5Toes 5er
This topic is closed.
  • Ryann
    • 3350
    #376
    Those brushes are 'Toes'd. Pic of the slip rings?
    • not5toes
      • Nov 2013
      • 30
      #377
      the slip rings are the part that the brushes are in close proximity to - on the shaft of the stator assembly right? I am unfamiliar with these things.
      if my slip rings check out gonna slap on a new voltage regulator and call it good.
      EDIT - went and checked out the slip rings. They look to be evenly worn and in good condition - no oxidization or anything.
      • Ryann
        • 3350
        #378
        New regulator/brush assy. and you should be good to go unless you cooked a diode.
        • not5toes
          • Nov 2013
          • 30
          #379
          Thats the plan - just emailed blunt.
          Removed the oil filter housing assembly today too and will give it a good cleaning tomorrow. Super easy job with the intake off.
          I hate that my car let me down, but I love how easy it is to work on!
          So this issue turned into:
          new voltage regulator and alternator cleaning
          oil filter housing seal and cleaning
          all new fuel lines in engine bay
          guess its a good thing after all <3
          • not5toes
            • Nov 2013
            • 30
            #380
            Reinstalled oil filter housing today. I cleaned it up very nicely and made sure to blow it out with compressed air good.
            The grooves for the seal I laid a bead of threebond in, then pressed the gasket in and applied another thinner bead of threebond. I used threebond 1194.
            Installed it on the engine and observed a nice pushout if the threebond. Its gonna have 24 hours to set so it shouldnt leak anymore :)
            • Nick_S
              • Apr 2011
              • 3658
              #381
              Had almost identical symptoms on my E30 last year. Ended up replacing the voltage regulator and hasn't had an issue since. Hope it's that simple for you.
              91 318is M50 swapped
              05 Honda Pilot
              24V swap thread
              • not5toes
                • Nov 2013
                • 30
                #382
                Hooray! Got her all back together and she fired right up and battery reads 14.2votls at idle. Mission accomplished!
                Im stoked, time for a drive
                • AbsorbantNut
                  Non faccio funzionare questa merda
                  • Jun 2010
                  • 2491
                  #383
                  Just realized 5toes is not5toes
                  '73 2002 m20 turbo [sold] '87 rat rod 325is [couch modded] '91 vert [daily] '88 325is [spec build v1] '84 325 [spec build v2] '99 323i vert [sold]
                  • TheTacoMan
                    • Nov 2011
                    • 2308
                    #384
                    Originally posted by LJ851
                    ^ It's the rusted hood causing all your problems.
                    Originally posted by not5toes
                    It really isnt.. I am looking for some solid help. Not bullshit, not games, not trolling.
                    That said, I did get the intake manifold off in 45 minutes without breaking anything out in the cold ahaha
                    • Dj Buttchug
                      • Jun 2010
                      • 7683
                      #385
                      that rusted hood cost you some 8,000 posts
                      those feels brah.
                      glad to see youre back
                      Turbo M42 Build Thread :Here
                      Ig:ryno_pzk
                      I like the tuna here.
                      Originally posted by lambo
                      • not5toes
                        • Nov 2013
                        • 30
                        #386
                        the rusted hood is receiving some graffiti soon
                        • george graves
                          • 20003
                          #387
                          Oh 5toes.....Why...I told you to stop being such a spaz.
                          Originally posted by Matt-B
                          • slammin.e28
                            שמע ישראל
                            • 12054
                            #388
                            those feels brah.
                            Oh BAHAHAAAHAHAH!
                            • not5toes
                              • Nov 2013
                              • 30
                              #389
                              Well the oil filter housing gasket no longer leaks - but the one plug near the oil pressure sensor does :( Pretty badly too... looks like I will need to remove the housing again :(
                              Just like here: http://forums.bimmerforums.com/forum...eak-how-to-fix
                              I plan on getting some orings and taking care of it. Any input?
                              • not5toes
                                • Nov 2013
                                • 30
                                #390
                                Got the oring, got the circlip off, lost the circlip, removed the alternator and found said circlip next day, tried to install it again, had it 95% then it popped out and is lost AGAIN. Im getting sick and tired of this car.
                                grrrrrrrr. picknpull only had the updated filter housing with the hex plugs. So I bought it for $10 and am opting to use a new gasket. Car is probably gonna be down till Tuesday. fml.
                                I am gonna take a hose and try to spray this side of the engine down and see if it flushes out... other than that I give up finding it again.
