First OFFICIAL TWINCHARGED M20 BUILD
  • Denny
    • Jan 2010
    • 822
    #136
    Originally posted by darvo
    In car video,2nd gear 2k rpm pull!! ;)
    Denny
    ___________
    1990 BMW red 325IC M30B35 all stock Girlfriends ride
    1991 BMW black 318IC (M62b44 Megasquirt 2 ver 3.57)
    Blogs:
    http://bmw325e30.blogspot.com/ (restoration)
    http://bmw325e30turbo.blogspot.com (Twincharge M20)
    http://bmw325e30m62b44.blogspot.ca/
    • MT325is
      • May 2012
      • 1103
      #137
      damn, all i am is speechless. and im glad the cx racing kit worked out for you. Ive known a few people that had those and said they worked good. Keep up the good work man, cant wait to see the end result!
      1989 BMW 325is (SOLD)
      1992 BMW 325IC (SOLD)
      1991 BMW 318IS (STOLEN!)
      2017 BMW M2 (WEEKEND WARRIOR)
      1989 BMW 325IC (PROJECT(
      2002 FORD ESCAPE (DAILY)
      • Denny
        • Jan 2010
        • 822
        #138
        Thank you :) I'm very pumped with this project I cant wait to drive it and to finally race it at the local 1/4 mile strip in the spring/summer. Still got lots of work but I should have it fired up for idle tuning in a few weeks.
        Denny
        ___________
        Blogs:
        • Cronopoulos
          • Jul 2011
          • 2187
          #139
          Are you done yet? :P
          Project log -- DIRTY 30
          2.7i * Megasquirt tuned * E85 powered
          • Denny
            • Jan 2010
            • 822
            #140
            Originally posted by cronopoulos
            are you done yet? :p
            lol :)
            Denny
            ___________
            Blogs:
            • Denny
              • Jan 2010
              • 822
              #141
              I got the full exhaust out of the car, got the new one in place for install but looks like I will have to make my own rubber hangers it wont be hard. Reworked the Supercharger Inlet to take boost (before twincharge it only saw vaccum duty).
              -Received my oil fliter adapter from member "e30euro". All I need to figure out is how to block the 2 BIG bolt holes (I removed the oil cooler) on it.
              Tonight I got time a side to work on it for a few hours I should have some update pics tonight! My calculations tells me I should be ready for first start by mid-end of February :)
              Tonight am working on it
              Denny
              ___________
              Blogs:
              • ADlBOO
                • 335
                #142
                Updates? Cant wait to see this running!
                I have friends who are EOD bro.
                That's awesome. I have friends who make coffee for a living, but you don't see me rocking out a bunch of lattes
                • jute91
                  • Nov 2011
                  • 581
                  #143
                  why are you using supercharger to flow into turbo? would that be better when both would flor straitght to manifold? here is how i would do it http://www.youtube.com/watch?v=KRhl182UAGY
                  raw diesel power :D OM606 with Eaton m90 + Garret gt40
                  same setup in e30 http://www.youtube.com/watch?v=uDK3K2TlAWs
                  Also found on Facebook - Juuso Tero, Tampere
                  https://www.facebook.com/JuusosGarage
                  • F34R
                    sLaughter
                    • 12376
                    #144
                    Something amazing to inspire you. Going to dyno it?
                    P.S. Anyone know the color of the Lotus?
                    Instagram: @BWeissLeather
                    Current cars:
                    ~ '87 325 M30B35 swap
                    ~ '87 535
                    ~ 01 540 Msport 6spd
                    ~ '06 X5 4.8is
                    • darvo
                      • Dec 2010
                      • 407
                      #145
                      Originally posted by Denny
                      When you finish, an in car video pull from low rpms, to see how responsive it is, would be badAss
                      • Denny
                        • Jan 2010
                        • 822
                        #146
                        After a lot of research the way to make serious power was to go like the lotus in the video (thanks for the link) and the Delta S4 lancia. I will dyno it at a local shop here to tune the timing and tweak the fuel :)
                        I will for sure have some REAL videos of inside and outside as am going to the track so speed is legal there :) am planning on on some slicks as traction is going to be crazy (I had serious issues with my 225/50 with 10PSI of supercharged boost) the low end torque transforms the car into a muscle car.
                        sorry for the long wait time on an update life got in the way lol....
                        UPDATE**
                        Update Project is going forward nice and slow... working on the turbo side of my setup.
                        Received and regasket the oil adapter, welded bolts (dont have a oil cooler), installed turbo oil inlet sandwich
                        clocked it so it fit under the header..
                        manifold installed...bolt holes had to be enlarged as it didnt fit but was very close ...no big deal
                        38mm wastegate installed fitting ready for intall...
                        her it is install with the fitting pointing in right direction.
                        I installed the turbo temp so to clock the housing properly ....
                        installed filter and I will need a 90degree coupler to join the turbo outlet and pipe...
                        so far so good still lots of work but its coming along like I promised a twincharged M20 by spring so stay tuned...
                        Denny
                        ___________
                        Blogs:
                        • JCarp90
                          • Feb 2011
                          • 1759
                          #147
                          Ooooooooooooh giggidy
                          • downforce22
                            • Aug 2009
                            • 3191
                            #148
                            Nice. I heard using couplers cut thin for mufler hangers was good haha. I am interested in both the manifold and the non oil cooled engine temps. I would think cooler oil would be better for the turbo inlet and I would think they would have fit with your manifold, but too late for that I guess!
                            • Denny
                              • Jan 2010
                              • 822
                              #149
                              :) just as excited a you...cant wait to drive it.
                              Im going to use 3/4 inch hard rubber cut in big rectangle with 2 slots and it will be better then OEM. The oil cooler would probably help if I was lapping all day for sure....but as a sunny day DD and short bursts at the strip kind of car I should be fine. Plus with my intercooler and turbo pipe not much space left.. :(
                              Denny
                              ___________
                              Blogs:
                              • TheTacoMan
                                • Nov 2011
                                • 2308
                                #150
                                WOO!
                                Cant wait to see this done, is there an ETA?
                                You will also have to let me know how you like that turbo, Im looking into the same turbo setup.
