my e30: s50 w/6262 and a/c
  • getouth
    • Jan 2010
    • 3343
    #46
    You my friend are doing it right! Keep us posted!!
    FEEDBACK:
    http://www.r3vlimited.com/board/showthread.php?t=316212
    BMWCCA #398608
    IG @yagayo38
    "The Best E30's were built with two camshafts four cylinders and sixteen valves!".
    • jbright407
      • Aug 2012
      • 13
      #47
      Nice thread. Very CLEAN!!!!
      • Mesarina
        • Jul 2012
        • 268
        #48
        repaired my a/c vents... from this..
        to that!
        got my ss brake lines from turner motorsports
        alcantara boots from topgaiters
        before
        after
        • Mesarina
          • Jul 2012
          • 268
          #49
          finally scored an e30 325e 86/87 driveshaft!
          ordered the blackbird kit with 12mm risers from condor speed
          a friend sold me his 4 bilstein sport shocks for $155 after he had some speed bumps near his house, they have about 200miles on them!
          got some front & rear crankshaft seals, valvo cover gasket and 80c thermostat
          the passenger arm was broken because of the crash, but another friend which just put a TRM Turbo mount arm gave me his stock arm for free, then I installed the e28 engine mounts..
          installed the thermostat housing with a 80c thermostat
          removed the ugly manifolds
          • Mesarina
            • Jul 2012
            • 268
            #50
            bought a 6cyl 7000rpms tach plug from ebay too
            • Mesarina
              • Jul 2012
              • 268
              #51
              last week I replaced both crankshaft seals..
              the clutch is not that good, but Im still gonna use it, If it need the replacement, I can remove the engine again..
              testing the headers
              • Mesarina
                • Jul 2012
                • 268
                #52
                more cf...
                condor blackbird kit delivered
                bought some vht niteshades, i want red & smoked tails
                some "while there" mods..
                oil pan ready
                a pic of last sunday
                • DasBLiK
                  • Jun 2013
                  • 8
                  #53
                  Wow brother. So complete, super clean. So detailed BUMP FOR SURE!
                  • silence
                    • Jun 2007
                    • 1824
                    #54
                    Glad you got them!
                    •• Powersteering Deletes • M20 Motor & Trans Mounts • 24V swap mounts • UHMW Offset CABs ••
                    •• Rear Subframe Bushings • RTABs • Facebook ••
                    • Nick_S
                      • Apr 2011
                      • 3655
                      #55
                      Man this car is clean. Normally don't like tons of CF but it works well with that color.
                      91 318is M50 swapped
                      05 Honda Pilot
                      24V swap thread
                      • Mesarina
                        • Jul 2012
                        • 268
                        #56
                        Originally posted by silence
                        Glad you got them!
                        Already installed the other kit on the rear subrame for an e30 touring which will be getting a s52b32us swap, Thanks!
                        • Mesarina
                          • Jul 2012
                          • 268
                          #57
                          Thanks, I like how it looks with diamond schwarz more than other colors...
                          • zumjosh
                            • May 2012
                            • 158
                            #58
                            Lovin' the work so far! I'm itching to start my S52 swap.
                            • Mesarina
                              • Jul 2012
                              • 268
                              #59
                              -10an cap for the oil return... maybe it get boosted later, maybe not..
                              removing front subframe out of a 325es, that way Ill have the engine and e36 m3 rack in another reinforced subframe ready for the swap
                              subframe out
                              ready for cleaning, reinforcement and install
                              e36 m3 rack
                              rear subframe and diff out of the same 325es (s2.93)
                              wish I can go lower, but streets here are a no-no, besides I want this to be my daily driver
                              • Mesarina
                                • Jul 2012
                                • 268
                                #60
                                subframe out
                                e36 m3 rack
