318 reborn into e30 335
  • chance
    • Feb 2012
    • 671
    For some reason on my motor the driverside and passenger side engine mounts use different size bolts
    1991 335is in progress
    • navytapaul
      • 615
      ok so I'm not crazy then. I have two bolts on the passenger side that are bigger than the rest, not sure where they went either
      • chance
        • Feb 2012
        • 671
        Got the trans mount made. Its now all welded up, just need to counterbore the chassis mounting holes as its much thicker than oem. A little grinding and a coat of paint will major it all
        And yes it got welded in the bends.
        • cormier
          • 380
          Lookin good dude! That sort of clearance is norm on those swaps?
          • chance
            • Feb 2012
            • 671
            Yep, these are long motors. They require some hammering on the firewall.
            Made some good progress today.
            Trans mount is finished and installed. Its not the prettiest thing I have ever made, but it is very strong and should do the trick.
            Got my shifter all hooked up. I didnt go fot making a DSSR just yet. The Evo3 shifter felt awesome, especially after adding s couple extra plastic washers in the pivots of the selector rod. My buddy whos been building e30's for years says its the best shifter he has felt in an e30.
            I also got my shortened drive shaft in. I had 4 inches cut off of the front half. It lines up perfectly.
            A number of other small things got done today as well. I placed a 110 dollar order with GP+S to get all the last gaskets. seals and cooling system parts that I could think of.
            I have fount out that the previos owner had removed a number of gaskets.
            Hopefully they will be in monday, then I can start getting them in
            • F34R
              sLaughter
              • 12376
              That is gorgeous paint! Coming along nicely.
              Instagram: @BWeissLeather
              Current cars:
              ~ '87 325 M30B35 swap
              ~ '87 535
              ~ 01 540 Msport 6spd
              ~ '06 X5 4.8is
              • chance
                • Feb 2012
                • 671
                Thanks man. I just realized I have had the car almost exactly a year as of this month. So it has been a ton of wrenching and almost no driving.
                At this point pretty much the only thing that hasnt been removed and upgraded is the interior... yet.
                • JCarp90
                  • Feb 2011
                  • 1759
                  I've had mine for over 2 years and that's how it's been for me as well. Car looks great man. M30 swapped E30s are godmode.
                  • chance
                    • Feb 2012
                    • 671
                    Got the IE street and track camber plates in so far today. Im worn out, but there is still some progress to be made this weekend.
                    • grays
                      • 1343
                      those acura integra wheels fits right on?
                      • chance
                        • Feb 2012
                        • 671
                        The bolt pattern is the same, but the hub bore and the offset is wrong.
                        So they fit right on, WITH spacers.
                        • F34R
                          sLaughter
                          • 12376
                          It is worth the wrenching man, mine has been under the knife since early '10. It is worth the smashed hands and exhausted weekends.
                          Current cars:
                          ~ '87 535
                          ~ '06 X5 4.8is
                          • chance
                            • Feb 2012
                            • 671
                            Isnt that the truth. I am left handed, and currently have a busted ass fingernail on my left middle finger, and two gouges from an angle grinder in my left pointer finger. So my left hand is working its way to being useless. I also did both of those injuries in one night haha.
                            Cant wait to drive this car. Ive ridden in a m50/s52 heads&cams car, and it was really fun. I am hoping the torque of the m30 should make this car a hoot on the streets.
                            • F34R
                              sLaughter
                              • 12376
                              Angle grinder without heavy leather gloves? 10 bucks protect your hands! I use gloves no matter what I work on.
                              Current cars:
                              ~ '87 535
                              ~ '06 X5 4.8is
                              • chance
                                • Feb 2012
                                • 671
                                I never use leather gloves with any rotating machinery. Id much rather nic a finger than have it grab the leather and do worse. Granted, an angle grinder most likely wouldnt rip a hand off, but I do a good bit of work with mills and lathes, and leather gloves are a big no-no there.
