Bagged E30, S52 swap, never ending build - Shaved bay + more
  • NickL
    • 562
    #121
    Originally posted by bmwandhonda
    Your car is amazing, one of the best I have seen out there. Will be even better when the bay is finished off. Looking forward to the 'finished product'.
    Thanks man, if thats your touring in your sig I'm extremely jealous.
    After this it won't be cell phone pictures anymore haha I found my camera charger.
    Wire tuck/brake line tuck is all done along with abs delete.
    Trailered the car to my buddies shop where the metal work will be done and the bay will be resprayed. In the mean time, Ill be going back through the S52 and refreshing it a bit, along with sending some parts to powder coat.
    Next update will be some metal welded into the bay :popcorn:
    1987 325is - S52
    • e30lov
      • Jul 2008
      • 1597
      #122
      Cant wait to see what you have in store for next season :)
      `92 325 vert - `90 325 coupe `99 m3 - Instagram @e30L
      • NickL
        • 562
        #123
        Some progress
        1987 325is - S52
        • dillon7
          • Mar 2013
          • 824
          #124
          sorry for the dumb question but where do the brake lines go? and guessing you did the power steering delete as well?
          Instagram: @dillonmakar
          Build thread HERE
          • NickL
            • 562
            #125
            Both of those pictures are a bit older so theyre still in stock location and the master isnt on the firewall. Currently the passenger side runs along the subframe over and up the driver side frame rail to the prop valve. The drivers side just goes out the side of the prop valve and into the oem location.
            Instead of coming through the fender well it comes underneath now because a plate will be welded there to mold where the batter tray used to be, into the frame rail. Hard to invision but ill snag a picture of what it all looks like.
            1987 325is - S52
            • logyt
              • Aug 2012
              • 176
              #126
              I love your e30, so much good work going on here.
              my e30
              http://www.r3vlimited.com/board/show...=274651&page=3
              • NickL
                • 562
                #127
                Progress.
                Fresh paint on the block/head/accessories. Began wrapping my headers. (Ignore the fact that I put the rear header on the front lol)
                1987 325is - S52
                • Nick_S
                  • Apr 2011
                  • 3655
                  #128
                  christ that engine is clean.
                  91 318is M50 swapped
                  05 Honda Pilot
                  24V swap thread
                  • JCarp90
                    • Feb 2011
                    • 1759
                    #129
                    This is why I wish I would have painted my S52 lol.
                    • DER E30
                      • Sep 2013
                      • 2349
                      #130
                      I can't tell if you've reinforced your engine mount tabs on the subframe, but if you haven't I would suggest doing it now while you have the motor pulled... I spent like 10 hours last week fixing my subframe tabs after my oil pan was sitting on the steering rack... The tab broke off in my hand, and I have a lowly M42... :rofl
                      -Christian
                      • NickL
                        • 562
                        #131
                        Haha thanks man.
                        You should, it looks great in the bay.
                        I haven't yet, but was definitely something I was considering.
                        1987 325is - S52
                        • NickL
                          • 562
                          #132
                          Drivers side coming together
                          1987 325is - S52
                          • nyChris
                            • Apr 2012
                            • 395
                            #133
                            Do you have any concern that the bondo will crack on the seams of the strut tower? They definitely flex a bit under load, which may, or may not cause the bondo to crack.
                            Just thinking out loud. Always thought this was one of the most proper early models. Good luck with bringing it to the next level
                            • NickL
                              • 562
                              #134
                              I'm not worried about it. The filler being used isn't bondo and is super durable. We've smacked it with a hammer and it didn't crack in multiple places so I'm hoping it'll hold up in the stressful areas. Plus around the strut towers it's laid pretty thin
                              Appreciate it man.
                              1987 325is - S52
                              • lambo
                                Captain Scene Points
                                • 10953
                                #135
                                How do you have your air tank setup?
