First OFFICIAL TWINCHARGED M20 BUILD
  • Denny
    • Jan 2010
    • 822
    #121
    Originally posted by kamotors
    aside from the oil filter how was the manifold fitment
    yeap great fitment. So far so good...
    Denny
    ___________
    1990 BMW red 325IC M30B35 all stock Girlfriends ride
    1991 BMW black 318IC (M62b44 Megasquirt 2 ver 3.57)
    Blogs:
    http://bmw325e30.blogspot.com/ (restoration)
    http://bmw325e30turbo.blogspot.com (Twincharge M20)
    http://bmw325e30m62b44.blogspot.ca/
    • Denny
      • Jan 2010
      • 822
      #122
      making room for the new turbo... cut some useless brakets.. push my EPS further to make room for air filter
      I just put a used filter temp on the pipe at the other end so no debrie would go in..but that pipe is going to connect to the turbo.
      shot of the intercooler
      another shot so you can see that the filter now hits the manifold... anybody have a spare filter adapter I can buy from?
      and just a quick shot of the turbo (still needs to be turned the correct way for the oil feed/drain and air outlet
      more to come...
      Denny
      ___________
      Blogs:
      • JCarp90
        • Feb 2011
        • 1759
        #123
        I've been following your build - but have not commented for fear of proving myself retarded.
        This. Is. Sick. Can't wait to see it all up and running.
        • downforce22
          • Aug 2009
          • 3191
          #124
          can't you use the stock filter adapter? Or do you need it for your oil feed?
          • Denny
            • Jan 2010
            • 822
            #125
            No man... only comments I dont want are the imature bring me down useless ones that take space ...everything else is very very welcome :)
            Cant wait to have it all done...never drove a twincharged car before but I think its going to be a one of a kind SICK daily driver!!
            I lost the one that came with the engine :( but I would so need one right now... the kit comes with a clever sandwich adapter that provides for the oil inlet to turbo...but unless I have the stock oil filter adapter that does a 90 degree bend so my oil filter sits behind the manifold am SOL right now...:(
            Denny
            ___________
            Blogs:
            • decay
              • 5637
              #126
              Originally posted by evandael
              quick question though.. you keep saying you'll only have the turbo wastegated at 8 psi.. won't it need to spool to 20psi to attain your goal 20psi manifold pressure? i don't know much about twincharging but i didn't think boost pressure could be added cumulatively (like in a twin turbo system, two turbos spooling to 10psi each =/= 20psi total..)
              substitute pressurized air for electrons, and then think about this as a metaphor for series or parallel circuits- can be done either way.
              twin-turbo rx7 is a common example, like you're thinking of; that's "parallel".
              lancia delta s4 is "series"- turbo's compressor outlet pipes to blower inlet.
              past:
              1989 325is (learner shitbox)
              1986 325e (turbo dorito)
              1991 318ic (5-lug ITB)
              1985 323i baur
              current:
              • FLG
                • Sep 2011
                • 3165
                #127
                Just use a smaller filter off an m42 I think? I had one for awhile, no problems.
                Could also tee your turbo oil inlet off the stock oil pressure sender outlet.
                I wound up running a trans dapt relocation kit to a Ford temp controlled sandwich plate to an oil cooler and a wix 51515 filter
                Sent from my Galaxy Nexus using Tapatalk 2
                -Build http://www.r3vlimited.com/board/showthread.php?t=295277
                • Denny
                  • Jan 2010
                  • 822
                  #128
                  well put!
                  In my case I am doing the exact same thing as (lancia delta s4 is "series"- turbo's compressor outlet pipes to blower inlet.)
                  Denny
                  ___________
                  Blogs:
                  • Denny
                    • Jan 2010
                    • 822
                    #129
                    Cool! I will check that alternative out,thanks!
                    Denny
                    ___________
                    Blogs:
                    • FLG
                      • Sep 2011
                      • 3165
                      #130
                      Sorry believe it was an s14 filter that is short and fits.
                      • Denny
                        • Jan 2010
                        • 822
                        #131
                        ok thanks! I just remembered the oild filter I removed and didnt fit was an even smaller filter then stock (because it didnt fit the headers) and its from a 80's V6 toyota Camry. So I would have to compare the size of the S14 to the one I have but unless its really shorter with the sandwich adapter it wont fit.. :(
                        Denny
                        ___________
                        Blogs:
                        • decay
                          • 5637
                          #132
                          intuitively, that way makes the least sense to me, but it seems to be the way that makes power. maybe you'll teach us why :)
                          past:
                          1985 323i baur
                          current:
                          • Denny
                            • Jan 2010
                            • 822
                            #133
                            Yeah I did a lot of research and at first I tough the VW TSI engine model was the way to go SC feeding the turbo inlet...BUT then I saw the Lancia S4 :) read the theory around it and the new hellion ford mustang twincharge systems and it all made sense to go this way and this way you dont loose any of the 2 power adders strong points with the added bonus of the SC making 1 extra Liter of exhaust gas to spool the turbo even faster.
                            Cant wait to see the end results...
                            Denny
                            ___________
                            Blogs:
                            • Denny
                              • Jan 2010
                              • 822
                              #134
                              s14 filter is the same size as the small camry filter :( wont fit at all unfortunatly.
                              thanks for those who PM'd me with offers to sell me a filter adapter..I bought one from member "e30euro" should have it soon.
                              I will wait to install it before installing exhaust manifold...so I will attack other parts of the build until it arrives... Exhaust system, turbo air pipes...
                              Denny
                              ___________
                              Blogs:
                              • darvo
                                • Dec 2010
                                • 407
                                #135
                                In car video,2nd gear 2k rpm pull!! ;)
