My E30 LS1 Drift Car
  • Jezza
    • 222
    #46
    z3 rack!
    E-9 Motorsports
    Supported by:
    Insane Innovations LLC
    DTMFiberwerkz
    Achilles Radial
    • Tico Frank
      • Feb 2011
      • 351
      #47
      Please explain what was improperly connected that was keeping your injectors from pulsing. I think I read that your dme power and ground wires were swapped? I need help.
      • EREKSHUN
        • Apr 2011
        • 310
        #48
        Sweet build sub'd
        • Jezza
          • 222
          #49
          Things have been slow lately, I wasted tons of time going through wiring to figure out why I couldn't pull codes from the obd2 port. It ended up being the program I have on my laptop, I didnt have a file I needed for the usb interface. All is well now, the car drives nice.(From what I can tell, just a short run up and down the street) No traction in first or second gear.
          Here are a few pics for your viewing pleasure. The z3 rack is stupid amazing and well worth it. The 10mm rack spacers also added quite a bit of angle.
          And this was pretty cool too...
          E-9 Motorsports
          Supported by:
          DTMFiberwerkz
          Achilles Radial
          • Jezza
            • 222
            #50
            Bash bar.
            E-9 Motorsports
            Supported by:
            DTMFiberwerkz
            Achilles Radial
            • JCarp90
              • Feb 2011
              • 1759
              #51
              Car looks badass and I was just in Tempe visiting some friends. Wish I would have seen this hooning about ;)
              • IronFreak
                • Dec 2012
                • 3702
                #52
                [quote=Jezza;3604249]Things have been slow lately, I wasted tons of time going through wiring to figure out why I couldn't pull codes from the obd2 port. It ended up being the program I have on my laptop, I didnt have a file I needed for the usb interface. All is well now, the car drives nice.(From what I can tell, just a short run up and down the street) No traction in first or second gear.
                Got any more information on the brake setup? are you going to be running different calipers for this or will it be to the stock rears?
                Instagram @rebellionforge
                • Jezza
                  • 222
                  #53
                  The hydro handbrake will be plumped in line of the rear brakes to use the stock calipers. I may make a little diy on it, I'm just waiting for fittings to come in the mail.
                  E-9 Motorsports
                  Supported by:
                  DTMFiberwerkz
                  Achilles Radial
                  • IronFreak
                    • Dec 2012
                    • 3702
                    #54
                    I was thinking about doing the same thing. Are you going to "T" into it from your pedal MC? If so are you going to put a reverse check valve so when you pull the handle it doesn’t pressurize the front MC? Just curious how you’re going to go about running all the lines.
                    • Jezza
                      • 222
                      #55
                      Yup T into the MC. I never thought about putting in a check valve, seems like a good idea. I'll contact ASD and see what they have to say.
                      E-9 Motorsports
                      Supported by:
                      DTMFiberwerkz
                      Achilles Radial
                      • FLG
                        • Sep 2011
                        • 3165
                        #56
                        Would be super interested in a diy!
                        Car looks great Btw.
                        Sent from my Galaxy Nexus using Tapatalk 2
                        -Build http://www.r3vlimited.com/board/showthread.php?t=295277
                        • lambo
                          Captain Scene Points
                          • 10953
                          #57
                          Specs on the steering wheel setup??
                          • Jezza
                            • 222
                            #58
                            Thanks!
                            It's an NRG short hub adapter and NRG deep dish wheel. Feels pretty much amazing.
                            E-9 Motorsports
                            Supported by:
                            DTMFiberwerkz
                            Achilles Radial
                            • bimmerboy709
                              • Oct 2012
                              • 100
                              #59
                              This is so inspirational! Moving to las vegas with my girlfriend this summer and were forced to move into a small 1 bedroom apartment with a shitty garage. If you can make big things happen with your e30 in your small apartment garage, so can I! lol. Awesome build so far cant wait for more updates! sub'd!
                              ERHMAGHERD! BERMER!
                              • Jezza
                                • 222
                                #60
                                Thanks! Honestly, I would have found a way to do this even if I didn't have a garage! You should be seeing this thing at some vegas proam events so stay tuned!
                                E-9 Motorsports
                                Supported by:
                                DTMFiberwerkz
                                Achilles Radial
