2137
    #1606
    Nice! I have an OBD1 manifold leftover from my blow'd up s50, has all new hoses and stuff
    - '88 m54 coupe
    <3
    • 2mAn
      Señior Mod
      • 20877
      #1607
      Plus a set of S50 cams and cam trays? Give him a package deal
      Simon
      Current Cars:
      -1966 Lotus Elan
      -1986 German Car
      -2006 Volkswagen Jetta TDI
      Make R3V Great Again -2020
      • lambo
        Captain Scene Points
        • 10953
        #1608
        Grabbed an M50 manifold from the junkyard today.
        • gdrumm93
          • Oct 2015
          • 123
          #1609
          I'm building an M52 for my 4 door e30 as well, I'll be looking forward to seeing your progress.
          • ak-
            • 12422
            #1610
            M52urbo pls
            1991 325iS turbo
            • lambo
              • 10953
              #1611
              Originally posted by ak-
              M52urbo pls
              That's the plan lol
              • Northern
                I like cupcakes & sh!tboxes
                • 5248
                #1612
                WHP goals with turbski?
                Originally posted by priapism
                Originally posted by shameson
                • lambo
                  • 10953
                  #1613
                  350-400 wheel. Somewhere in there.
                  • ak-
                    • 12422
                    #1614
                    Nice - so easily done. We can all forgive you for the Futuras now.
                    1991 325iS turbo
                    • lambo
                      • 10953
                      #1615
                      I actually emailed VR Wheels yesterday about getting them fixed... so that's happening, finally.
                      I ransacked the junk yard again for parts that I may or may not need. I'm not terribly sure. I figured I'd rather have more junk than not enough junk lol
                      • LJ851
                        • 7919
                        #1616
                        You're going need more rubber than a 205 this time, i'll hold my forgiveness until i see some real tires on there.
                        Lorin
                        The M30 is God's engine.
                        • Wschnitz
                          • 8089
                          #1617
                          What r u doing these aren't Tacoma parts.
                          willschnitz
                          • lambo
                            • 10953
                            #1618
                            Yeah... I'm not too sure what to do about that. I was thinking 225/45 star specs on the Futura's but idk if that will be enough. I might consider stepping up to 17's or 245/40 RS4's on some fat 15's hehehe
                            I know... it's bad. I have too many projects. And, Ryzen isn't gonna help if it's good. Currently I'm thinking armor for the taco with refund monies, for now.
                            • lambo
                              • 10953
                              #1619
                              Quick update on the E30. I just bought a bunch of truck parts so the swap has been pushed down the list of priorities a bit. I want to get suspension, tires, and the remaining armor for the truck before I really continue more with the E30.
                              As such, since the M20 isn't really working properly, I decided to fix it up so it's driveable because I really miss driving it. Currently, if it is dead cold, it will fire right up and run ok. It seems to misfire under light load and occasionally under WOT. Then, once it gets warmed up and I turn it off, leave it off for like 15-30 minutes, and try to start it up again, it will fire straight away and then die. Eventually it will fire and stay alive but just barely. It's really confusing.
                              I've tested the AFM and TPS and they seem fine. The temp sensor is <3 years old. I did a smoke test and that didn't reveal anything major (just a decent sized leak from the bitch tube but I don't think that would be causing these issues). We tested the fuel pressure and it was showing really low so I think something may have been wrong with the test set up so I'd like to redo that. The injectors are cleaned/flow tested M50 ones that are only a few years old. However I did order a new Walbro 255 because I do need it for the swap anyways. That should be here sometime this week, I hope. Other than that, I got new spark plugs, fuel filter and engine bay fuel hose (even though I redid that like 2 years ago... stupid cheap AutoZone fuel line). If the fuel pump doesn't fix this I'm going to be seriously puzzled...
                              • Sh3rpak!ng
                                • Jan 2014
                                • 2667
                                #1620
                                Regarding OBD1 vs OBD2, there is no reason to go OBD1 anymore. Just get the ews deleted, plus any other stuff you don't need (secondary O2s, evap, running loss valve, SAP) and it's literally plug and play and you retain all the OBD2 fault code reporting, you can use an OBD2 bluetooth adapter - great stuff
                                Looking forward to swap progress!
                                Shadetree30
