Porsche 911 Project
  • ThatOneEuroE30
    • Dec 2013
    • 8626
    #241
    ^ what he said
    1991 318i 4dr slick top
    Mtech 2 turbo restoration
    • 5ickride
      • 2922
      #242
      Perfect wheel
      • csermonet47
        • Jul 2009
        • 937
        #243
        Love it!
        Are Three Vee
        Dad Spec
        • iwantspeed
          • 3164
          #244
          love the new wheel
          Project
          Parts for Sale
          Feedback
          YouTube Channel
          • LJ851
            • 7919
            #245
            Originally posted by mitchlikesbikes
            ^ what he said
            Originally posted by 5ickride
            Perfect wheel
            Originally posted by csermonet47
            Love it!
            Originally posted by iwantspeed
            love the new wheel
            Thanks, guys.
            Lorin
            The M30 is God's engine.
            • 2mAn
              Señior Mod
              • 21024
              #246
              Originally posted by LJ851
              Went back and forth about wether to buy a new hub for the italvolanti wheel because the adapter i would need with my shortened momo hub would need to be like 40mm thick.
              I stumbled across this spacer that is shaped like a spool and uses separate bolts on the top and bottom as opposed to being through-bolted. It was available in the right thickness and the upper flange had plenty of meat to allow me to machine the italvolanti bolt pattern with massive 8 X 1.25 threads. An inexpensive and simple solution.
              Why am I just seeing this now!?!?! do you have a link?
              Simon
              Current Cars:
              -1966 Blue Boat
              -1969 Red VW
              -1986 White BMW
              -2006 Green Thing
              Make R3V Great Again -2020
              • LateFan
                • May 2013
                • 4432
                #247
                What did you use to clean those carb bodies? - they look good.
                • GillesBigCowboy
                  • 507
                  #248
                  Wow, this is an inspiration for me. Thanks.
                  My aunt has a 1982 SC that spent its first 25 years in CA, and then it moved to her garage in Alpharetta. I am pretty sure the car will be mine eventually. It was last driven about 8 years ago... I worry that the prolonged sitting is doing damage, but I know nothing about these cars.
                  87 4dr specE30: Bitsy (lurking above), 89 4dr 325i blau, 91 318is brillrot, 90 325ivertbronzit
                  • lambo
                    Captain Scene Points
                    • 10953
                    #249
                    I need more updates pls
                    • Staszek
                      • 2533
                      #250
                      Just read this thing all last night. Awesome project!
                      • LJ851
                        • 7919
                        #251
                        Duck tail is back on, i'm enjoying that.
                        I've been driving around with my wideband 02 hooked up. My suspicions about AFRs were pretty much on point.
                        Full throttle is a little rich and fades richer at high rpm.
                        Light throttle is Very rich, like 10-10.5 to 1.
                        There really aren't any wild fluctuations in the AFRs which is nice, I'm hoping some simple jet changes will get me an acceptable fuel curve without creating any new issues. We will see.
                        LateFan, the carbs are pretty much brand new so i just sprayed them down with Berrymans carb cleaner.
                        Going to put in an order for a selection of carb jets today.
                        Lorin
                        • 4Running Daily
                          • Aug 2012
                          • 55
                          #252
                          Duck tails do it better
                          DSC_0114 by Connor Rhoades, on Flickr
                          • LJ851
                            • 7919
                            #253
                            A crapload of carburetor jets are on the way to me from PMO. Woooooo
                            Lorin
                            • spiDmang
                              • 3941
                              #254
                              so jealous of this...and duckbill gets my vote :up:
                              91' 318iS - S54/6MT Swapped
                              08' E90 M3 6MT - Daily
                              Originally posted by IronJoe
                              Originally posted by 2mAn
                              • LJ851
                                • 7919
                                #255
                                Been driving the 911 a lot and doing jetting changes. I've made good progress and currently have a setting that has good throttle response, doesn't foul plugs and has a good full throttle profile.
                                It's current fault is that it runs super rich at light throttle and i haven't been able to address that without causing an unacceptable compromise is throttle response.
                                My drivers side door handle trigger just broke so i need to fix that too.
                                Lorin
