Retrofitting An Airbag To An E30?
  • EricAkaAviator
    • Oct 2012
    • 34
    So, today I bought my Second E30... This one, a sedan... Planned to make my wife smile with it, but she'd like to see an airbag in it... Any one ever retrofit an airbag to an E30? It's an '89 (doesn't have the bag option) and is in awesome shape.
    Fill me in folks, let's make my wife an E30 lover!
  • James Crivellone
    Head Janitor
    • 6305
    The NHTSA recommends replacing all airbags I think every 15 years (although nobody ever does)
    The E30 system is first generation, and was clearly an afterthought when they installed them into the car.
    Technically you need to swap over the collapsible steering column, knee bolster, swap over the electronics, sensors, airbag itself.
    100% not worth it, plus if any insurance company found out you installed your own airbag they would probably go ape shit. Remember according to the VIN it never had one, so if (god forbid) she gets into an accident and the airbag you installed blows her head off I don't think they are going to have my sympathy.
    • EricAkaAviator
      • Oct 2012
      • 34
      Interesting, and well stated. Thanks for the feedback James... And the site.
      • LuckyHenriksen
        • Jun 2010
        • 4244
        X2 that was good info James. OP, it is easy enough to find a late model with an airbag if that is a requirement
        Bahama Beige E23 Project
        Bluebird Bus Conversion
        New Oregon Trail
        • camip
          • Nov 2011
          • 1253
          Just look up crashed e30 threads and show her how beat up the cars are and condition of drivers. Made me feel safer in my car.
          • Vivek
            attention whore/retard/bitch
            • 6167
            Also, most of the time if the airbag goes off, and it should have (for those both to happen is unlikely), the driver's say that the amount they felt it protected them wasn't really worth it (harsh chemicals, strong impact, loud explosion, etc.).
            1992 Mauritiusblau Vert
            2011 Alpinweiss 335is coupe
            2002 540i/6 Black/Black
            2003 GSX-R 750 (RIP)
            • TimKninja
              • 2131
              Just put the airbag wheel in the car. Tell her its all hooked up.
              Problem solved.
              1985 325e M50TU(Sold)
              1991 318is Slicktop (Sold)
              1990 325is Brilliantrot S50/5 Lug Swapped.
              1992 525i Manual shitbox Winter Beater
              • chadthestampede
                • Jul 2008
                • 3601
                IIRC the e30 airbags are pretty much a shotgun blast in the face if they even work, so it's probably not worth it.
                Originally posted by LJ851
                Feedback
                • mikeedler
                  • 6707
                  Problem solved.
                  the R3V way.
                  • USAce777
                    • 2
                    "I imagine the airbag e30's being extremely dangerous... like several seconds after a minor accident the airbag goes off and knocks the driver unconscious"
                    I think I saw this around here somewhere... I was laughing trying to imagine it..
                      • 34844
                      SRS - supplementary restraint system
                      it was originally meant for people who don't wear their seatbelts. if you wear your seatbelt the E30's ancient airbag tech isn't going to do much for you.
                      in 1990 manufacturers could choose between airbags or those horrid automatically retracting seatbelts. thank god BMW chose the airbag.
                      • bimmer630
                        • 1228
                        Bmw uses both seatbelt tensioners and airbags, still. What is a retractor?
                        • ForcedFirebird
                          • Feb 2007
                          • 8300
                          It's called passive restraint. It's the belts that attach to the top of the door so you can get out without unbuckling the belt. Some cars had the motors on them that slid down the jamb. Airbag was not required if the cars back then had these type of belts.
                          john@m20guru.com
                          Links:
                          • DÌEGØ
                            • 690
                            Yeah I think this is the consensus on the subject.
                            It's not worth it in so many levels....
                            Driving:1990 325iS, 2007 335i :devil:
                            past BMWs: 1987 325iS turbo, 1989 325i, 1995 525i, 2000 328CI, 2001 540i, 2008 135i
                              • 34844
                              look at any 1990 model year Ford.
