6/83 grey market 323i.. mtech I S50 5-lug
  • kronus
    • Apr 2008
    • 13032
    #211
    Originally posted by Wanganstyle
    For impedance of Injectors a Toyota resistor pack for avalon 6 cylinder will work perfectly; 1998 avalon uses the same resister as a mk4 Supra; played this game on 2JZGTE with J spec brain and usa bigger supra injectors
    Just put it in line on the power path pre injectors
    Sent from my SAMSUNG-SGH-I337 using Tapatalk
    Interesting. I'll keep that in mind, but I think I'll be going with full-on aftermarket injectors and MS does impedance matching. We'll see.
    Originally posted by M-technik-3
    Is that Byzantine?
    Byzanz, yup!
    cars beep boop
    • Farbin Kaiber
      Lil' Puppet
      • 29502
      #212
      Anything mew?
      • kronus
        • Apr 2008
        • 13032
        #213
        nothing mew. I've been cheating on this project with a z3 m coupe. during the summer I will return to it. need to find a body guy.
        cars beep boop
        • ThatOneEuroE30
          • Dec 2013
          • 8626
          #214
          Just went through this thread for the first time... I like it good work.
          1991 318i 4dr slick top
          Mtech 2 turbo restoration
          • delamaize
            • Nov 2013
            • 1465
            #215
            get rid of those damn DOT side markers Please.....
            Dumpster Fire Pilot
            • kronus
              • Apr 2008
              • 13032
              #216
              sidemarkers are getting patched up, don't worry.
              finally, progress:
              also I've stumbled into an S52 and this car is going to be more of a daily because I bought a crazier one. Which makes more sense: M30 turbo dogleg, or S52 not turbo not dogleg?
              cars beep boop
              • Farbin Kaiber
                Lil' Puppet
                • 29502
                #217
                S52, not turbo, not dogleg. Keep it OBDII, and save the diag headaches on a DD.
                • kronus
                  • Apr 2008
                  • 13032
                  #218
                  but that's so sensible and practical :(
                  I wonder if the small-case m20 dogleg I got with the car would put up with s52 power...
                  cars beep boop
                  • Farbin Kaiber
                    Lil' Puppet
                    • 29502
                    #219
                    My 323i could use it more, and I bet it wouldn't die before winter. I'd cry if you s52 melted a dogleg.
                    • golde30
                      • 11464
                      #220
                      Is the dogleg know for being weaker than the getrag 260?
                      IG: @Baye30
                      • ak-
                        • 12422
                        #221
                        You'll get bored with the s52 in like a week.
                        Turbo it. The headaches are fun too, you just won't admit it to yourself.
                        1991 325iS turbo
                        • LJ851
                          • 7919
                          #222
                          It's a 245 (E21 4 cyl) based trans so it is noticeably weaker than a 260. That being said, one in good condition behind a S52 would probably last fairly long if it wasn't driven by an asshat.
                          Alpina used the 245 gearbox bolted to a M30 in their E21 B6 and they did ok.
                          Lorin
                          The M30 is God's engine.
                          • kronus
                            • Apr 2008
                            • 13032
                            #223
                            I dunno guys. We'll see, I guess. I wonder if getting an aluminum M52TU block bored out to S52 specs is practical-ish. Lightness is something I'd like to pursue with this car if I go the S52 route.
                            Sorry Farbin, I'm pretty easy on transmissions, I think I'll give it a go. Hope the selector shaft isn't too fucked.
                            Cut down and prepared a replacement. It's getting TIG'd in tomorrow:
                            I also prepared and cut patches for the rear federalization marker holes, antenna hole, and rear window rail rust hole.
                            While it's getting inserted I'll need to pull the dash back out to do work on the front window rust. I just put it in, oh well.
                            cars beep boop
                            • Farbin Kaiber
                              Lil' Puppet
                              • 29502
                              #224
                              No worries, my transmission is fine, so it's a want right meow.
                              • kronus
                                • Apr 2008
                                • 13032
                                #225
                                rebuttal:
                                needs the welds ground down and some primer. The rest of the holes still need to be patched, but this was the biggest and scariest rust on the car. I'm happy it's better.
                                cars beep boop
