325ic Calypso Euro Conversion - Houndstooth & dbilas now, MT1 & MM 3.2 stroker coming
  • audiquattrot
    • May 2008
    • 3836
    #286
    Oh Man U took it to the next level w the Alpinas! They look so perfect on ur car. I need to change the tires on my Alpina soon....might go stickier on them this time around since I won't be putting a ridiculous amount of miles on it anymore
    www.instagram.com/snwmble
    #snwmble
    Current:
    '05 BMW M3 - Silver Grey/Imola Red
    '90 BMW 325iX - Sterling Silver/Houndstooth sport(5-speed converted)
    '15 Mini Countryman - Blazing Red/Carbon Black
    Past:
    '01 Audi Allroad - Light Silver/Platinum Saber Black
    '88 BMW 325iX - Diamond Schwarz/Silver sport *Sold*
    '01.5 1.8TQ - Brilliant Black/Nogaro Alcantara ...after 8.5yrs, *Sold* =(
    '90 BMW 325i - Schwarz/Tan sport *Sold*
    '89 BMW 325ix - Diamond Schwarz/Black sport *Sold*
    • jeffnhiscars
      • Jun 2011
      • 6011
      #287
      The absence of a 6 cyl plenum is what has kept me from putting the RHD itbs on my grocery list but I'm only seeing plenums for 4 bangers on Ramas web site. Are they FS at the moment ?
      Alice the Time Capsule
      • bradnic
        • Jul 2012
        • 3554
        #288
        yup they're for sale RIGHT NOW. Just swapped email with him.
        HOWTOs:
        DB vert plastic bumpers
        OEM Keys
        MTech1 docs
        88 ix Lach/Card
        91 ic Calypso 3.1
        86 Cosmo 2.7
        OEM+ or bust!
        • bradnic
          • Jul 2012
          • 3554
          #289
          Well I'm running rapide30ic's direzzas but that car hasn't moved since I mounted them lol. they have a lower wear rating than my S-Drives and a pretty aggressive tread pattern - lots of rubber on the road. So fwiw they really LOOK sticky lol.
          Still have to seal the large DB bumper openings.. and my MT1 rear is for 325i so slanted exhaust.. will probably move the strömung to my IX.
          2017 EDIT: Exactly what I'm gonna do now that I have a slanted tip Strömung to replace this one.
          HOWTOs:
          OEM Keys
          MTech1 docs
          88 ix Lach/Card
          91 ic Calypso 3.1
          86 Cosmo 2.7
          OEM+ or bust!
          • bradnic
            • Jul 2012
            • 3554
            #290
            Originally posted by e30rapidic
            do me a favour. Find me at The Vintage to say hello....but don't park you car anywhere near mine LOL. 8)
            But seriously, it is looking awesome.
            you crack me up. my paint job definitely needs a redo so you have nothing to worry about. was actually gonna try parking right next to you... Alpinas, euro, HLCS... I think they'd look great side by side.
            HOWTOs:
            OEM Keys
            MTech1 docs
            88 ix Lach/Card
            91 ic Calypso 3.1
            86 Cosmo 2.7
            OEM+ or bust!
            • bradnic
              • Jul 2012
              • 3554
              #291
              Sorting the hose puzzle to get this damn thing started up
              Capturing all the key details on the hose setup. really want to get this running today..
              Easy bits
              - I need to seal off the TB heater hose lines, one to the thermostat housing, one to the back of the head, 11mm fittings on both.
              - Replace fuel feed and return hoses for longer versions, 8mm fittings (one of the hoses is original anyway)
              Stock vacuum connections
              - 4mm FPR to pass side of intake (small hose)
              - 22mm ICV in from intake, post AFM
              - 22mm ICV out to TB, after throttle
              - 12mm TB to brake booster via check valve, after throttle
              - 8mm fitting, TB to carbon canister via fuel tank vent valve, also after throttle
              - 22mm valve cover vent to 14mm fitting on TB, before throttle
              dbilas vacuum connections
              - 1 12mm fitting lower side of itb manifold by cyl 6, after
              - 1 24mm connection for PCV valve cover outlet
              - 1 12mm fitting on plenum bottom between cyl 4 and 5
              - 3 10mm fittings, 1 each on bottom of each ITB pair, after throttle
              - 2 4mm connections on top each ITB pair, after throttle
              lower ITB fittings
              rear of engine showing the rear block coolant line fitting and both fittings on the manifold adapter and rear ITB
              HOWTOs:
              OEM Keys
              MTech1 docs
              88 ix Lach/Card
              91 ic Calypso 3.1
              86 Cosmo 2.7
              OEM+ or bust!
