E36 M3 - LS3/TR6060 Swap
  • jakeb
    • 1909
    #136
    Had to make some changes to the headers and also move the engine mount a little bit to give me more room.
    From here....
    to here
    More header work....this fits but I did have to slide the drivers side engine mount out to get it in.
    I'll take more pictures from the bottom later today...it was late when I came in last night. THey might ave to get tweeked a little bit more but headers are just about done!
    www.classicdaily.net
    1970 m42 swapped 2002
    1985 LS1/T56 Swapped e28 (557e)
    www.blunttech.com - For all your parts needs
    Follow me on Instagram for constant build updates @classicdaily
    https://www.facebook.com/ClassicDailyLLC
    • jakeb
      • 1909
      #137
      Forgot to post a picture of the tires mounted up.
      Header clearance from below
      Might run tree house style FCABs to give more room here but they do clear the stock bushings too.
      Collector
      • stanhayward
        • Mar 2013
        • 765
        #138
        Sub'd, very cool project! Huge props on the fab skills, man, those headers are beautiful!
        1990 325i Touring - The Bonsai Bimmer - Patiently Waiting
        1984 316 Coupe - The Base Model - Pain in the Ass
        1988 750iL - The Daily Driver
        ...And a couple others...
        • ACHTUNG
          • May 2005
          • 2397
          #139
          So awesome.
          1989 US E30 Cammed S52
          Under Construction: 1983 Euro E28 Cammed LQ9/LS3 Heads/Jakeb E28 LSx Kit
          • M-technik-3
            • 18946
            #140
            Nice meats what size show more.
            • jakeb
              • 1909
              #141
              rears are 285, fronts are 265
              • M-technik-3
                • 18946
                #142
                Yeah your gonna need some flares that's for sure. What style flares do you have conceived?
                • jakeb
                  • 1909
                  #143
                  grafting the flares from e46 fenders into the e36 fenders/rear quarters. All metal....
                  • F34R
                    sLaughter
                    • 12376
                    #144
                    mmmmm <3
                    Instagram: @BWeissLeather
                    Current cars:
                    ~ '87 325 M30B35 swap
                    ~ '87 535
                    ~ 01 540 Msport 6spd
                    ~ '06 X5 4.8is
                    • IronFreak
                      • Dec 2012
                      • 3702
                      #145
                      If you can't find a good deal in Treehouse CAB's checkout BimmerWorld. They make some like that, and you can replace the bushings in them as well. I got a set for my e30.
                      Looks really good man!
                      Instagram @rebellionforge
                      • jakeb
                        • 1909
                        #146
                        Yeah I would get them from bimmerworld. I was unaware they had replaceable inserts tho. Good to know!
                        thanks
                        • jakeb
                          • 1909
                          #147
                          Worked on the suspension some...needed a break from headers.
                          Rear suspension/diff/sway bar/etc is all installed
                          Some of the front together as well
                          • ACHTUNG
                            • May 2005
                            • 2397
                            #148
                            Shiny
                            • jakeb
                              • 1909
                              #149
                              The rear brakes use e46 M3 rotors...while the e36 m3 rear parking brake shoes WILL work if you wind them really far out they are not ideal. So Eric at Rallyroad.net suggests using e46 m3 shoes. They do have to me modified slightly.
                              Here they are before...as you can the lower spring will hit the shoe.
                              And then a little trimming
                              The adjuster had to be opened up just a little bit to fit the e46 shoe...
                              Left is before...right is after
                              All mounted up....brake bracket is on as well.
                              Rotor on...lug bolts on just to hold the rotor on with no wheel. Studs are on the way.
                              • F34R
                                sLaughter
                                • 12376
                                #150
                                Looks great Jake! and stick with the treehouse racing, those Bimmer ones look cast.
                                Current cars:
                                ~ '87 535
                                ~ '06 X5 4.8is
