E36 M3 - LS3/TR6060 Swap
  • jakeb
    • 1909
    #106
    Turn cardboard into metal...
    Rear will mount off the trans... something like this
    This piece of metal will be cut where the line is after I drill a hole on each side of the big hole going up from the bottom. Then I will tap the upper half so it is easier to take the entire assembly in and out.
    The entire thing will be powder coated.
    www.classicdaily.net
    1970 m42 swapped 2002
    1985 LS1/T56 Swapped e28 (557e)
    www.blunttech.com - For all your parts needs
    Follow me on Instagram for constant build updates @classicdaily
    https://www.facebook.com/ClassicDailyLLC
    • Farbin Kaiber
      Lil' Puppet
      • 29502
      #107
      Cardboard into Metal is some alchemist magic shit right there.
      Or a pretty cool band name.
      • jakeb
        • 1909
        #108
        hahaha...I like it as a band name. Everyone plays can-jo's and guitars made out of boxes run through LOTS of distortion.
        • jakeb
          • 1909
          #109
          Cut down the back mount to make the entire shifter easy to remove.
          Before cutting it apart i drilled holes. These will be drilled bigger and tapped to m6.
          How it will fit
          Removed the linkage that hooks to the shifter rod and then drilled a hole through it.
          That way the rod will go through the linkage end
          About where it will end up
          Excess will get cut off and then the two pieces will be welded together. I might have a one piece linkage cut out on the water jet. Will see how the modded one turns out first.
          • jakeb
            • 1909
            #110
            Shifter all done (needs to be cleaned up a little bit and then coated) - Only tacked in the pics
            Inside the car
            old shifter knob.... This shows 3rd gear. The shifter is height adjustable. It is at it's lowest point right now.
            Trans mount (needs to be fully welded and a gusset or two added)
            Flaming river Ujoints / Borgeson DD sliding steering shaft...next to the stock one
            Starting work on the headers. New little tool to make sure the cut is across the radius.
            I posted a pic of a converted wood saw to cut metal but I wasn't happy with it so it got returned after I found this big ole machine on craigslist. Made in 1937...made to cut only metal. Makes cutting stainless U bends easier. Not to mention old machines like this are cool.
            Passenger side header started
            Pan to subframe clearance..
            • LJ851
              • 7918
              #111
              Do Alls are the shit, nice score!
              Lorin
              The M30 is God's engine.
              • jakeb
                • 1909
                #112
                Sure is...when this thing popped on CL. I was all over it. Should have talked the guy down but I was too excited about it. It is ugly as can be...paint peeling, etc etc but it is a beast of a machine. Probably weighs 400-500 lbs.
                • ACHTUNG
                  • May 2005
                  • 2397
                  #113
                  Sick band saw. It is a beast!
                  1989 US E30 Cammed S52
                  Under Construction: 1983 Euro E28 Cammed LQ9/LS3 Heads/Jakeb E28 LSx Kit
                  • jakeb
                    • 1909
                    #114
                    Your headers will get some time with the big saw too!
                    • nick526
                      • Jan 2011
                      • 258
                      #115
                      Awesome job on that shifter. How's the feel of it?
                      I miss the old BMW
                      • jakeb
                        • 1909
                        #116
                        Feels really good..direct, not too much effort needed. That is also with a dry non running transmission to so it should be even smoother with fluid and when its running
                        • jakeb
                          • 1909
                          #117
                          A little bit of work on the passenger side header.
                          • GreasyE30
                            • Dec 2012
                            • 159
                            #118
                            Nice work, they look real good.
                            Must have been great when you realized you didn't have to go crazy on fitting in those header pipes.
                            2006 Dodge Magnum SRT8
                            1986 Slammed Shwarz ETA Coupé (DEAD)
                            2004 Slammed TSX A/T (Wifey's)
                            1963 Slammed ChevyII never ending project
                            1982 Suzuki GS1100GK CaféRacer
                            • jakeb
                              • 1909
                              #119
                              The drivers side header is an entirely different animal....it will take much more time than the passenger side.
                              • GreasyE30
                                • Dec 2012
                                • 159
                                #120
                                Ha! I spoke too soon, I knew it..