              • bradnic
                • Jul 2012
                • 3554
                #292
                So this is the plan then based on the above
                - make an AFM gasket
                - cap off the 2 coolant fittings for the TB heater hoses
                - replace both fuel hoses
                and on the vacuum side, keep valves, replace all hoses and clamps, adapt hoses with fittings as needed based on the sizes mentioned above
                - FPR to ITB top fitting (sp33dy teed this to both connections on an ITB pair and it improved his high rpm fuel delivery).
                - plenum lower fitting to ICV in
                - ICV out to ITB manifold fitting underneath
                - ITB lower fitting to brake booster check valve, and to booster
                - ITB lower fitting to fuel tank vent valve, and on to charcoal canister
                - Cap the remaining lower ITB fitting
                HOWTOs:
                OEM Keys
                MTech1 docs
                88 ix Lach/Card
                91 ic Calypso 3.1
                86 Cosmo 2.7
                OEM+ or bust!
                • doorman
                  • Mar 2015
                  • 360
                  #293
                  Don't forget some mad stance, drifting, hella flush, Instagram, snapchat, broken oil pan or angel eyes related stuff!!!!
                  Keep up the good work otherwise!
                  Crappy day for a test drive. Those IX weaves pan out for you?
                  • bradnic
                    • Jul 2012
                    • 3554
                    #294
                    haha not happening but you know that already lol
                    those IX weaves were sold before I could get to them unfortunately..
                    got all the hoses and fittings I need. assembling everything now.
                    EDIT: cool 2k posts yay
                    HOWTOs:
                    OEM Keys
                    MTech1 docs
                    88 ix Lach/Card
                    91 ic Calypso 3.1
                    86 Cosmo 2.7
                    OEM+ or bust!
                    • doorman
                      • Mar 2015
                      • 360
                      #295
                      Sigh.......maybe in the next build!
                      I noticed the CL add was down and thought you scooped them up already!
                      I have three tabs on my phone that I check everyday. 4x100 rims, e30 parts and E30s for sale.
                      2000 posts.....that qualify as good or bad?;)
                      • bradnic
                        • Jul 2012
                        • 3554
                        #296
                        Depends on who you ask I suppose :-) clearly I spend a lot of time here
                        HOWTOs:
                        OEM Keys
                        MTech1 docs
                        88 ix Lach/Card
                        91 ic Calypso 3.1
                        86 Cosmo 2.7
                        OEM+ or bust!
                        • e30rapidic
                          • 2167
                          #297
                          My paint is original single stage so its a struggle, maybe one day i'll repaint it?!
                          I think that would be awesome to park side by side...will make for some cool photo ops. :coolphoto:
                          '87 325ic, powered by S50.
                          • bradnic
                            • Jul 2012
                            • 3554
                            #298
                            hose work completed.. home stretch
                            got out the oetiker pliers and made this bad boy.
                            also put an ICV line together using 3 sizes of hose, the old ICV bent hose to the TB and a piece of washing machine drain tube :-)
                            all hoses are installed except for the lower end of the fuel lines. coolant lines capped as well.
                            remaining before 1st start
                            - remount the plenum
                            - lower fuel line fittings
                            - mounting for service connector, dipstick and ITB
                            - assemble airbox and M30 AFM.
                            then attach the throttle cable and pray the tune works lol
                            EDIT: Here's both the hose assembly above and the ICV hose assembly installed
                            HOWTOs:
                            OEM Keys
                            MTech1 docs
                            88 ix Lach/Card
                            91 ic Calypso 3.1
                            86 Cosmo 2.7
                            OEM+ or bust!
                            • sonomabimmers
                              • Dec 2015
                              • 802
                              #299
                              just read most of this, inspiring to say the least. cheers to another calypso vert owner!
                              i love bmws
                              • bradnic
                                • Jul 2012
                                • 3554
                                #300
                                thanks.. just take one step at a time.
                                put up a post with pics of your ride...
                                Well she's running. close, but not drivable yet. rough as hell, and doesn't accelerate when you pull the throttle. seems like fuel shortage. i have the fpr vacuum going to one of the ITBs. gonna try moving it to a shared tee i have in the harness (you can see it in the hose assembly pic in the middle). running an ssquid tune for m20 2.5 with m30 afm and 19# injectors.
                                also can't seem to get the airbox to work with this setup. will probably have to switch to a cone filter as there isn't enough room to mount the thing.
                                will post some pics tomorrow and assume I'll sort the engine issues out without too much agony. still have to install the accelerator cable to the pedal as well.
                                HOWTOs:
                                OEM Keys
                                MTech1 docs
                                88 ix Lach/Card
                                91 ic Calypso 3.1
                                86 Cosmo 2.7
                                OEM+ or bust!
