Ive got a 4.10 in mine.
Ford 5.0 swap into a Bronzit. Update: Now running, VIDEO ADDED.
HOLY CRAP! for real?
I drove a m42 with a 4.10, that was just way to high. I don't want to be in boost when I'm at 60 in 5th gear hahaha.sigpic
Instagram @rebellionforge
Hey guys, I'm very slightly entertaining the idea of this swap. I have been stockpiling turbo parts for a good few months and estimate being able to sell it all for around $1400ish, plus a few other many parts I have lying around. How cost effectively do you think I could pull this off? I don't have fab skills, but I have been looking for a reason to learn some.
Do you think this swap (5.0/t5) could be done for <$2000ish? I would have access to a lift and I have a second car so I can take my time doing the swap. I would probably be going the carb route. There are a bunch of 5.0s in the yards nearby, many being from explorers, so I could have the gt40 heads and such, as well as be able to sell the FI setup to recoup some of the money.
What do you guys think?Last edited by TimbyMaTombo; 04-09-2013, 11:17 AM.
I've got <$400 in mine, but I traded labor for the drivetrain and I welded up my own oil pan/crossmember/slave cylinder mount.
If you are creative and good with your hands, it won't cost much. The only things I couldn't avoid are driveshaft work, conversion flange, bought the mounts to save some hassle.
I'd imagine it could be done for <$2k on average. I do however have at least 30 hours of labor into it, if you go carb it will be a lot easier. Then again, wiring the FI up wasn't hard, just time consuming.No E30 ClubOriginally posted by MrBurgundyAnyways, mustangs are gay and mini vans are faster than your car, you just have to deal with that.
Motors and tranny can be had cheap, keep your eyes on CL. I don't know down there, but around here CL is littered with 5.0's stock to modified. My buddy just picked up a motor and tranny for $500.
Dollar amount is tough, I agree with exodus, but it depends on how much self discipline you have.....mine was going to be a basic carb swap....now it's a FI, fuel injected MS2 (thanks exodus) monster.
You can learn to fab stuff, or checkout e30v8. If there is something you can't build, they have it for the swap, it'll just cost more out of your pocket.sigpic
A little far for me, biggest event I'll be going to this year is h2o in ocean city, MD.
Made some good progress today, moved the trans over about a half inch and that took care of the low speed vibrations. Still need a new driveshaft though, at around 80mph you can feel it start to hit the body. I'm done with it, going to drive it for now and when I can, I'll have a new tube made out of steel. The aluminum driveshaft is just too thick to be practical.No E30 ClubOriginally posted by MrBurgundyAnyways, mustangs are gay and mini vans are faster than your car, you just have to deal with that.
Get a junkyard drive shaft and shorten it.sigpic
Heading to the yard on saturday! They charged me 100 to shorten the aluminum and balance, hoping the steel will be less.
Any idea what the diameter is of a stock fox driveshaft? I'm thinking I'll take an old u-joint up there and just find something that uses the same joints but 2.5" or so in diameter. maybe I'll get lucky and find something that's already the proper length.No E30 ClubOriginally posted by MrBurgundyAnyways, mustangs are gay and mini vans are faster than your car, you just have to deal with that.
Going to stuff the big mustang radiator in there tomorrow.
My under hood temps are ridiculous, coolant gauge never goes below the half way mark, and I can tell that the A9L is pulling timing once hot. The car turns into a slug once it is up to temp.
I saw a stock e30 radiator was used in a lemons car... I just don't see it being practical.No E30 ClubOriginally posted by MrBurgundyAnyways, mustangs are gay and mini vans are faster than your car, you just have to deal with that.
Mine runs about 185-190 in normal driving and lower on the freeway. Traffic it'll creep. Ive never had it in stop and go but the only time ive had it get. "Too high" was in line at a drift event on a 95 deg day. Track temps were closer to 105. Climbed up to like 225 and i shut it down. Lol ambiant temps wound up killing my coil then melting my clutch cable lining. This is with a half dead pusher 525 rad and zero ducting.
Ill be going with an aftermarket alum rad, taurus fan and custom ducting/mounts for this season tho.Last edited by eurotrash; 04-11-2013, 10:19 AM.
Had a nice ride home tonight with the needle riding right at the 1/4 mark.
Ended up getting a Champion aluminum 2 row radiator that fit in between the rails. I had to cut off the stock mounts, and used some angle iron to hold the bottom, welded to the body. A little modification to the stock top retainer, and she's ready to roll.
Also installed the condenser fan and bypassed the resistor. Now when I press the a/c switch, air starts moving. I can finally idle for as long as I want without the needle going past the 1/2 mark. With a 160* thermostat I'm now hitting about 205 at an idle with the fan on.No E30 ClubOriginally posted by MrBurgundyAnyways, mustangs are gay and mini vans are faster than your car, you just have to deal with that.
Originally posted by Exodus_2pt0 View PostEnded up getting a Champion aluminum 2 row radiator that fit in between the rails. I had to cut off the stock mounts, and used some angle iron to hold the bottom, welded to the body. A little modification to the stock top retainer, and she's ready to roll.
