5Toes 5er
This topic is closed.
  • twolitresix
    • Jan 2013
    • 21
    #301
    Nice and corrosion free headlights! Wish mine were like this... Did you clean your projector lenses too? They look foggy. I cleaned mine with glass cleaner, light output like... quadrupled :D
    • 5Toes
      • 9836
      #302
      ^ good sir. That pic of them on the counter is actually prior to going in the dishwasher.
      After dishwashing I removed projectors and clenaed low beams very good with rubbing alcohol. I also cleaned the projectors. I cant wait to put them in later this week!
      • TheTacoMan
        • Nov 2011
        • 2308
        #303
        Nice head lights, and nice corrosion free hood. Oh wait.
        • e30austin
          • 15382
          #304
          LOLOL
          James....we"re waaaaaaaitinggggggg
          • twolitresix
            • Jan 2013
            • 21
            #305
            Wao. They already look like new (compared to wintersalt-sesoned ones).
            Originally posted by TheTacoMan
            Watching this made me feel uncomfortable.
            • TheTacoMan
              • Nov 2011
              • 2308
              #306
              • 5Toes
                • 9836
                #307
                UPDATE :(
                I installed some rebuilt fuel injectors from MEPEH here on r3v (he did great work and I recommend him!)
                Right after the install the car throws a CEL for the camshaft position sensor. I found the sensor on ebay for a great price (facet brand new old stock) and should be installing it when it arrives, as well as fix my oil filter housing leak.
                I am undecided if I want to remove the intake manifold for these projects, but it definitely would help if I did! I think with the oil fitler housing out of the way Ill have enough room.
                • 5Toes
                  • 9836
                  #308
                  So I jumped the gun on the sensor... turns out all my new injectors needed was a DME reset.
                  Clocked 31mpg average on the interstate over a course of 45 miles today :) Also picked up a 70,000 miles ZF320 and some new-to-me tires.
                  220,800 miles and running strong! I am sending out my UOA (used oil analysis) this week with my liquimoly... will post results here on the forum.
                  • 5Toes
                    • 9836
                    #309
                    Update - got my smileys installed and learned how easy it is to take the bumper off :) even for one person it was a breeze.. I even used the OEM lugwrench tool to get the 4 nuts off ahahahahaha. Looking like a drift missle.
                    Pics of my new ZF320 :)
                    Pics of the smiley install. I used new connectors but junkyard pigtails. I saved roughly $50 this way. The pigtails can be found on every connector that uses this style, I grabbed the 90 degree ones mainly off e36 foglights and windshield washer pumps.
                    The high beams:
                    And the lows:
                    I cut the sealed beam connectors off, and then cut my pigtails to roughly the same length:
                    Brown is ground so just follow the colors like I did here:
                    I didnt get pics of the rest but basically just splice them in on car.
                    I wired my city lights through the sidemarker connectors and disconnected the lead for the sidemarker running lights - though now the OBC tells me the "parking lamp" failure so I need to clean it up.
                    They sure are pretty though!
                    And a pic of my new toolbox!
                    • Dj Buttchug
                      • Jun 2010
                      • 7680
                      #310
                      bitchin!
                      Turbo M42 Build Thread :Here
                      Ig:ryno_pzk
                      I like the tuna here.
                      Originally posted by lambo
                      • 5Toes
                        • 9836
                        #311
                        I should also add I got my new federal 595s mounted up on my rear wheels. 235/40R17s on 17X9 - it is my idea of perfect stretch.
                        • F34R
                          sLaughter
                          • 12376
                          #312
                          Why are you swapping to a 5spd? I am sure you know you have only one leg right? Don't setup some contraption when it is designed for two leg operators.
                          Instagram: @BWeissLeather
                          Current cars:
                          ~ '87 325 M30B35 swap
                          ~ '87 535
                          ~ 01 540 Msport 6spd
                          ~ '06 X5 4.8is
                          • 5Toes
                            • 9836
                            #313
                            Im swapping to a 5 speed to make my car more reliable
                            • F34R
                              sLaughter
                              • 12376
                              #314
                              How are you going to drive it with one leg? You know there is three pedals right?
                              Current cars:
                              ~ '87 535
                              ~ '06 X5 4.8is
                              • LJ851
                                • 7919
                                #315
                                Im swapping to a 5 speed to make my car undriveable
                                fixed
                                Lorin
                                The M30 is God's engine.
