My E30 LS1 Drift Car
  • Jezza
    • 222
    #136
    Interior should be painted sometime this week, after the firewall is made for the back. Going with a fuel cell and tubed rear end as well.
    E-9 Motorsports
    Supported by:
    Insane Innovations LLC
    DTMFiberwerkz
    Achilles Radial
    • FLG
      • Sep 2011
      • 3165
      #137
      Jezza might I recommend against a fuel cell. It's been proven that the stock tank is in an ideal location and your actually hindering yourself with a cell.
      Sent from my Galaxy Nexus using Tapatalk 2
      -Build http://www.r3vlimited.com/board/showthread.php?t=295277
      • Jezza
        • 222
        #138
        How so? My premise is that moving weight to the rear would help with grip since this car is so light.
        E-9 Motorsports
        Supported by:
        DTMFiberwerkz
        Achilles Radial
        • FLG
          • Sep 2011
          • 3165
          #139
          The gas tank is in a really good spot, forward of the rear wheels and as low as it can be. By putting a tank in the rear behind the rear axles, its going to sit higher and also youll be dealing with a pendulum effect wanting to swing the car.
          Not to mention i assume your looking at the rear tire well for the cell? That is a crumple zone and a very bad spot for the cell unless you seriously reinforce things.
          If you wanted to go with a cell, to do it propely in these cars your looking at a ton of cash, and in the end really no benefit. Even the spec guys run a stock tank, they just upgrade small bits to deal with fuel starvation.
          Id look at better tires/air pressure/shock settings first.
          • Jezza
            • 222
            #140
            Well ill talk to Kelley and see how low he can get the cell, I don't think the height difference will be significant. As for the pendulum effect, that's for sure I don't deny it, but I believe with the increased track of wider wheels and spacers it could be beneficial during initiation and transitions. The entire rear end will be cut out so we'll talk about where we can mount it. Appriciate the input though!
            E-9 Motorsports
            Supported by:
            DTMFiberwerkz
            Achilles Radial
            • FLG
              • Sep 2011
              • 3165
              #141
              Np. Do a search I'm sure there's a few guys out there who have done it correctly. General concensus though will be to stick with the stock
              • DEV0 E30
                • Oct 2004
                • 8904
                #142
                Awesome man!
                Can't wait to see the beast under it's own power.
                • Jezza
                  • 222
                  #143
                  Firewall is done and paint has started, scion grey for the interior.
                  E-9 Motorsports
                  Supported by:
                  DTMFiberwerkz
                  Achilles Radial
                  • IronFreak
                    • Dec 2012
                    • 3702
                    #144
                    Dude!!! I love what you did with the trunk bulkhead!! I hope you don't mind but I think I will be coping you....
                    Two questions....
                    1. What is the purpose of the little pedestals that the cage is sitting on?
                    2. I see that you ran your rear supports the the spring perch, but the x-brace to the shock towers. What was the reason for this?
                    Instagram @rebellionforge
                    • Jezza
                      • 222
                      #145
                      Thanks man, feel free to do what ever you want to your car! I don't have any patents on anything ha
                      E-9 Motorsports
                      Supported by:
                      DTMFiberwerkz
                      Achilles Radial
                      • Jezza
                        • 222
                        #146
                        Big thanks to Insane Innovations in Phoenix Arizona for fabbing up this car! They are growing big and are super involved in the Achillies team in Formula Drift.
                        E-9 Motorsports
                        Supported by:
                        DTMFiberwerkz
                        Achilles Radial
                        • Jezza
                          • 222
                          #147
                          Two questions....
                          The boxes the cage sits on are required as per the formula drift rule book, and I wanted both those points in the rear to tie into the cage.
                          E-9 Motorsports
                          Supported by:
                          DTMFiberwerkz
                          Achilles Radial
                          • kalib0y
                            • Dec 2004
                            • 3620
                            #148
                            nice build!
                            95 7.1L 16V E36 M3
                            Motorsport Hardware ***Wheel studs and Spacers!!!--->FOR SALE 4/5 Lug Stud Conversion Kits available CLICK HERE
                            LIKE my Facebook Page! CLICK HERE
                            • IronFreak
                              • Dec 2012
                              • 3702
                              #149
                              I'm assuming that the boxes allow more contact area with the chassis or is there anything special going on inside or under the car that isn't shown?
                              • Jezza
                                • 222
                                #150
                                Youd be correct there, nothing fancy underneath the car though. Oh and these just arrived!
                                17x9 +20
                                E-9 Motorsports
                                Supported by:
                                DTMFiberwerkz
                                Achilles Radial
