E30 M3 touring with S62 power
  • DaveG
    • Nov 2011
    • 40
    #106
    Bit more progress
    Final cut on door to fit quarter to door
    Lots of welding making sure that panel doesn't heat up. Keep moving around and take a break often
    Bit of grinding
    Blended in well
    Bit of primer
    Final trimming and cleaning up for wheelwell
    Wheelwell in and quarter plug welded to it
    Old standard wheelwell for comparison
    Looking towards rear
    All tacked up
    Still a bit of work to be done to match up the pocket
    Corner worked out very well
    Now to fill some gaps
    And here
    On the 2 tourings I've seen that have been converted before a filler piece is used between the door and the m3 quarter like this
    And on the closing panel the same thing
    Get the door gap nice and even
    Then loose the plot :D
    To be continued ........
    • henryki
      • Jun 2013
      • 960
      #107
      Ohhhhh my... I just had a massive crisis in my pants just going through this thread. Keep up the good work and I can't wait to see the finished product!
      • DaveG
        • Nov 2011
        • 40
        #108
        A bit of an update again
        Here is the reason for the wild cutting the last day
        A bit more cutting for good measure
        Cut a piece from a breaker to move out the door shut
        Door closed
        Same thing on door
        Move out door edge also
        Happy with that
        Now to move out the sill to line everything up
        Drill out spot welds
        And cut the rest out
        Part I cut from the m3 quarter before
        And do some more cutting for a change
        The bottom of the door shut is curved in as standard so a good bit of hammering is required to get it to Match the shape of the m3 quarter
        Not perfect but it's fairly close. Can build it up with some weld after
        Another piece of the puzzle
        Coming together
        Due to straightening the shut edge the corner piece was shaped the wrong way
        So cut again
        Make a piece to fit
        And
        Shaping up
        From the outside
        • Der Ruffian
          • Dec 2012
          • 697
          #109
          Awesome..
          You're becoming quite familiar with the welder :-)
          #ShenanigansE30 1989 Touring AC Schnitzer S3 replica http://www.r3vlimited.com/board/showthread.php?t=320784
          Ruffian 1987 318is 2 door Hartge project http://www.r3vlimited.com/board/showthread.php?t=290863
          Natalma 1990 Touring AC Schnitzer S3
          #GlorianaE28 1986 525i
          #AnniePowerE34 525i 3.2 M50 with AC Schnitzer S5 parts
          • delamaize
            • Nov 2013
            • 1463
            #110
            Hory sheet. Epic work man....
            Sub'd...
            Dumpster Fire Pilot
            • CubbyChowder
              • Mar 2012
              • 1488
              #111
              Now THAT is attention to detail. Making perfections in places where most people wouldn't even notice it. This is a very respectable build, you are doing incredible work. Keep it up!
              --Roundie Revival 2.0 - 1973 BMW 2002 Build Thread--
              --Golden Boy E30 Build Thread-- (sold)
              • stoja e30
                • Apr 2013
                • 123
                #112
                wow...........
                89 325i 4 door - current project
                88 325 V8;D - next project
                my 325 build
                M20B27i FORSALE maimi fl
                • DaveG
                  • Nov 2011
                  • 40
                  #113
                  Thanks very much for all the great comments. Keeps me going :D
                  • henryki
                    • Jun 2013
                    • 960
                    #114
                    Just wow. Can't wait to see this finished! Keep up the good work very jealous...
                    • rzerob
                      • Jun 2013
                      • 2315
                      #115
                      Subscribed
                      • E30 Wagen
                        • Jul 2005
                        • 3434
                        #116
                        Excellent work! I think this will be the best four door with ///M panels yet.
                        My Feedback
                        • Nick_S
                          • Apr 2011
                          • 3658
                          #117
                          christ man, your fabrication skills are on point. Nice work!
                          91 318is M50 swapped
                          05 Honda Pilot
                          24V swap thread
                          • E30_Pare
                            • 7801
                            #118
                            i suck with metal work. inspired/subbed
                            DREWLIENTE
                            1$ PShops PM me
                            • dirtbag30
                              • Apr 2013
                              • 678
                              #119
                              wow that sheet metal work is awesome, cant wait to see it done.
                              i have no idea what i am doing with my life
                              • DaveG
                                • Nov 2011
                                • 40
                                #120
                                Another few bits done
                                Need to complete this corner
                                First
                                Then some new steel cut to fit
                                Bit of welding
                                Another bit of door done
                                Bottom
                                Few small pieces completed
                                Bit of new steel cut and shaped to fill in on the door.
                                Tacked in
                                Rear quarter welded in completely. Kept its shape extremely well
                                Time to tackle the rear pocket
                                Out with my old friend mr angle grinder again
                                Make up a piece to fill the gap and try and follow the shape of the quarter
                                All welded up
                                And ground down
                                Happy with how it came together
