My E30 LS1 Drift Car
  • Jezza
    • 222
    Hi I'm John, and I love to drift. I want to take drifting as far as I can, and this is the car I'll be starting with. A 1987 325e. For the early stages of drifting the car I used an S52 from a 98 z3m, now that I have begun competing in pro am events in an effort to attain my Formula D license I have chosen to go with an LS1 swap.
    The Rebuild:
    Custom Fabrication done by Kelly Wolfe and James Allen at Insane Innovations: https://www.facebook.com/InsaneInnovationsAZ
    Built by Rudy, Brandon, and Grinder at Streetlife Performance AZ
    Power provided by an LS1/T56 combo
    Formula Drift regulation cage
    Tubbed front and rear end
    Fuel Safe Fuel Cell
    Ground Control coilover suspension
    DTM Fiberwerkz body components
    STR 514 17x9 +20
    Achilles Radial
    Kicking off the 2014 Season!!
    E-9 Motorsports
    Supported by:
    Insane Innovations LLC
    DTMFiberwerkz
    Achilles Radial
  • Jezza
    • 222
    The S52 came from a 1998 z3M with 80,000miles pretty much complete. I'm staying OBD2 for simplicity.
    I have always wanted to do this, cleaned up the zf reeeeaalll niceeee.
    Boxes o' parts for refreshing the motor
    E-9 Motorsports
    Supported by:
    DTMFiberwerkz
    Achilles Radial
    • Jezza
      • 222
      Refreshed the motor, seals, spark plugs, waterpump, gaskets, clutch and flywheel, etc. I was extremeley surprised witht the fitment of the ebay headers I got. The gaskets were garbage but thats expected, I already had oem gaskets for this. They cleared the engine mount, sway bar and lolipop with miles of room. Dropping in the motor was a suprisingly easy process. I used the slots on the subframe for the condor motor mounts which seems to be what everyone had to do. After about 20 minutes or so it was all in.
      E-9 Motorsports
      Supported by:
      DTMFiberwerkz
      Achilles Radial
      • DEV0 E30
        • Oct 2004
        • 8904
        Good stuff Jezza. It went to a good home.
        I was wondering where one of my many previous cars ended up, what did you give Andre for it if you don't mind me asking? I almost bought it back but knowing what I sold the rolling chassis to him for, I couldn't justify what he was asking when I saw it for sale (non-functional m20, etc).
        I'm sure I'll run into you. What are the plans for exterior? Complete the LSB?
        • Jezza
          • 222
          Thank you! I'll tell you that I definatly did not pay near the price posted on craigslist ;)
          So once the car is running, which should be very soon probably a week or two, I want to work on more suspension components then a cage. After that I'll look into fixing up the exterior. Not sure what I want to do but LSB is definatly an option.
          E-9 Motorsports
          Supported by:
          DTMFiberwerkz
          Achilles Radial
          • DEV0 E30
            • Oct 2004
            • 8904
            Good. But also makes me wish I had tried harder haha.
            Good plans, you should sign up on azbmw.org if you haven't already.
            • Jalves619
              • 596
              Subscribed. Really looking forward to seeing the progress on this and seeing it in action in person.
              • Jezza
                • 222
                Ive actually tried to but I never got a confirmation email, I'll try again though.
                As am I!
                E-9 Motorsports
                Supported by:
                DTMFiberwerkz
                Achilles Radial
                • Jezza
                  • 222
                  BTW here is the daily and its transformation in a nut shell.
                  E-9 Motorsports
                  Supported by:
                  DTMFiberwerkz
                  Achilles Radial
                  • graveshaker
                    • Sep 2009
                    • 828
                    How did you get your H&R springs so low on your daily?
                    • CubbyChowder
                      • Mar 2012
                      • 1488
                      What is the typical cost of swapping an S52? I see you're staying OBD2 "for simplicity", but every swap I've seen, they convert to OBD1. What are the advantages of staying with OBD2? Isn't that the diagnostics system? Still learning here.
                      --Roundie Revival 2.0 - 1973 BMW 2002 Build Thread--
                      --Golden Boy E30 Build Thread-- (sold)
                      • Jezza
                        • 222
                        They are the race springs which drop about 2 inches.
                        I would say a safe estimate would be around 4-5k. As for obd1 vs obd2 this thread will have infinitley more information than I can give you:http://www.r3vlimited.com/board/showthread.php?t=230879
                        But essentialy my reasoning for staying obd2 is because I didnt want to deal with adding obd1 parts and sensors, which add to the cost of the swap. All I have to do for obd2 is remove some systems in the DME.
                        E-9 Motorsports
                        Supported by:
                        DTMFiberwerkz
                        Achilles Radial
                        • Jezza
                          • 222
                          Mishimoto radiator
                          Putting these in tomorrow most likley
                          My roomates S50 swapped 91
                          E-9 Motorsports
                          Supported by:
                          DTMFiberwerkz
                          Achilles Radial
                          • CubbyChowder
                            • Mar 2012
                            • 1488
                            Thanks dude, after reading through that thread, it makes me wonder why people swap to OBD1 in the first place. If I were to do this swap, I would stay OBD2 as well. Look forward to watching this progress, this might be on my to-do list down the road.
                            • lambo
                              Captain Scene Points
                              • 10953
                              Your roommate's car is quite the sleeper...
