E30 M3 Project.
  • bimmer8604
    • 3017
    E30 M3 Project.
    Well, after being absent for a few years I have returned. I've just about completed my M Coupe project, and went on the search for an E30 M3. Long story short, I bought the car site unseen over the phone from Utah. We negotiated a price and I mailed a check. 4 months later my friend towed the car on a trailer back to Wichita for me. I was told the car had rear end damage, and the body was "fair". Overall the car was described accurately, however the paint sucks and there are dents everywhere. The driver's door is the worst, and may need to be replaced. Anywho, onto the pics. Remember, I started this project last April.
    How she arrived:
    The first step was to replace all the suspension and fix the damage in the rear. I chose IE stage 3 springs and Bilstein Sport shocks/struts. Installed IE subframe bushings/trailing arm bushings, etc. New bearings blah blah. Also replaced the damaged trailing arm and installed a new axle. I had some photos from my phone, but they were blurry and boring.
    Talking to the PO it sounded like the motor was okay. Still ran, but the exhaust manifold had been ripped from the head and had a horrible exhaust leak. I attempted to start the car, and it ran for about 30 seconds. I didn't like what I heard, and just didn't sound "right". A quick compression test and cylinder leak down determined low compression on cylinders 2 and 4 due to heavy carbon build up on the valves. I said "screw it", and decided my project just got a bit more expensive. So out came the motor!
    All apart!
    Sent everything to the machine shop to have cleaned/checked out. Everything was fine, and only some cleaning, polishing and new valve guides were needed. Re-honed the cylinder walls and polished the crank. Picked everything up!
    Block assembly was next, making sure all new bearings had proper clearances, new rod bearings as well, wrist pins and new rings were fitted. all OEM.
    New chain guides etc. I was surprised at how expensive these puppies were!
    Head is on! Of course all new gaskets and seals were installed. All OEM.
    Cams were able to be reused
    Next was new cap/rotor. Water pump, yadda yadda. Dont worry, I installed all new exhaust studs...
    More accessories. I know the throttles are "dirty" but the metal is stained, and I didn't feel like taking them apart to powder coat. They work just fine :-)
    How she sat in storage for almost a year. At least it was heated/air conditioned.
    Next was fitting the Isahara/Johnson crank scraper. I went with the teflon scraper, and it took nearly 2 weeks of working on it to make it fit. Should be worth it, and I like the added benefit of keeping oil down in the pan for the new oil pump. No shots of the actual teflon, as I didn't have my camera with me.
    Quick valve adjustment
    Fresh powder coated valve cover and new plug wires
    And powder coated intake plenum with accessories
    Already to drop in!
    I'm sorry to say I don't have any more photos. But as of 3 weeks ago I dropped the motor and installed new radiator and all new silicone coolant hoses. Drained the fuel tank and installed new fuel filter and all new fuel lines. Injectors were rebuilt when I had the motor apart. Installed a new battery and bingo, she fired up. I've only driven it about 50 miles, but she drives very nice. I'll need to take more photos, as next is body work. I've stripped the car down to bare shell and the body work begins on Monday. Sucks to take apart a car and put it back together just to take it apart again!
    My next decision is what color??? Car is originally Zinno, but I'm leaning towards a brighter red, something out of the can. Or maybe orange or henna. Haven't decided yet. Stay tuned!
    Kyle
    1988 M3, 97 840, 99 XJ
    DILLIGAF
  • bimmer8604
    • 3017
    Edit, just got photos from a friend who was there for the motor install. Yes that's my mug in the photo.
    In she goes!
    All in
    Kyle
    DILLIGAF
    • fronton
      • Oct 2009
      • 1262
      awesome. nice engine refresh. Are you repainting it the same color? Is that zinno? What are your interior plans, or is this a full stock restoration?
      • Court M3
        • Jan 2004
        • 6713
        Welcome back! Been awhile since we've seen the car in your sig
        Continuous For Sale Thread
        323i s50
        • evandael
          • Oct 2009
          • 2881
          friday night r3v'ing is complete thanks to your thread. i love rebuilds and can't wait for more!
          • BlackbirdM3
            • 2772
            Nice work. I'd say keep it the same color that way everything will match nicely. That is unless you are planning to completely strip the car down to a bare empty shell with no wiring, windows ect. My guess is the paint on the interior isn't bad, nor are the door jambs. Also, if you go this route you can carefully mask all the VIN #s and it will look correct when everything was all said and done.
            If you are pulling the motor out again, get those headers ceramic coated. It will keep them looking good, and will keep the underhood temps down.
            Looks like a good project. My hat is off to you for rebuilding the S14, that is the only motor that should ever be seen under the hood of an e30 M3 ;) .
            Will
            '88 BMW M3
            • reelizmpro
              • 9552
              Good stuff! You have to be brave or crazy, maybe both to buy an M3 sight unseen...that is unless the price was excellent.
              88 M3 - LACHSSILBER
              89 M3 - ALPINEWEISS II
              • kingston
                • Jun 2010
                • 2669
                Nothing sexier than a Henna E30 M3, so there's my vote!
                BTW, GREAT work on the S14! You're doing that car justice!
                Originally posted by LJ851
                kingston is the play by play announcer for this thread.
                ‘Tis by the grace of God that my cars run!
                Originally posted by unloadedak
                #teamross
                Siobhan's Build Thread - UPDATED!
                • bimmer8604
                  • 3017
                  Will
                  I'm jealous of your Alfas. I can't decide if next car will be an Alfa GTV or another BMW, or perhaps a Pcar of some sorts. I don't plan on pulling the motor. Its resprayed zinno right now, I'm thinking of either Henna or another variant. I know I'm sticking with "red" so I doubt I'll worry about painting the engine bay. All glass is out of car now, as well as door trim etc. So jams will be painted.
                  Kyle
                  DILLIGAF
                  • bimmer8604
                    • 3017
                    Your name confuses me every time I see it. My brother's name is Kingston, and lives in the KC area. I'm leaning towards henna aswell.....
                    Kyle
                    DILLIGAF
                    • archie
                      • 5448
                      Wow! I dig what you have done. Beautiful car. I must be getting older but I dig stock weaves on these cars more and more by the day.
                      Possible to get a few interior shots?
                      88 M3 Diamantschwarz
                      89 M3 Zinnoberrot
                      56 Isetta
                      LIKE ARCHIE'S on Facebook!
                      • CrusherCurtis
                        • 2532
                        Bravo sir. You deserve a standing ovation for keeping it s14.
                        • bimmer8604
                          • 3017
                          Price was good :-). I always drool over Mariano's and your M3's..
                          Kyle
                          DILLIGAF
                          • el bimmer
                            • 900
                            Sweet!
                              • 37833
                              Fuck you Kyle! :D
                              Congrats on the car and glad to see you back here.
                              Grover Beach, California
                              BimmerHeads.com
